Arvex
4 -
Arvex's Achievements
I don't mean to double post, but I found the pdf's Rosch was talking about (finally.) Unless I want to make the DIN and DOUT boards myself, it looks like I would have to order 2 DOUTX4 board and three DINX4 boards for a full control surface (unless there is a DINX2 on another site)
That many cables is quite intimidating to my simple mind (kind of funny because I build my own computers...) Are those just prototyping boards with the buttons and rotary encoders soldered down or is there more stuff between them and the boards? Huh, I think I saw that picture before and it didn't quite register for some reason that I was looking at a C64 case with an MB 6582 in it. Not sure I like the idea of the holes from the C64 case showing like that, I think I will go with the PT-10 and might see able pulling the logo off the C64 case (if I happen to get my hands on a broken C64) and gluing it on to the PT-10.
I was planning to buy most of my parts from SmashTV and buying the parts he doesn't sell from electronics parts suppliers out here. EDIT: Also, I'm not sure about anything on the flea market because I don't know when I'm going to start this project. I'm thinking that might not be a bad idea, I didn't take polyphony into account and I also (wrongly) assumed that I would need to start with all eight SID chips to run one of these. Problem is that I looked at the MB-6582 as something for people who have made an MB-SID before, I'm a little concerned that this might be a lot more complicated to set up than the MB-SID (but that might just be me being a little intimidated by the larger board.) I was going to say the price difference scared me a little, but after a second look at the combined price of a SID module and Core, the MB-6582 board sounds a lot more reasonable. Another thought that came to mind... Would the MB-6582 main board fit in a C64 shell or is it too big? I'll check this Ponoko thing out, too. If I can make my panel for under $80, then I might just go with that. My plan for the panel was to just print up the frontpanel .fpd file at 1:1 scale and use that as my template, use my dad's drill press to get the holes for buttons and rotary encoders/knobs and to start the hole from the LCD and to acid etch all of the text and lines/details. For future reference, assume cost is only a secondary issue to me because I'm in no hurry and can always save for another few weeks/months more to get something nicer. The front panel is just a little steep for me when I think I can make it myself.
Hello, I've been looking at the MIDIbox SID stuff for a while with the intent to one day build a MIDIbox SID. That day is just a little closer now that I finally have a keyboard with MIDI ports again (wouldn't believe how picky I am with keyboards.) I tend to plan my projects months before I actually start working on them, so this might not start for a while. This is not only my first MIDIbox project, but would be my first real electronics project I've undertaken. (I put together a few hobby kit electronics kits that my dad bought me when I was a kid, but that was it, but I do know how to solder.) This is going to be a learning experience for me, which means I'm going to take it slow while I learn everything along the way (this is the best way for me to learn stuff) The plan right now is to get a single SID chip which will be controlled from my keyboard, my keyboard doesn't have a sequencer so I don't think I'll have much use for multiple SIDs at this point (might get a second one for stereo later.) For the case, I'm either going to use a PT-10 or an actual C64 case, depends on what I find in the market of damaged/broken C64 parts. I plan to make my own front panel by hand since I don't feel like paying for an expensive machined one. Here's what I think I need: -6581 Chip (important) -C64 PSU or other compatible power supply (and matching jack) -Either a PT-10 or C64 case -Front panel material -2x20 LCD -Core8 kit (with MIDI jacks and PIC18F4685) -SID module kit -LEDs -2 audio jacks (in and out) -24LC512 (bank stick) -Rotary Encoders (1 undetented and 14 detented, right?) What I'm not sure about yet: -Buttons, not sure what kind(s) -Boards for the control panel? I can't seem to find anything for what I need to make the control panel and what needs to be wired up to it. -DIN and DOUT modules? -SIL and DIL pin headers and IDC connectors? -Ribbon cables, do I just need one of each? Are these only used for connecting the MB-SID to the Core? Anyways, I have a few questions I wanted to ask to help me figure out what I need. -I'm trying to make a price estimate so I know how much to budget for this, but I keep finding things that I'm missing or weren't needed in the first place. I'm going to leave out the cost of any C64 stuff (SID, PSU, case, etc.) since the prices on those can vary. I'm not sure what I'm missing and what I don't need that I listed above. -I have no idea how the control panel is set up -Because of the cost of a machined front panel (over $200 everywhere I looked), I'm actually going to make the panel myself with a drill, a Dremel tool and a file (for the LCD slot) and use acid etching (with help from someone who has done this before) to make my front panel. Is there a recommended thickness of the aluminum for the panel? -I'm planning on having this hooked up to a keyboard that doesn't have a sequencer, should I just go with a single SID chip or is there any use for multiple SID chips when there is only one device controlling it? I was thinking of making a separate MB-6582 unit if I ever get a sequencer. -I actually had this interesting idea in my head where I find an old dedicated MIDI controller keyboard or broken keyboard (with enough room for a modified front panel), find a way to fit the MB-SID stuff in there and wire it all up and have it look like a standalone unit. Any recommendations on how this would be done? Or am I the mayor of Crazytown? (This would be a later project and would probably be a mix of multiple DIY MIDI controller and keyboard kits, still researching this idea just wondering if anyone can point me in the right direction)
