SiliconHeaven
    40
Everything posted by SiliconHeaven
  1. Thank you! They arrived!
  2. What do you think about this project? I may back it just to sound like a Dalek, EXTERMINATE! :-D http://www.kickstarter.com/projects/2006771911/the-arduino-dsp-shield?ref=category
  3. Ich werde die Suche fortzusetzen. Ich kann diese Informationen auch bald brauchen.
  4. Ich haben nicht gesprochen deutsche ein neun Jahren. :-D But I think you are searching for these? http://www.pbe-shop.de/shop/448.html
  5. :-) Thanks for sharing. It makes me feel better lol. I have learned not to get too excited to finish a project.
  6. LoL I went thru the entire troubleshooting guide at http://www.ucapps.de/howto_debug_midi.html and couldn't find problem. Frustrated, I went to take a shower and it struck me. After inserting PIC18F4685, I was too happy to load the Firmware. I forgot to insert 6N138 into IC2. Bingo! Firmware loaded with no problems. Im having trouble uploading content to my gallery. Once i get my video uploaded, ill share it. Onto the next DIY....
  7. Problem solved!!! Wooh Hooh!!!! It's time to celebrate!!! sammichSID complete. LoL
  8. still no luck with it
  9. Getting MIOS uploade now. Maybe that will help.
  10. Thank you very much! At least yours is working lol. I'm still stuck. :-) good times tho....
  11. New Question: So I am done with my build but I have run into firmware problems. I connected midi in and out. Turned unit on and got the midi in address. When I press "Query" nothing happens. Red text appears. I tried to upload MIOS and another red text appeared saying there is no core. Suggestions? I've tried a majority of the midi debug test and checked all solder joints a lot of times.
  12. Oh yes I will. nothing will stop its build! :-D I am addicted to midibox. :-D
  13. Q-P by any chance did you take pictures of your completed PCB's? Or anyone else. Would you mind posting them if you did? Honestly, I would like to see if I'm doing things right. Especially the bits with the LCD. :-D
  14. nILS thanks a lot. :-) 1: thanks eases tension. 2. Damn it cracked just a tiny tiny bit where the ceramic starts. So I'll order a few more. There goes building before tonight lol. 3: you lost me. I know I know. Noob....but that's a good thing....to me at least. I'll look up little more and than ask I needed. I'll do what I did for the GND/5v test I did lol. 4: I will take your answer as, I was right and it's up to me to decide. ;-) Thanks for designing the board. I know, no kudos. I'll send a beer when the wife ain't looking.
  15. Greetings! This is place is awesome! I am currently working on a sammichSID and I have a few questions. I would like to continually post in this thread as I go. Just a heads up my electrical and soldering experience are zero, but that hasn't stopped me before. 1. I noticed ceramic capacitors have 4 holes. "EG: C7L & C7R" I chose to attach them to the PCB using the outer sets of holes. I accidentally filled some of the inner and outer holes but never bridged sets. Is that okay? Should I fill all 4 holes of each capacitor? 2. I bent some ceramic capacitors as I was building. Should replace them? LoL how do I check for errors on my part? 3. I soldered a 6 pin Common Bus resistor where the machine pin strip (6 pins as well) goes into C1R and C2R. It took 2 hours to get out, LMFAO but what's a good check to make sure I didn't ruin anything. 4. I swear I read somewhere if I wanted,mono in and out jacks, I would need to remove pins 2 and 5 from the jacks. Is that correct? By the way I don't know how to use a multimeter LoL. I've just begun step 3 inserting rear jacks. I have this multi meter. http://m.radioshack.com/radioshack/product/detail.do?itemId=4214667&categoryId=1092594&path=Home%7CHobby+%26+Do-It-Yourself%7CTest+%26+meter+equipment%7CMultimeters%7CRadioShack%26reg%3B+15-Range+Digital+Multimeter Sorry for the long link. Wilba wherever you are, bless you. You added a extra 6 pin common resistor. How'd you know??? O-o
  16. SiliconHeaven
    1st SammichSID Build
    1st build ever.
