SkyRiderJavelin
    5
SkyRiderJavelin's Achievements
MIDIbox Newbie
  1. Howdy, I would also be interested in registering for the chips & pcbs..... I not in a hurry and happy to wait for the numbers to build before a order is placed
  2. Hi All, Happy Dayz...... Loaded V3 on Bootloader 1.011 By using my limping mutilated debug board to reload the bootloader Thanks Thorsten for your advice... much appreciated
  3. Hi Thorsten I originally installed with the window7 usb driver, after your advice I tried accessing it with another usb driver ie, windowsXP . XP called the device miosbootloader, but when I ran Mios Studio I get the same result... same range error . So now I will follow your advice with the debug interface. Thanks
  4. Hi Thorsten, Thanks for your prompt response. When I boot the core with J27 jumper stuffed, and then start Mios studio I get this message No response from MIOS8 or MIOS32 core! Check MIDI IN/OUT connections and Device ID! I have tried querying Device ID 0 to 16.... all same error message Then Attempting to load mios32_bootloader_v1_011\MBHP_CORE_LPC1769\project.hex On loading hex file I get this message Reading project.hex Trying to contact the core... project.hex contains 69064 bytes (270 blocks). Range 0x00000000-0x00010dff (69120 bytes) - PIC Bootloader (ERROR!) ERROR: Range check failed! I can't contact the core,I have tried unplugging cable then tried J17 power jumper then restart power on always same result. I am wondering if the bootloader is corrupt. When I restart with J27 jumper on the red light is blinking, I don't know if this indicates bad bootloader. The error message seems to point that way. Thanks
  5. Hi I am a stupid newbie, I loaded the lastest MIDIO128 V3 on bootloader 1.008 without upgrading the bootloader to 1.010 now Mios Studio cannot see the core. I loaded bootloader 1.008 on months ago and could connect to the core, I hadn't installed a application at that stage. I loaded the latest MIDIO128 V3 it seemed to load ok it had 1 error/warning that said it was able to solve it by itself It seemed to take a while when I was waitng for it reboot. I closed down Mios studio and restarted. Then was not able to see the core I have tried a jumper on J27 to disable the application, but still cannot see the core. I don't know what to do next can anyone please suggest how to upgrade the bootloader to 1.010 Thanks
