fourfour
    18
Recent Profile Visitors
1,039 profile views
  • 2hb
fourfour's Achievements
MIDIbox Newbie
  1. Where do I put this file? I am not familiar with how to use templates? Thanks!
  2. Hey Duggle. I was thinking I needed something like this. Do I just replace my default NGC with this code?
  3. Here are all my files loaded on the SD. Archive.zip
  4. Hey everyone. I am having trouble getting Pro Tools to respond to my controller. I have it setup in Pro Tools as HUI, but nothing seems to work. Is there a setting I need to declare in MIOS for HUI Emulation? Or is that always available? Setup: LPC17 NG DIN Thanks! -eric (the attachment shows the MIOS in italics, I just had it unplugged when I did the screenshot)
  5. woot. @novski that was it! Again, thanks for the help everyone.
  6. It all seems to be hooked up fine. I just had some jumper wires laying around that I crimped some dsub connectors to. All those are passing current fine. Do you have to #include a NGC file for it to load? Or does it load every file on the SD?
  7. @duggle Ok, I tested all the connections. The clk, data and RC all beep ok from the core to the first shift reg. Thanks for your help.
  8. @novski I am following that 'first steps' tutorial
  9. Hey Spirit. Ya I get the voltage drop to 0V when the button is pressed. I have this in HELLO.NGC RESET_HW EVENT_BUTTON id=1 type=NoteOn key=36
  10. I'm stuck again :/ I am new to hardware dev, I come form the software side of things. I appreciate everyones help getting me off the ground. I have a DIN connected to J8 and a single button. I am trying to get the 'first steps' one button test to work. There is voltage and the button works. Am I correct that the button gets wired to ground and D0? I get a voltage drop when the button is pressed, but nothing happens in MIOS. Thanks!!
  11. Ok! We have liftoff! Thanks so much everyone.
  12. @duggle: I assumed they just mirrored J8 e.g Vs Vd Si Sc Rc I have some ribbons on order. The site didn't state that I needed to order them separately. Thanks for your help.
  13. @spirit: oh my, thanks for catching that. Unfortunately, that didn't solve the issue. LED still on all the time. I checked my wiring again over the whole board. (how do you send a beer?)
  14. Hey Duggle. I am getting voltage to the DOUT board, tried using J8 and J9. Here are some pics, thanks for your help!! https://s3.amazonaws.com/uploads.hipchat.com/14874/54948/jijmbr9a06d226i/IMG_9264.jpg https://s3.amazonaws.com/uploads.hipchat.com/14874/54948/szsbs0p7lz9nyxs/IMG_1599.JPG
  15. Hey Pete. Ya, I tried that already. I also tried setting individual pins to 0|1 and nothing happens.
