Hi John.
thanks for replying to my message and thanks for the advice.
I think you are right, I didn't realise that Midibox has changed so much,
but most definitely welcome the changes.
I think that new ARM MCU is much better and gives much more options,
not that I have much experience on MCU's or programming / electronics, however, I have read a book or two and taken a look
at the market and the ARM MCU's certainly appear to be very popular and have much more General purpose inputs and outputs
and memory.
which is really good for our purposes.
Presently my studio setup is fairly minimal, centred around an "In the box" DAW multi-tracker ( Logic Pro and basic Protools)
I also runs Virtual instruments, Native instruments for sampler / synths etc.
The plug ins that I plan to make control surfaces for are mostly ones used for engineering rather than creative or
composing, I would like to make control surfaces specifically for use during mix engineering. As not having a pro level desk is a bit of a hinderance during mix engineering and a tactile control surface for the plug ins that you use would give you the same control as the pro engineers have when mixing in a pro studio
on pro level equipment.
I presently favour UAD and waves plug ins for most of these types of jobs, although I do also like a couple of others from other manufacturers that I do not yet own. such as the newish lexicon reverb plug ins etc.
To start with, I perhaps should try to make a control surface for one of the more simpler plug ins (simpler in terms of how many buttons / encoders are required to control) and, if I can afford to, and still have the enthusiasm, I would like to perhaps make more complex ones for the other most used plug ins.
If the programming doesn't already exist, I perhaps would be willing to try and code this myself either in C or Arm Assembly language.
Although one step at a time.
Actually, at this point, having little applied experience, I would be pleased to be able to make a control surface for even the basic logic plug in sets,
just to see if I can. As long as it doesn't cost me the earth. and build on my experience and then move on to progressively harder projects.
But sticking with plug ins to start. :-)
As I said before, I have just finished a course in basic electronics and have brought a fairly good soldering iron that has a fairly accurate temperature control, which wont fry the sensitive components. So I now am looking for a way to use my new knowledge and think that perhaps Midibox is the ideal starting point, in that I can get hands on without having to do too much science but still can get my hands dirty with the practical and making useful things in the process.
Cheers
