wpatterson
    9
wpatterson's Achievements
MIDIbox Newbie
  1. Thanks so much! I will give that a try. Thanks, Harry Patterson
  2. Is there away to use an encoder to "scroll through" the sections of a NGR Script? Thanks, Harry Patterson
  3. Say I wanted to be able to use banks to control the color of the LEDs and 4 different banks within the same encoders but with different CCs. I know I could have use one encoder to scroll through each individual bank and the colors, but is there a way that I could use one encoder to scroll through groups of 12 banks and another encoder to change the color of the leds? For example: Encoder 1: changes the CC of each led via banks Encoder 2: scrolls through rgb banks of LED rings (the range would be 1 to 12) Thanks, Harry Patterson
  4. Thank you for replying so quickly! Also, do I still specify the LED_MATRIX_PATTERN the same way? for example: LED_MATRIX_PATTERN n= 1 pos= 0 pattern=1000000000000000 Thanks, Harry Patterson
  5. I am building a controller that will have 16 encoders with individual LED rings. Each ring will consist of 12 RGB LEDs (11 around the encoder and 1 below it). I want to use two DOUT modules to control them. The first and second SRs will send signals to the 12 cathode rows. The third and fourth SRs will send signals to the red anodes. The fifth and sixth SRs will send signals to the green anodes. And finally the seventh and eighth SRs will send signals to the blue anodes. I have included a schematic: Does anyone have any suggestions about programming this?
  6. wpatterson
    MIDI Box NG
  7. Thanks novski, I will try to get on the next bulk order!
  8. I have had the hardest time finding knobs for the Bourns PEC-11 Rotary Encoders. Does anybody have any suggestions? Thanks, Harry Patterson
  9. What do you mean by "add all environment variables as user defined build settings. (seehttp://www.midibox.o..._toolchain_core, all of these)"? Sorry I am new to programming Thanks, wpattersons
