                Posts11
Everything posted by GuitarNut67
	You Sir Rock! Thanks a ton. :)
	  Looking for help with NGC file (bank routing and layout)GuitarNut67 replied to GuitarNut67's topic in MIDIbox NG I found the "set_active" feature with Multibnk.NGR & .NGC examples. ...still confused but trying to work through it.
	The NG manual page: http://www.ucapps.de/midibox_ng_manual_ngc.html Has a bad link under the Banks category. "Please note that it's also possible to assign only a subset of controllers to banks, and to use the remaining hardware elements for dedicated functions outside the bank: Link to a configuration example." I could really use that example in my current project. Thanks GuitarNut
	I'm trying to build a Midibox NG interface for a guitar preamp. I have built the hardware consisting of 12 encoders, 3 toggle switches, 1 LCD, a few LEDS on a DOUT. I have 2 different DEFAULT.NGC files (representing Mode 1 & 2 Below) with Switch 2 banking encoders 1-8. The hardware is tested and working for each NGC file. :smile: I need to combine the code from both NGC files and add encoders 9-12 with banks of their own, responding independently of banks 1&2. (Is this possible?) I also intend to add Mode 3 to Switch 1 soon. This is how I want it to work: Switch 1 : Mode 1 => Switch 2 (banks 1 & 2 for encoders 1-8), Switch 3 (banks 3,4,5 for encoders 9-12) Switch 1 : Mode 2 => Switch 2 (banks 6 & 7 for encoders 1-8), Switch 3 (banks 8,9,10 for encoders 9-12) Switch 1 : Mode 3 => Switch 2 (banks 11 & 12 for encoders 1-8), Switch 3 (banks 13,14,15 for encoders 9-12) But I am confused on how to accomplish this. Should I use radio buttons, Meta events, can banks be inside other banks? Any help would be very appreciated. Thanks GuitarNut
	OK, Finally completed a second Breakout board, this time it worked! :smile: Must have messed it up while building it. Please disregard the graphic earlier in the thread. I incorrectly labeled the connector. I wouldn't want to confuse anyone. If TK could delete this thread that would be OK with me.
- 6 replies
		- sd card error
- ng
					(and 1 more)
					Tagged with:
	Ok, Good news I ordered more STM32F4 boards and they all react the same with my Core breakout board. I didn't fry the processor board. :) Bad news, Still have a non-functioning SD interface. I guess I need to remove the current SD Connector and start over.
- 6 replies
		- sd card error
- ng
					(and 1 more)
					Tagged with:
	Ok, I tried a 2 gig SD card with no improvement. :no: Triple checked the solder connections on the board and SD card socket these seem fine and, I was incorrect in my earlier post (I confused the orientation of J16 making me think I had a short between RC1 & RC2 it was actually Vs & Vs). Do you think I may have damaged the STM32F4 board by powering it up with an incorrectly oriented 74HCT541 chip? I'm considering purchasing another STM32F4 for comparison. Thanks
- 6 replies
		- sd card error
- ng
					(and 1 more)
					Tagged with:
	Thank you, for the quick response. Yes, I will try a 4GB card to see if that makes it happy. I did notice that the same errors occur when there is no SD card in the slot. I removed the STM32F4 board from the socket and made a continuity test for all pins on the SD card and where they arrive at J16. I notice some crossed lines in my test, I'm including a drawing showing my results. In my continuity test, pin 9 & 6 of the SD card bridge both RC1 & RC2, while pin 3 joins them at RC1 of J16. Is this a proper connection? Thanks
- 6 replies
		- sd card error
- ng
					(and 1 more)
					Tagged with:
	From the album: GuitarNut67 SD card trouble Drawing of my continuity test on my Non-Functioning STM32F4 + SD Card Connector. View is from the top of the board looking down onto the pins and SD card slot.
	I may have messed up my STM32F4 board. I accidentally plugged the 74HCT541 in backwards while trying to power it up for the first time. No lights came on. I replaced both chips on the core module and got the boot loader and LCD working. I installed Midibox NG 1.032 but my SD card fails. :( From MIOS Studio 2.4.6 (here are the details) [319531.507] sdcard [319531.499] SD Card Informations [319531.500] ==================== [319531.500] ERROR: Reading CID failed with status -256! [319531.500] ERROR: Reading CSD failed with status -256! [319531.500] [319531.500] Reading Root Directory [319531.500] ====================== [319531.500] SD Card: not connected [319531.500] Failed to open root directory - error status: 12 [319531.500] done. I tried two 8 gig sd cards (one Ultra) format FAT 32. ========================== I checked continuity between the solder pads of the sd card before assembly nothing seemed to be causing a short circuit. Is there a way to trouble shoot SDCard or Connector and the STM32F4 board ? I couldn't locate error status codes while searching the forum. Thanks, A confused GuitarNut
- 6 replies
		- sd card error
- ng
					(and 1 more)
					Tagged with:
	Yes, any supplier information available?
