Mickael
    6
Everything posted by Mickael
  1. To control the midibox i will use generic remote in cubase or nuendo. A lot off configuration are possible. If you don't know it, looking on the web or to French: http://www.espace-cubase.org/page.php?page=appcubmr13
  2. But MIDIbox can be played with a MIDI keyboard in real time so normally it can follow. and when I press the mute button MIDIbox sending the signal to daw but also directly to the output. it is only during the reading phase of daw it sends the information directly to the relay and it does much more than once a second. fans my first try I have no latency and switches several times per second. but I did the test with only one button and one relay. For now it works well. I have not specified but the daw will be used only operating automation. another computer will be dedicated to audio spot.
  3. Relay replace switch on this shematic: http://www.sonelec-musique.com/images2/electronique_commutateur_audio_012.gif I use only the half of this shematic to mute the audio signal.
  4. Thank you Zam, My project is to build a 32 channels console with 10 automated buttons for each channels and with motorized fader for each. but that is 320 input and output, but with 1 card I can have only 256 input and output. So I need use a matrix or more card. The automation will be controlled by Daw like cubase. In addition to that I would like to include the subgroups mute and control (play, rec, stop, etc ...). So if i can use use several core, it's ok for my project.
  5. Hello, I am trying to build myself an analog mixer and I'd like to use the MIDIbox project to automate certain function of the console. I have some small questions suddenly I allows me to create a topic that will lead me to my idea to ask different problem than I can meet. Thank you in advance for your help. So I like to know if an LED matrix can be diverted to control relay? If this is not possible, can i use several CORE_STM32F4 card to increase the number of input output?
  6. Bonjour, je suis en train de me construire un console de mixage analogique et j'aimerai utiliser le projet midibox pour automatiser certaine fonction de la console. j'ai quelque petites questions du coup je me permet de créer un sujet qui me servira au file de ma conception à poser les différents problème que je pourrai rencontrer. Merci d'avance pour votre aide. Alors, j'aimerai savoir si une matrice de led peut être détourné pour contrôler des relais? Si c'est pas possible, peut on utiliser plusieurs carte CORE_STM32F4 afin d'augmenter le nombre d'entrée sortie?
