Hi everyone!
Just a quick update: after a good night of sleep, I found a bad joint directly connect to the RES# pin in the SID chip.
After fixing this, now I am able to complete successfully the "mbsid interconnection test v2" application, and confirmed that all SID pins have the correct voltage during the test.
Also, when I run the "mbsid_testtone_v3c" application I get a triangle waveform from the SID output, as expected.
However, when I run the "setup_6581.hex" I get only a "click" sound and the sysex message "f0 00 00 7e 40 00 01 f7" every 4 seconds. I tried to upload the other files from the "midibox_sid_v2_044", but the behavior is always the same.
Any hint or tip? Is the sysex message "f0 00 00 7e 40 00 01 f7" the expected behavior from the application "setup_6581.hex"? What does this sysex message mean?
Thanks!
