LambdaTon
    3
    2
LambdaTon last won the day on January 13 2018
LambdaTon had the most liked content!
Contact Methods
  • Website URL
    https://www.lambdaton.de
Recent Profile Visitors
LambdaTon's Achievements
MIDIbox Newbie
2
  1. Hey Antichambre, your project looks really great. I just looked briefly over the datasheet of the TLC5958 and now understand your problem with the multiplexing. Using a CPLD to achieve a precise timing is an interesting solution. At the moment I am thinking about building a dedicated step sequencer that is fully integrated into the DAW, but I am just in the concept phase. When things get more precise, I will definitely take a deeper look at your solution. Best regards, Sascha
  2. Thanks for the nice feedback. Actually, I first tried to implement it exactly like you proposed, but my BAM implementation always suffered from "randomly" appearing flickering. With my sketchy knowledge about MIOS32 and FreeRTOS, I were not able to solve this problem within an acceptable amount of time, such that I went the lazy way and used a separate Arduino Nano for the task, which I already had here lie around. But you are absolutely right, it should in general not be a problem to implement all of this with just the MIDIbox core. I think in my next project, I will go another way and use directly a specific LED driver like the TLC5958, since the feature set of this chip is really interesting. Sadly, they are just available in a SMT package, such that they could be a challenge for MIDIbox beginners. Best regards, Sascha
  3. Hey MIDIbox community, first of all I want to thanks everybody participating in this project, since utilizing from the MIDIbox project really saved me a lot of time. In 2014 I started working on my DIY MIDI controller LambdaControl and can now proudly say that it is finished. I designed and build LambdaControl to support me during my upcoming live performances. Therefore, the controller consists of 10 channel that are fully integrated into Ableton Live. Each channel consists of a volume fader, six buttons for clip selection, four rotary potentiometers for effects, and an encoder with switch button functionality (could be used to control a looping mechanism). The normal components like the potentiometers or encoders are simply scanned by using the AINSER64 and DIN modules with a custom MIOS32 firmware. However, the special part of LambdaControl is the custom 10x6 RGB button matrix (based on button pads from Sparkfun), which is completely integrated into Ableton Live like a Novation Launchpad. For this purpose I connected a separate micro controller unit (MCU) via I2C to the MIDIbox core, which drives the RGB leds and reads the button inputs. The matrix MCU (16MHz Arduino Nano) can produce up to 4096 different colors by driving the matrix with a combination of multiplexing and Bit Angle Modulation (BAM). The matrix MCU still uses the shift registers of the DIN and DOUT modules to connect to the matrix rows and columns. This works really stable in the given scenario, but my implementation has some drawbacks like a low refresh rate or a relatively high input lag for the buttons (more in the documentation). This problems can be easily solved by using a MCU with more power or using a specialized IC like a TLC5958. However, it was a nice challenge to do everything in software on a limited hardware. Moreover, the parts used for the matrix MCU were with around 4€ really cheap. Additionally, I written a so called MIDI Remote Script, which integrates the by MIDI messages controllable RGB button matrix into Ableton Live. The MIDI Remote Scripts are python scripts that Live internally uses to integrate the different commercial MIDI controllers. The following picture shows that LambdaControl can be selected as every other control surface inside Live's preferences. The other screenshot shows the red rectangle that Live is rendering to visualize the position of LambdaControl's clip launcher that can be moved up and down by using the encoder on the master channel. I decided to release all files under open source licenses, such that other people can make us of my work. First of all you can find a complete documentation with more information and pictures on my website. Then I created four repositories on github for the different parts: Repository for the hardware related files like the faceplate or the 3D printable case MIOS32 firmware for the MIDIbox core Matrix MCU Firmware for the separate micro controller that drives the RGB matrix MIDI Remote Script for Ableton Live that integrates LambdaControl into the DAW I hope this information can help other people with their projects.
