        jmp220478
                Posts7
jmp220478's Achievements
	Did you see the final link on the empress page which is in theory what Strymon are aligned with And further info - https://support.empresseffects.com/support/solutions/articles/1000229541-i-want-to-use-midi-with-your-midi-enabled-pedals-but-i-don-t-want-to-buy-the-midibox-what-are-my-op
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	The saga continues - more information about midi implementation was released on the Sunet support page - https://www.strymon.net/support/sunset/ so I mailed them again Strymon Support response when I asked about midi pin to TRS jack wiring We follow the same TRS MIDI scheme as Disaster Area and Empress. These do not simply wire the 5 pin DIN connections to the TRS; true MIDI data (post opto-isolator) needs to be sent into the pedal. TIP is MIDI IN, and RING is MIDI OUT. Our cables here have an opto-isolator in line, and can let you send MIDI into the TRS jack: https://store.strymon.net/midi-exp-cable/ Note that this cable is only one way, and won't let you get MIDI OUT. Another way to do it would be to get some kind of MIDI box to split the signal from 5 pin DIN to TRS: https://empresseffects.com/products/midibox2 https://www.disasterareaamps.com/shop/midibox The Empress box is nice because one port is bi-directional and you could use MIDI OUT of the Sunset if you needed it. Subsequently got this from another forum I raised this on .. I emailed Strymon support about the Strymon MIDI Cable and asked them about the cable trying to find out if they adopted the MIDI DIN5 to TRS A OR B standard which basically flips the pins 2&3’s polarity on the TRS Tip and Sleeve respectively. What I got back was neither! Strymon uses a proprietary cable. The support specialist attached this torn out drawing which is a schematic of the Strymon MIDI Cable. So I ordered the cable. Cost more than your average MIDI cable. But I have not regretted buying it now. Here’s a link to a picture. Sorry about what I used and the clarity:https://imgur.com/gallery/Md24LCE?s=smsThere are 3 resistors, a diode, and a 6N138 high speed opto-coupler IC chip inside a cylindrical capsule. One might think it is a ferrite bead but it’s not. So if Strymon has gone to this length to make this cable, there must be something that is not either compatible or reliable using just a straight-thru wiring scenario. Usually this kind of circuit is used to mate different voltages or to keep down interference. So word the the wise over seas who can’t yet get this cable, order the parts and make one somehow. Maybe wire it up on an in-expensive breadboard at least. BTW - This is only for input to the pedal. Apologies for super long post but for sake of completeness - I've added all details ; $64000 question now is how do I proceed as diagram looks like TRS back to Midi In flow ? I also found this which may help original post - whats going on in an empress midibox 2 => full design schematic https://empresseffects.freshdesk.com/support/solutions/articles/1000114016-i-design-build-guitar-effects-and-i-think-midi-is-rad-can-i-make-my-pedal-compatible-with-the-empres And further info - https://support.empresseffects.com/support/solutions/articles/1000229541-i-want-to-use-midi-with-your-midi-enabled-pedals-but-i-don-t-want-to-buy-the-midibox-what-are-my-op Heeeeeeeelllllllllpppppp :-)
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	thanks I was confused by the use of both midi in and outs to connect to the single TRS jack - hence asking for the qualification
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	Many thanks for feedback - the exp jack socket on the sunset ( overdrive / distortion unit ) controls volume / other parameters with an expression pedal and midi with their bespoke cable . With your solution - you are using the out and in of another pedal ie my timeline ? their cable is a single MIDI to 6.35mm TRS lead - enabling me to send midi info ex a programmable pedal board to the timeline => Sunset, otherwise all changes will have be from delay alone ( see below ) .. is there a way to do this without connecting midi out and in on the send device => Sunset ? currently I have Programmable Joyo pedal looper - single midi out => Strymon Timeline delay ( used for patch changes ) my ambitiion as above but Midi out Timeline => TRS EXP jack in Strymon Sunset ( patch changes to align with delay ) many thanks
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	@Antichambre @latigid on many thanks for your replies - one final question as there are two potential solutions for me to try - is there likely to be any risk to either my timeline of the sunset pedals if i get the wiring incorrect ?
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	I just want to use midi into Sunset pedal to access new patch feature - from what I can see ( novice opinion of course ) the cable is unlikely to carry active components ? would this be a simple wiring orientation ie if my reading is correct then pin 2 to trs jack sleeve ; pin 4 to tip? pin 5 to ring ? is there a need for resistors ?
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
	Newbie here on all things MIDI - but keen to learn .. I have a specific question to a new Strymon MIDI feature recently made available on their Sunset / Riverside pedals - and which uses a MIDI to TRS jack connection on their custom cable - unavailable in UK til late October and I'd like to use facility asap - googled and hence I'm here and looking for feedback based on your work above please - realise of course big ask from non contributor to date but any advice greatly received .. Strymon bespoke cable - is it possible to replicate based on information provided below ? info ex their site - On our pedals equipped with a 1/4? TRS MIDI connection (Riverside and Sunset), the MIDI data is received by the pedals from the TIP of this connection. When MIDI OUT or THROUGH is enabled on these pedals, the MIDI data is sent out of the pedal from the RING of the TRS connection. also - recommended interface units - which I dont want to buy as its more pedalboard real estate Disaster Area Designs – DPC Gen 3 Series, DMC Gen 3 Series, MIDIBox Empress Effects – MIDIbox2 nb - this is a question on a youtube posting Hey guys, could I hook up one of your drive pedals to the Meris MIDI I/O instead? Asking because I already have one of those. Yes, Riverside and Sunset will communicate via MIDI with any TRS MIDI box that sends signals to the pedal on the TIP and receives signals from the pedal on the RING of the TRS connection.? best regards and thanks in advance for any advice
- 69 replies
		- jack
- `control port
					(and 2 more)
					Tagged with:
