Hi Pilo, 7805 doesn't get any hotter then with 2*16 display. It seems that I wasn't precise enough. When I said pale I meant dots - I can see 'Received a DIN Event' but dots which are supposed to be black are too pale, almost impossible to see. Backlight, on the other hand, works fine And I've plugged regulated 6.5V after the 7805 (which in this case does not regulate anything), meaning that the PIC18F, 6N138, LCD, 4051, 74HC165 and everthying else is working on 6.5V. And if I keep contrast pot to the minimum, V0 is 0V so the difference Vd - V0 is 6.5V Hope someone could help me clear this mess Thanks dragon
