26 -
Everything posted by piku
ok ok :yes: the job is done
i'm trying to understand but with no success... could you explain exactly where do i decide the out channel? where can i find a table with the values for each channel? what i need now is the value to send all out to midi ch3...
thank you very much TK!!!!!!! :D
how can i modify the firmware of my midibox64 and midibox64e to send midi over channel 4 but receive midi (and so control the leds) on another channel?
ahahah well.. it's funny that it seems some kink of monologue but... i finally found the final solution i set two variables: unsigned char timerled[64]; unsigned char actualed; each time a note on i received , the corresponding led is set to ON and his timer is set to 0... then.. in the SR_Service_Prepare section: if ( ++actualed >= 64 ) { actualed = 0; } if ( ++timerled[actualed] >= 16 ) { MIOS_DOUT_PinSet(actualed, 0); timerled[actualed] = 0; } so each led has a fixed duration... thanks to the forum anyway!! ahaha :tongue:
mmmh .. ok i used some suggestions i found here: for now the leds of all my 8 shift registers are turned all off after 250 ms since the last note on received... i used a global variable called "timerled" ad every note on received it is turned to 0 and everytime it reaches 250 all led are set to 0 this is how the thing works void SR_Service_Prepare(void) __wparam { if( ++timerled >= 250 ) { timerled = 0; MIOS_DOUT_SRSet(0,0x00); MIOS_DOUT_SRSet(1,0x00); MIOS_DOUT_SRSet(2,0x00); MIOS_DOUT_SRSet(3,0x00); MIOS_DOUT_SRSet(4,0x00); MIOS_DOUT_SRSet(5,0x00); MIOS_DOUT_SRSet(6,0x00); MIOS_DOUT_SRSet(7,0x00); } } now.. i repeat i have no programming skills what i need now is a way to make the same work but for every single led i thougt i have to use a multiple variabe like " unsigned char timerled[64] " but do i have to repeat the "if" code 64 times???? is there an intelligent way to do this? i mean .. how do i have to configure the code for a multiple variable in the SR_Service_Prepare section??
i'm building a little light installation with leds controlled via midi i programmed the firmware following the C examples given by thorsten the problem is that sometimes some leds remain on due to bad midi transmission, since i'm using a wireless midi device (cme widi) i'd like to make the firmware able to set alwais the leds off after some seconds let's say .. a led doesn't receive his midi note off message, so it remain lighten, what i want some counter algorithm that turn a led off after 2 seconds. can someone give me saome examples i can follow? i have no programming skills!!
i had success with the c examples.. but it's too difficult for me to enable this kind of feature in mb64e firmware
how can i configure my midibox 64 and midibox 64e to turn on leds via midi and via buttons both? can someone build a special version of the firmware with this feature enabled? if not, please give me some general suggestion about the necessary code modifications thanks
i need to drive midi datas over critical cables with some nodes and extensions... can someone link some schemes to build balanced midi cables?
Hi all. I'm building a quad sid box. i need to know if is possible to connect 2 midi in to the master core. Do i need an external midimerger? I'll try to explain: I've got an half broken midi controller... I want to put two octaves of keyboard and the mod and pitch weels directly inside the box (i found a nice and large box for electromedicals for 10€!!). the midi keyboard has inside an ATMEL controller that translates all the analog inputs (of the keyboard and the weels) in midi messages on the midi channel 1. i know that my idea is such a prehistoric solution :-/ but... i'll set the sids to recive midi messages from the channels 2, 3, 4 and 5... while the incoming data from channel 1 (the internal keyboard) will be "routed" to the desired sid by the master core. Questions: Do i need another core to put two midi IN (the internal keyboard and the midi in) into the master core? what is the programming language for pics? How can i make a code that allows the master core to change the channel of the internal keyboard to 2, 3, 4 or 5, and to change the the cc's assign of the pitch and mod weel, or to change octave to the internal cannibalized keyboard?????? the midi keyboard has a control fader that sends cc messages n7 (volume control), i could filter it's midi messages by the master core to control (for example) the cutoff or the resonace control of the SID n3 that recives on the channel 4... How can i add some switches connected to the master core to control the various modifications of the midi signal incoming from the channel 1? (example: a switch + - to change the octave or the midi channel) is it possible to program a procedure in basic or pascal or C language? Do i have to learn all about the assembly language? I think is enough :) Exuse me for my english... i hope somebody will open my eyes!!! Thanks
I want to use the 2 x 40 lcd for my quad sid box. I'll redraw the front panel off couse... but (technically) i would like to know if i can (and how) increase the number of swithces under the lcd. Thanks
i think that a "stupid" answer is better than philosofy in this case... 8) * another answer: if i mount a 2 x 40 lcd on my quad-sid-box, there will be problems of firmware compatibility? * how a firmware is "written" on the pic? What kind of cable i have to use? how can i connect it with the computer?
What is the name of the italian "bromografo"? Is the machine that allows you to create Pcb's, by exposing the boards to his UV reys... I want to search one on ebay... but i don't know the name!!
10) Can someone e-mail me some detailed photos of the connections and sections of the 4-chip-Sid-box?
:-[ I have an humanistic education...
2) what use is the midi out connection? 3) Can i download the bankstick memory into mt computer by the midi out connection? 4) Is possible to probram the wave tables without a comuter, directly by the control panel? If not, how can i program a "complex" wavetable texture and save it into the bankstick memory of the sid-box? 5) where can i find infos about the "midi thru" circuit (tha i would like to insert in the sid box)? 6) can each Sid chip play a different patch? 7) have i to load patches on the sids everytime i turn on the machine? or is possible to keep a cofiguration for all the sids even when the machine is turned off? 8) is possible to load a patch while playng? On the sidstation is possible... 9) where exactly is located the "brain" of the 4chip-sid-box? in the PIC of the master core? Every pic of every core is programmed in the same way?
how many PCB i have to create for the 4 chip Sid-box??? 4 sid 4 core 3 din 4 dout 1 ltc (for midi in\out leds) 1 jdm (for programming my pics) total 16 PCB is that right?
Where can i find good knobs for building my Midibox SID? I'm searching for the old '70 style knobs. Another question: is there a difference between a pot and a rotary encorer?
:D I have found out the hot water!!!
mmmmhh... you're right
is possible to realize all this crazy things with vectorboards? P.S. i'm not sure about the meaning of the word "vectorboard". is the full of little holes one that i see in the gallery of the step c? right?
Another questiooooon!! Besides the multigate i would like to insert in the box a mini mixer for the stereo outs... There would be 6 audio outs in the box i dream :P : 4 outs are the direct mono outs of each sid and 1 stereo out is the main, in wich each signal coming from the sids passes thru the volume and pan knob to be placed in the stereo imagine. Can anyone tell me where can i find the "simple" circuits for a minimal mixer like the one i imagine? I think all the pan and the volume knobs (and even a possible "main volume" knob) could find placed on a modified and extended front panel... What are the complications about the alimentation of these other circuits? Is it possible to put an alimentation system directly inside the box??? ::) HOW?
If you look inside a c64... you will notice that the metal cover of the board presents three little "tongues" (i don't know the word in english) that are in contact with che prinicipal processors and even with the sid chip. This is clearly an expedient to "refresh" the chips. So, i think that a security measure (like the metal cover) is necessary for a long life midibox sid! 8)
Ehmmm... Excuse me.... :-[ What is a PSU??
