xcoulonx
    15
Everything posted by xcoulonx
  1. fader Alpha chez Mouser : http://www.mouser.com/catalog/627/536.pdf'>http://www.mouser.com/catalog/627/536.pdf http://www.mouser.com/
  2. c'est ceux de Smash TV, avec poussoir intégré.
  3. Ok merci, j'avais fais ça mais avec un encodeur "detented". du coup impossible d'acceder à certaine fonction. je vais essayer avec un "non detented".
  4. Hello Midiboxeur Je n'arrive pas à configurer correctement mon datawheel pour une MB64, J'ai fait les modifs dans le main.asm, connecté l'encodeur sur pin 4 et 5 (la place de l'ancien snapshot et left), Mais je vois pas trop quoi faire avec le mios_table.inc. Quelqu'un a une idée. Un big merci Fab
  5. Well, I've found the solution. My mb64_meta.inc file was Ok. But when i upload the Syx file with Midiox, i don't understand why, but I have always the An1 sysex. I upload the same Syx file with sysexbox_18f and all is OK. Silly isn't it ??? And of course all my midi connections are right with Midiox. Thank you Serge for your very good Tools. And F**ck you Midiox ;) fab
  6. Quand on programme le pic , faut-il charger le programme Hex dans la fenetre Program Code seulement(avec Open file), ou bien faut-il également le charger dans la fenetre Eprom Data (Open data file). Fab
  7. Yes it's the MB 64. I've don't modified the mb64_midi.inc, I've seen it but can't find the Meta_send_AIN1x_sysex string. I configured a meta file for relays with midio128, and all was Ok. But with sysex and MB64.....no chance :-/ Fab
  8. Yes, yes of course.
  9. Hello All I configure my Meta event file with XG sysex and assemble it with MPlab, but when i control what I send with Midiox it's always the AN1 sysex ??? I've tryed with another Meta event file found here (for Mks 80) and it's similar re.????? Is there another file that the meta.inc to be configured? Fab
  10. Just received my order and the answer is : YES.
  11. ok, i did it. I don't need more assistance. ;) fab
  12. I would like to send from 1 to 8 program changes with 1 button on my MB64, to control 8 relays with Midio128. Can you help me to write the file mb64_meta.inc cause I don't understand anything with the meta vent. Many thanx for your help. fab
  13. Hello When I send a program changes by a key, I would like that the LCD lets show the n° of program. It, but very briefly... is this does it possible? and how? NB: the sending of Prg Chng by potentiometer is on the other hand very visible, one sees very well what one with fact but it is less practical than a key :) Thank you for your answers fab config : MB64 + pic18F
  14. xcoulonx
    Midio128
    Hello Hello Je voudrais configurer Midio128 pour que lorsque je lui envois un program change il pilote indifferament 1, 2 3 ou 4 relais (ou plus...128 ) sur 1 même n° de program change. Je vois bien comment faire pour :1 relais par 1 N° de prg chnge, mais pas pour plusieurs relais. En fait, aujourd'hui, pour faire ça j'utilise le Midi Program Change de Tom Scarff qui est completement programmable : http://tomscarff.tripod.com/prg_chx8/program_change.htm Et je voudrais le remplacer par le Midio . Merci pour vos réponses Fab
  15. Bonjour Lorsque j'envoie un program change par 1 touche, j'aimerais que le LCD laisse afficher le n° de program. Il le fait mais très brièvement...Est-ce possible ?et comment ? NB : l'envoi de Prg Chng par potars est par contre très visible , on voit très bien ce qu'on à fait mais c'est moins pratique qu'1 touche :) Merci pour vos réponses fab NB2 :config MB64 + pic18F
