hello, i'm a new midiboxer and also have received a handful of SmashTV's new PCBs. I have a modular analog synth that is mostly kit-based, with modules from several different manufacturers. for the most part, these are luxurious boards with thru-hole plating, solder mask on both sides, and plenty of room between parts... they make construction very easy, and perhaps limit me somewhat in becoming a better solderer for that reason ; } anyhow, i was really thrilled to see the improvement in the 2nd-generation SmashTV boards. still, my batch had some issues. the most critical was that one board's traces did not align properly on the PCB, so that most pads did not encircle the thru-holes. this makes for a really sketchy connection. on two other boards, the topside clearcoat extended to cover up many of the thru-holes. not too big a problem, just use something to open them up again. finally, i was also disappointed that many of the parts did not have room to lay flat on the board - there is no way that the standard xicon 1/4-watt resistors i'm using are going to bend to fit flat. but again, not really too much of an issue. unrelated to the boards, and equally my fault for not recording them, are the few part errors that exist in the parts sheets, at least among the core and SID modules. again, i should have made note, because i can't remember now which ones were wrong. i do remember that the bridge rectifiers seemed like massive overkill - with thurston's spec calling for 40V/800mA, and SmashTV recommending 800V/1500mA parts. still, a big thank-you to SmashTV for offering the boards, guides, and service in the first place. soggy
