Thank you Thorsten! I proofed the wiring between sid and core modul again, and as usual, something was wrong (i flipped 2 cables), now it should be ok. (checked it twice again) During an constructive accident with a screwdriver, that got connection to the metall top at IC3 of the core, i recogniced the LCD was getting back it's luminance... so i connected something to cool IC3 and finally the LCD works without trouble (very hot IC3). Is that ok for IC3? Maybe i have to connect a DINX4 first, to get the random data away, and sound out of my sid... because when i start the sequenzer, the random data stops as long as the sequenzer is active, but i'm not able to change the values on the display by MIDI... The LTC Modul recognices the MIDI data very well, but no sound if notes are played. (i use the Logic Environment) strange... I wanted to check the connection with mbsid_interconnection_test, but it's impossible to get it running with SYSEX librian to upload the .syx file. Perhaps the upload will work with the sequenzer... I'll try out because i cannot use the MIDI-OX program. Actully still no sound :'( Do i have to change something in the syx file or is it still a problem with the connection... It transmits some kind of MIDI, and is able to receive MIDI... so i think no MIDI problem... Thank you for help, but i'm shure, i neeeeeeed more... :-/
