redhead
    5
Everything posted by redhead
  1. Hi Thorsten, I only need this function for making fast volume groups, cause for channel panning i know that isn't very useful... You think this will work? Looping LC_ENC_SendVPot for the selected channels you think i can get an immediate response from the "grouped" motorfaders? The "incremented value" will be added to the current value of the motor-fader ONLY for the selected channels?? I'm just a sound technician, and i know that my idea can appear "unuseful" but when i have to arrange a drum-set volume fader by fader, making attention to increment every channel the same value, i think that such function could really help me :) Thank you again for helping me with this :) redhead
  2. Hi Thorsten, thank you for your quick reply! Currently i'm using Ableton Live 4.0, wich unfortunately don't include a grouping function... I wanted to create such function ON the MidiBox because of that... My project include also compatibility with Protools, wich includes the grouping function... (BankSticks)... I think that giving to a rotative encoder the possibility of incrementing the selected value (pan - volume) of the selected channels, the function can be created, but i don't know "how", and it's not a little particular... Could you tell me if it's possible to create such function ON the MidiBox? Sorry for the bad english and thank you very much for the support :) redhead
  3. Hi all, i am on my first project, and i would like to create a dual Midibox LC with a master Midibox LC... i wanted to add a function for "incrementing" the value of selected channels by moving only ONE fader or pan, a "such fast grouping" function ON the Midibox... I think i have to send the increment to the other channels by their DOUTX4 module, but i have no electronics experience/cognition and i'm a little bit confused... Someone has tried doing this before? Could someone give me some useful hint? Thank you ;D redhead
  4. Ciao a tutti, sto pianificando di costruire un "semplice" midibox come primo progetto... Il mio progetto è composto da: - 17 fader motorizzati (16 canali + master) - 16 rotary con ledring per il pan - solo, mute, rec enable, select per i 16 canali - bank select (1-16, 17-32, 33-48, 49-64,NEXT) - comandi per Transport (play, rec, stop, ffd, rew) - un display per il timecode (hh,mm,ss,ff) - un display (o diversi) per vedere la channel label e lo stato dei parametri mentre li si modifica... - compatibiltà Protools - Ableton Live Non avendo molte cognizioni di elettronica, ho un po' di confusione sui moduli che devo usare... in teoria avrei bisogno di: - 2 Midibox LC (8 fader motorizzati, 8 pan con ledring, solo, mute, rec, select e display - per ognuna) - 1 Midibox LC (1 fader motorizzato "master", controllo dei faderbank slave, transport , display per MTC) e Banksticks per la compatibilità Protools - Ableton Live... DOMANDE: Come posso collegare insieme i moduli CORE per avere la possibilità di comandarli dalla Midibox "master" (controllo dei fader Banks)? Qualcuno conosce le differenze principali tra i messaggi che vengono inviati a Protools e Live? Il vostro aiuto è molto gradito, se non vi rispondo è perchè sarò al manicomio ;D Grazie a tutti, redhead
  5. hi everybuddy, actually i'm working with a Motu micro lite 5x5 midi usb interface. i'm very happy with this>> fast, reliable, mac/pc compatibility check it out :) ciao
