Glennzone
8 -
Everything posted by Glennzone
Hi sparkys, I have designed a MIDI interface in Flex/Flash (AS3) for the purposes of storing and sending MIDI Program Change commands, with single channel presets as well as multiple channel presets. I am in the process of researching the components, etc. for this project, and I would appreciate some guidance. From what I can tell, the STM32 is the way to go because I do want to connect both with a computer, and to multiplex several other MIDI controller devices I am designing to follow this current one. My design specifies that MIDI will return to the computer via USB. The components I need for this interface are as follows : 56 buttons (backlit when selected, hopefully, or at least some indication) 1 slider (rheostat) 1 4x40 character blue LCD Display 4 red LEDs For this, I am under the impression that I will need to following modules : Core32 DIN DOUT Because this MIDI Controller is only one of a suite of devices I have designed, I am also considering the MBNet TK has alluded to on the uCAPPS site. Any thoughts or suggestions would be appreciated. I've been poring through the 1200 page Mouser catalog, but my eyes glaze over after a period of time. :-P Thanks, Glennzone
Oh, I found lots of buttons. Just not the ones I've been looking for. I may have to design my own (128 new subassemblies ! ! Yuck !) I don't know. I'm thinking I need three separate buttons for each 1 clip (pattern) as record (MIDI ch1, note x with red LED illuminated)    play (MIDI ch2, note x with green LED illuminated)    stop (MIDI ch3, note x with no LED illuminated) . . . Times 128 ! How do I wire up something like that ? Can I actually use 1 momentary switch for all three conditions with two LED's in the circuit? (multiplied by 128 for each button in the matrix ) I see three-state rocker switches which seem like they could do it. I just don't know whether these three states will be able to trigger 3 MIDI events. I'm at a loss. If I could overcome this lack of foresight (regarding the switches), I think I would be able to begin. Thanks again TK, Glennzone
Thanks TK. I have downloaded all the files and will peruse them. I need to find my little clear rectangular button switches. I have downloaded and looked through the whole Mouser catalog, but don't find what I'm looking for, though some things could be ok for "sloppy seconds". I have seen them many times before, particularly on aircraft (I used to work in the aerospace industry). I'll settle with anything that will yield the same aesthetic results. Any input there would be appreciated. I am certainly learning though ! ! Thanks again ! Glennzone
Vielen dank TK, This is good news. Perhaps you could tell me where exactly to find these things you reference? I don't see any search tools on the uCapps site for these references. I have also been failing at my attempts to locate the clear plastic switches I want. Then there's the question of the red and green LED's. Are there switches with those types of things already built in ? Where could I go with questions such as these? I'm getting the feeling that a MIDIbox64 is more than enough to handle this (and the rotary encoder for tempo). If so, do you think I could realistically go about incorporating flying faders as a next step? I just don't know if I'll need anything more than the MF module. Either way, I will be taking it one step at a time. First, the interface with the buttons and rotary knob. Thanks again, Glennzone Let me know
Thanks Twin-X for the reply. I thought my description of the interface was already pretty complete :   "There will be an 16 x 8 matrix of clear plastic push buttons (16 across, 8 down). Each of these buttons will have three states indicated by a red light (Record), a green light (Play), and no light (off). My thinking is that each of these buttons can trigger a simple note-on command for each state (3 MIDI channels, 1 for each state, 128 MIDI notes for each of the 16 x 8 buttons). This can serve to control the clips in Live4 due to the excellent MIDI mapping functions in Live4. A readout would not be necessary because that would already be reflected on the computer screen. It would also be great to have a continuous rotary knob to control tempo. Does anyone understand my design logic? :-) " The idea of this interface relies wholly on the key and MIDI mapping features of Live4. It is a beautiful implementation. So here's a deeper look at my vision : The bottom line I guess is that the physical interface will be a representation of 16 tracks in Session view having 8 clips in each. If you have everything coming from a clean start, there are no lights illuminated on the little clear rectangular buttons. 1. If you hit the track 1, clip 1 button (upper left-hand corner of controller) it illuminates red (LED), and immediately puts that clip in record mode and begins recording. Technically, Record messages are sent over MIDI channel 1, one of notes 1-128 for a duration of about 250 ms, then note off. 2. Hitting it again, the pattern (clip) stops recording, and turns the button to green (LED) indicating playback. Technically, Play messages are sent over MIDI channel 2, one of notes 1-128 for a duration of about 250 ms, then note off. 3. Hitting that button again de-illuminates the clear button (LED) indicating that the pattern (clip) is not playing back at all. Technically, Stop messages are sent over MIDI channel 3, one of notes 1-128 for a duration of about 250 ms, then note off. By using this type of an interface you can start multiple clips recording at once, and at the same time. The reason I like to do things this way is that I have static tracks in Live4. Each track has a specific input going to a specific output, most of which are MIDI using VSTi's. I can then take that track (and others) and bounce the audio out of those MIDI tracks into another track which takes the audio from the MIDI tracks (like a group mix by musical section) Now, in Record mode, where exactly these tracks start recording (in measure or beat) depends upon the setting in Preferences for that function. That's all I can include for now . . . I'm at my "real job !" Thanks again, Glennzone P.S. I will definitely be taking a closer look at the sites you specified over this weekend and coming week. Being a single father, my child is with me all the time but for a week per month (when he's with him mom.)
Not a single response from anyone. Something's not right. If someone could give me an idea, I would appreciate it. Is the MIDIbox64 going to be able to handle that ? Do I need something more? I would appreciate even a single response. Thanks, Glennzone
What do you guys think of this MIDI interface?
Glennzone replied to bodimix's topic in Design Concepts
Actually the referred to movie was Minority Report and with Tom Cruise. I don't recall the Bourne Identity as having it, but I could be wrong. Thanks, GDR -
Hi all,    I have been an electronic tech in the aerospace industry, studied BAL Assembler, and C in college, and I'm now a Systems Engineer. I have for the past 20 years or so had a dream that I am on the threshold of fulfilling, and I believe the MIDIBox64 is the missing piece. I am looking for advice from those of you already working with these custom HW/SW devices to go about building my own. I will explain my concept, and hopefully I will get enough information in responses to set about facilitating this dream.   There will be an 16 x 8 matrix of clear plastic push buttons (16 across, 8 down). Each of these buttons will have three states indicated by a red light (Record), a green light (Play), and no light (off). My thinking is that each of these buttons can trigger a simple note-on command for each state (3 MIDI channels, 1 for each state, 128 MIDI notes for each of the 16 x 8 buttons). This can serve to control the clips in Live4 due to the excellent MIDI mapping functions in Live4. A readout would not be necessary because that would already be reflected on the computer screen. It would also be great to have a continuous rotary knob to control tempo. Does anyone understand my design logic? :-)   I can only guess at what I would need at this point, other than saying materials for the box, components, something to burn the EPROMs or whatever they're called these days, and the necessary software. I would Love to benefit from your experiences. I have other ideas as well, but this would be an awesome start.   Any help regarding the ways to go about beginning this process, through completing and finally using this device would be most appreciated. I don't know what kind of expectations to even have regarding this . . . how much will it cost, how long will it take, etc. Will I have to breadboard it first or is the logic so that I simply get things interconnected, and then write to the PROMs ? I will be trying to follow this forum more closely; this is very cool. Thanks for all responses, Glennzone
