.mag
    7
About .mag
  • Birthday 01/01/1
Contact Methods
  • Website URL
    http://www.magdesign.ch
  • Gender
    Male
  • Location
    switzerland
.mag's Achievements
MIDIbox Newbie
  1. no hurry, thanx anyway if just someone could tell me how to define the value ??? its maybe in mb64_lcd MB64_LCD_PrintValue andlw 0x03 JUMPTABLE_2BYTES 4 rgoto MB64_LCD_PrintValue_Hex rgoto MB64_LCD_PrintValue_PmHex rgoto MB64_LCD_PrintValue_Dec rgoto MB64_LCD_PrintValue_PmDec ;; print hex value 0x00..0x7f MB64_LCD_PrintValue_Hex movlw ' ' ; fill with space call MIOS_LCD_PrintChar movf INDF0, W andlw 0x7f goto MIOS_LCD_PrintHex2 hope to find a solution.... mios rocks!
  2. it dont have to be mb64, i used it because its easy to programm, leds work, knobs toggle.... but i need full cc# range! see files for more information: http://magdesign.ch/Files/MIOS/MultiControlProT.JPG http://magdesign.ch/Files/MIOS/Controllerzuweisung_Rev.A.pdf thanks so far.
  3. i just need for pot number 6 text values. i used a 12-way rotary pot, every single way is 10k any idea where to to manage the value tables? yes, i'm happy with my controller, use it for logic pro 7.1 and for live vj'ing. if anyone wants .dwg files of the case, pm me......... 8)
  4. hi qbas i already made a text display in logic environment and played with it over 2years, no i think its time to integrate it into my midi-box, just for feeling good ;) first of all it would be alright to get the text values for all pots, i tried it in mb64_lcd.inc, but it seems to be the wrong place, i'm searching the code which defines the numerical values. any idea?
  5. Thorsten, besten dank für alles! Ich liebe meinen Mios controller........a yea!
  6. hi ;D midibox 64 lcd menu display normaly prints the pot name and the value 0-127. so far this works. now i want to chance the number value to a text value, for example: when i move pot #6 (midi cc#118) for value 0-10 the display should print ES1, for value 11-22 the display should print ES2, for value 11-22 the display should print EXS, for value 23-34 the display should print EVOC, and so on.. where do i have to define this values, in mb64_lcd.inc ? thanx for any help, its better to spend hours behind mios than watching tv for hours ;)
  7. :) great concept!
  8. a case made of stainless steel and aluminium, cnc lasercuted..... massive and sexy 8)
  9. hallo thorsten, danke für die rasche antworten! LED: es geht mir nicht um den toggle modus, sondern darum wie ich die richtige led zum richtigen taster zuweise bzw. in welchem script ich das zuweisen kann. Display: könntest du mir sagen nach welchem befehl ich suchen muss bzw. wo ich einträge ändern muss? Logic: logic kommuniziert mit dem mackie/hui protokoll, habe schon bei emagic/apple schriftlich nachgefragt aber information dazu wollen sie nicht rausrücken. selbst beim service login auf mackie kriegt man 'nur' schemas und keine protokoll infos. danke!
  10. hallo nachdem die midibox(64) fertig konstruiert ist habe ich probleme mit der programmierung, habe das forum durchforstet um antworten zu finden, doch bleiben immernoch volgende fragen: kann mir jemand erklären wo ich änderungen vornehmen muss, damit zb. beim drücken des tasters 15 die led nummer 12 leuchtet und beim nochmaligen drücken die led wieder erlischt? wenn ich auf display page 4 einen regler bewege zeigt es mir den reglernamen und den wert an, ist es möglich bei einigen regelern den wert anders darzustellen? zb. controller nr.25 zeigt bei wert 0 auf der unteren zeile des displays "controller 25_ES1" bei wert 11 "controller 25_ES2" an. kann das mios mit logicpro kommunizieren? zb. die momentan aktuelle spur und das oberste plugin auf dem display anzeigen, erkennen ob die spur auf read oder latch ist oder sonst was? ich freue mich auf jede hilfe :)
  11. .mag
    Arkaos
    hi its really easy to build a arkaos controller since its possible to chance the controller numbers in arkaos. so you can use fix controller numbers in your box. actually i'm building a controller for my friends software visulator 2.5, it rocks! cheers
  12. .mag
    XY Controller
    hallo audioman ich baue seit einiger zeit in meine midiboxen joysticks zum steuern von cutoff und reso, ist voll geil! das beschaffen der joysticks ist relativ schwierig, da die meisten unheimlich viel kosten. bei pusterla in zürich kriegt man welche für ca. 20euro. gruss mag
