carlos
    4
Everything posted by carlos
  1. Hi, IMHO the polivoks could be commpared with ms 20, raw sound and good for fx. Aelita is something is more difficult to describe is also raw and sometimes subtle. the unison feature is great, On ruskeys.net you can hear some samples. cheers
  2. Hi guys, thx for the info!!, I was afraid i would get this answer... About the cv gate, I used that scheme from the creator (vladimir...) to install the midijack, it was an fairly easy task using the scheme so I can control the polivoks with asequencer. I also think the filter would be the easiest thing to handle since it uses (at the back of the polivoks) CV to control it. Concerning the ADSR (or the rest of the knobs on the synth...), I hoped it would have about the same logic as the filter (send a certain amount of voltage) so I guess not....damn :). It is just that I know of a guy (http://www.sms-audio.be/analogue/exp07sm.htm) that did it with an ms20 and others too and I thought it would be a bit more simple than what you described. About the PSU...you are right about that one...tuning is a disaster...i will change that it the future for sure if it is a lot of difference (thanks for the pointer!) Well I still dont know what i am going to do ,maybe I will give those people at smsaudio a try or ask how they do it :) Anyways many thanks!
  3. Hi, thx for the quick answer, I have a couple of vintage soviet synthesizers that I want to control with the computer. One of them the polivoks I had installed the synhouse midijack on and it works but still don't have control over other parameters. Another one the Aelita isn't midified yet but I want to try out this midibox if it will do what i think it could do, that is send control voltages to any parameter on the synth. So if I get this right each parameter has to be voltage controlled...could you give me a pointer no how to know if a parameter (filter cutoff, resonance filter adsr, vca adsr, vibrato, unison) is voltage controlled or not... can you measure it with a dmm or do i see it on the schemes? are there other possibilities except voltage controlled parameters? as you can see...a lot to learn :-) thx!
  4. Hi everybody, Totally new to this board and I do hope I don't ask a stupid question...I have searched this board and a bit of the specs of the midibox... My question is the following : Is it possible to control all the parameters of a synth like the filter resonance ADSR ... every pot that is on the board...and notes on and of of coarse. And if so could somebody give me a pointer how to start with it. The question is also if I can use the 8 CV on the midibox to control 7 knobs or sliders and the notes? or are there other solutions? anyways thanks for the time!
