Posts
474 -
Joined
Last visited
Days Won
4
Content Type
Profiles
Forums
Blogs
Gallery
Posts posted by Marxon
this topic is a bit older but i'm facing the same ID problem with my G540 programmer.
There is also no option in software to reconfigure the programmer so that only the first 4k block will be overwritten.
On 27.10.2013 at 8:21 PM, TK. said:It could be, that your programmer doesn't clear the ID bits - in this case, the wrong baudrate will be selected.
Since the baud rate is set COM, would it not be possible to upload the workaround somehow via a LTC module?
Thanks for your help.
Best regards
Marxon
Yeah the signatures are back again.
Aber kein Alkohol ist auch keine Lösung.
In plain english: But no alcohol is no solution, too.
Isopropyl Alcohol and a soft toothbrush also make wonders. ;)
I also tried Isopropyl but I could not achieve the same results.
Yes they look very nice!
The same button are also used in my Quasimidi 309.
But they are so expensive :(
This is my low-cost variant:
http://midibox.org/forums/topic/17186-yaib-yet-another-illuminated-button/
Best regards
Marxon -
Hi TK
I just wanted to buy you one or two beers and realized that
there is no "Buy TK a beer" button anymore.
Have you renounced the alcohol? ;)
Best regards
Marxon- 1
Hi all!
I am very sad becaused i missed this bulk order.
If someone changed his mind and does not want his 16x16 board anymore please let me know :)
Nevertheless have much fun with your boards!
Best regards
Marxon -
Damn!
I visit the forum regulary but missed this bulk order.
If there are any PCBs left i wouldt buy them instantly.
Best regards
Marxon -
Hi FantomXR
try if this works like you expect.
The channel select buttons will run a script (to activaon press
.NGC
#CH2 EVENT_BUTTON id=1 hw_id=1 type=Meta meta=runsection:1 range=127:0 button_mode=OnOff EVENT_BUTTON id=2 hw_id=1 type=Meta meta=runsection:2 range=0:127 button_mode=OnOnly #CH3 EVENT_BUTTON id=3 hw_id=2 type=Meta meta=runsection:3 range=127:0 button_mode=OnOff EVENT_BUTTON id=4 hw_id=2 type=Meta meta=runsection:4 range=0:127 button_mode=OnOnly EVENT_KB id=1 hw_id=1 type=NoteOn chn=1 EVENT_KB id=2 hw_id=1 type=NoteOn chn=2 EVENT_KB id=3 hw_id=1 type=NoteOn chn=3
.NGR
#CH2 if ^section == 1 LOG "CH2 deactivated" set_active (id)KB:2 0 endif if ^section == 2 LOG "CH2 activated" set_active (id)KB:2 1 endif #CH3 if ^section == 3 LOG "CH3 deactivated" set_active (id)KB:3 0 endif if ^section == 4 LOG "CH3 activated" set_active (id)KB:3 1 endif
Hi sprintf,
unfortunately it is not possible to mix display types.
AFAIK Hawkeye and nILS made a working SSD1322 and SSD1325 driver for theire projects.
If you really want to use different displays, you can connect them to multiple cores.
Hi Midiboxers,
while i was tinkering with my midiboxes i wondered if it would be possible
to use a Midibox NG to simulate a encoder. Something like an "encoder generator" simply by using a Dout board and a .NGR script.
Some quadrature encoder signal may could be generated like this:if ^section == 1 set LED:0 0 delay_ms 2 set LED:1 0 delay_ms 2 set LED:1 1 delay_ms 2 set LED:2 1 delay_ms 2 set LED:0 0 delay_ms 2 set LED:1 1 delay_ms 2 endif
I guess connecting DOUT pins directly to the encoder inputs on the destination device
requires some kind of adjustment but should work too?What do you think?
Is something like that in genaral possible?Best regards
Marxon -
Hi Novski,
thanks for your suggestion!
Your inverted range get me on the right path.
Last night I did not come up with the idea.
This is working:
### BUTTON PRESS EVENT_BUTTON id=1 hw_id=3 type=Meta range=127:0 button_mode=OnOff meta=runsection:1 ### BUTTON RELEASE EVENT_BUTTON id=2 hw_id=3 type=Meta range=0:127 button_mode=OnOnly meta=runsection:2
It allows to run two different scripts on button press and button release.
Until now i used a if/then statement in my .NGR script wich was probably not very CPU friendly.
### .NGC EVENT_BUTTON id=1 hw_id=1 type=Meta range=0:127 button_mode=OnOff meta=runsection:1 ### .NGR if ^section == 1 if (id)button:1 == 0 LOG "BUTTON RELEASE" else LOG "BUTTON PRESS" endif endif
Best regards
Marxon -
Hi TK,
would you please add also a "OffOnly" mode for buttons?
A way to start a ngr on button press and a other script on release would be just as helpfull.
Thank you very much!
Best regards
Marxon -
Hi Thorsten
You are genius!
After more than three years reminding you,
you come up with it without warning on a sunday afternoon. :)
I would love to test it right now unfortunately i am already on the way to work.
But it looks exactly like what i've wanted.
Really great!
Thank you!
Best regards
Marxon
Hi TK!
Is there still hope that the current instrument can be selected via NRPN?
Best regards
Marxon
Thank you Thorsten!
A friend has my first FM synth so i couldt not check how i wired it there.
I edited the cs_menu_io_tables.inc so that the pin order matches the "MIDIbox FM CS DOUT map" schematics.
(It is just a other pin calculation, so please do not laugh)
DIO_M_COL_ENTRY MACRO sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3, sr4, pin4, sr5, pin5 db ((7 - pin0) + 8*(sr0-1)), ((7 - pin1) + 8*(sr1-1)), ((7 - pin2) + 8*(sr2-1)), ((7 - pin3) + 8*(sr3-1)), ((7 - pin4) + 8*(sr4-1)), ((7 - pin5) + 8*(sr5-1)) ENDM DIO_M_ROW_ENTRY MACRO sr_in, pin_in, sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3 db ((7 - pin_in) + 8*(sr_in-1)), ((7 - pin0) + 8*(sr0-1)), ((7 - pin1) + 8*(sr1-1)), ((7 - pin2) + 8*(sr2-1)), ((7 - pin3) + 8*(sr3-1)) ENDM
There is also a writing mistake about the CAN bus pins in the setup*.asm files:;; if 1: pin RB2 and RB3 are used for CAN bus
;; MBHP_OPL3 data pins #2 and #3 have to be connected to PIC pin RB1 and RB2
;; (available at J5:A6 and J5:A7)
Correct is:;; if 1: pin RB2 and RB3 are used for CAN bus
;; MBHP_OPL3 data pins #2 and #3 have to be connected to PIC pin RE1 and RE2
;; (available at J5:A6 and J5:A7)Best regards
Marxon
Hi again!
It seems that the DOUT pins of the matrix get mirrored somehow.
In my Midibox FM i connectedLED column 1 SR 3 Pin 4 LED column 2 SR 3 Pin 5 LED column 3 SR 3 Pin 6 LED column 4 SR 3 Pin 7 LED column 5 SR 2 Pin 0 LED column 6 SR 2 Pin 1 LED row 1 SR 2 Pin 5 LED row 2 SR 2 Pin 4 LED row 3 SR 2 Pin 3 LED row 4 SR 2 Pin 2
but in cs_menu_io_tables.inc i have to define it:
DIO_M_TABLE ;; --> DIN <-- pins of the 6 column select buttons ;; Col1 SR/Pin, Col2 SR/Pin, Col3 SR/Pin, Col4 SR/Pin, Col5 SR/Pin, Col6 SR/Pin DIO_M_COL_ENTRY 3, 6, 3, 5, 3, 4, 3, 0, 3, 1, 3, 2 ;; --> DOUT <-- pins of the 6 LED columns ;; Col1 SR/Pin, Col2 SR/Pin, Col3 SR/Pin, Col4 SR/Pin, Col5 SR/Pin, Col6 SR/Pin DIO_M_COL_ENTRY 3, 3, 3, 2, 3, 1, 3, 0, 2, 7, 2, 6 ;; --> 1*DIN/4*DOUT <-- pins of the 4 row select buttons ;; DIN SR/Pin, Row1 SR/Pin, Row2 SR/Pin, Row3 SR/Pin, Row4 SR/Pin DIO_M_ROW_ENTRY 3, 3, 2, 2, 2, 3, 2, 4, 2, 5
Hi all!
I am a confused about the FM led wiring.
In the DOUT schematic the intrument and operator LEDs are connected to-SR2 D6 and SR D7.
It is not possible to change the pin configuration for these LEDs in „cs_menu_io_tables.inc“.
But here SR2 D6 and SR D7 are assinged to matrix Col1 Col2 instead.
Which configuration is correct?
Best regards
Marxon
Servus Midiboxer!
Der Titel sagt eigentlich schon alles :)
Natürlich gibt es auch eine Aufwandsentschädigung in Form
von Bauteilen oder Geld.
Mfg
Marxon
Now you have a similar situation like before.
Leave out the rgb parameter in the led event because it is already forwarded by the button event
and by what you said, it seems that the forwarded value has a lower priority.
Maybe the dimmed parameter conflicts with the rgb parameter. Try to delete the dimmed parameter
you have set the first DOUT shift register in your DOUT matrix and your DIN matrix.
Hi again!
TK, would it be possible to increase the number of patterns in a further NG update?
Best regards
Marxon
After i had recap the issue, I remembered having a similar problem in the past.
The solution is that each dout_matrix has always 16 entries.Hence it does not make sense to use all of the 16 pattern positions in my 8x5 matrix.So i changed led pattern.LED_MATRIX_PATTERN n=1 pos=0 pattern=0000000000000000 LED_MATRIX_PATTERN n=1 pos=1 pattern=1000000000000000 LED_MATRIX_PATTERN n=1 pos=2 pattern=1000000000000000 LED_MATRIX_PATTERN n=1 pos=3 pattern=1100000000000000 LED_MATRIX_PATTERN n=1 pos=4 pattern=1100000000000000 LED_MATRIX_PATTERN n=1 pos=5 pattern=1110000000000000 LED_MATRIX_PATTERN n=1 pos=6 pattern=1110000000000000 LED_MATRIX_PATTERN n=1 pos=7 pattern=1111000000000000 LED_MATRIX_PATTERN n=1 pos=M pattern=1111000000000000 LED_MATRIX_PATTERN n=1 pos=8 pattern=1111100000000000 LED_MATRIX_PATTERN n=1 pos=9 pattern=1111100000000000 LED_MATRIX_PATTERN n=1 pos=10 pattern=1111110000000000 LED_MATRIX_PATTERN n=1 pos=11 pattern=1111110000000000 LED_MATRIX_PATTERN n=1 pos=12 pattern=1111111000000000 LED_MATRIX_PATTERN n=1 pos=13 pattern=1111111000000000 LED_MATRIX_PATTERN n=1 pos=14 pattern=1111111100000000 LED_MATRIX_PATTERN n=1 pos=15 pattern=1111111100000000
Now all leds are scaled linear over the hole controller range.But one problem remains:There are still "gaps" at the cc values 26, 52, 78 and 104.Any ideas?
PIC18F4685 configuration bits ?
in MIDIbox SID
Posted · Edited by Marxon
Problem solved!
I found a tool called PICPgm which supports my old Willem parallel port programmer (the manufacturer software doesn´t support 18F4685)
and burned my PIC without any problems.
Have a nice day!
Best regards
Marxon
