talion
27 -
Everything posted by talion
Hi Thorsten, tried this and it works.... I already startet to read the "acmididefines" in the wiki to understand what this really does. My wish is to fully understand the code one day, so i can write real modifications and get rid of such dirty hacks :) But I just startet to learn assembler so it will be a long way .... but the idea of inox (little surface, maximum controll) is so nice, that i wanted to use his idea for my own purposes and customize the firmware for my needs. The problem with this cc-sending-hack for the joystick (especially with two joysticks/4 pots) is, that if you change the value of one pot, the USER_AIN_NotifyChange funktion causes all values of all 4 pots to be sent as cc... that looks like chaos in a seqencer :) But this problem I'll try to solve by myself - I'm going to try to safe the value's of the pins in some var to compare them each time USER_AIN_NotifyChange is called, so i can send cc only if a valuechange for the specific pot is detected. Long way but it's nice to know what i am doing ;) Greets, Chris
Hi, I used this patch to enable two joysticks in my sid: USER_AIN_NotifyChange ;; get 7-bit value of pot #00 movlw 0x00 call MIOS_AIN_Pin7bitGet ;; forward value to the CC handler ;; it expects: CC parameter number in WREG ;; CC parameter value in MIOS_PARAMETER1, so: movwf MIOS_PARAMETER1 ; save 7-bit value in MIOS_PARAMETER1 movlw 0x2F ; control CC #2Fh == Resonance call SID_CCIN_Set ; call function ;; get 7-bit value of pot #01 movlw 0x01 call MIOS_AIN_Pin7bitGet ;; forward value to the CC handler ;; it expects: CC parameter number in WREG ;; CC parameter value in MIOS_PARAMETER2, so: movwf MIOS_PARAMETER2 ; save 7-bit value in MIOS_PARAMETER2 movlw 0x2E ; control CC #2Eh == Cutoff call SID_CCIN_Set ; call function ;; get 7-bit value of pot #02 movlw 0x02 call MIOS_AIN_Pin7bitGet ;; forward value to the CC handler ;; it expects: CC parameter number in WREG ;; CC parameter value in MIOS_PARAMETER1, so: movwf MIOS_PARAMETER1 ; save 7-bit value in MIOS_PARAMETER1 movlw 0x48 ; control CC #48h == LFO1 Depth call SID_CCIN_Set ; call function ;; get 7-bit value of pot #03 movlw 0x03 call MIOS_AIN_Pin7bitGet ;; forward value to the CC handler ;; it expects: CC parameter number in WREG ;; CC parameter value in MIOS_PARAMETER2, so: movwf MIOS_PARAMETER2 ; save 7-bit value in MIOS_PARAMETER2 movlw 0x40 ; control CC #40h == LFO1 Rate call SID_CCIN_Set ; call function return ; and exit AIN handle and it works great.... i used this one and not the sid_ain.inc-thing because the display should not be touched at all.... but how can i make the joysticks make send CC's now? is there a way without changing or touching the cs? Chris
Project: little surface, maximum control... (updated 20 march 2007)
talion replied to Ixox's topic in MIDIbox SID
No problem... but the control-surface needs some enhancements because in my version the encoders are splitted over the shift registers - this wont work so easy i found out... and also the pcb's need some documentation because bridges and so on are not documented... when i'm finished with this i'll do all this and put the pcb's in the wiki... Chris -
Ok, i found out, that in your post was something missing: CS_MENU_ButtonIncDec_End ;; force a display update and exit bsf CS_STAT, CS_STAT_DISPLAY_UPDATE_REQ return this is needed by CS_MENU_ButtonDec1 and has to be added to the code.... Greets Chris -
Hi Ixox, nice work so far!! I've nearly finished my sid exactly like you describted it here. I made my own pcb's and realized this thing on only 3 euro-pcbs including sid, core, 4x bankstick, dinx5, doutx3, optimized c64psu and on-pcb-control-surface.... here some (crapy) pictures: [edit] after all of your changes in sourcecode applied: Error[113] C:\DOWNLOADS\MIDIBOX_SID_V1_7303B\CS_MENU.INC 1666 : Symbol not previously defined (CS_MENU_ButtonIncDec_End) Error[126] C:\DOWNLOADS\MIDIBOX_SID_V1_7303B\CS_MENU.INC 1666 : Argument out of range (-8993 not between -128 and 127) Error[113] C:\DOWNLOADS\MIDIBOX_SID_V1_7303B\CS_MENU.INC 1671 : Symbol not previously defined (CS_MENU_ButtonIncDec_End) there must be something missing..... [edit off] Greets Chris -
Danke, werd mein Glück mal versuchen :) Gruß, Chris
Hi, vieleicht ist ja jemand hier, der mit helfen kann :) Habe vor einiger Zeit eine Platine gekauft und will diese nun Bestücken, jetzt habe ich folgenden Konflikt: Die Trannis sind ja im Schaltplan einmal mit B-E-C und mit dem Dicken Strich, der laut Anleitung vorne sein soll, beschriftet - BEC und VORNE passen aber laut Datenblatt der Trannis nicht zusammen - was ist denn jetzt richtig? Der dicke Strich = vorne oder einlöten gemäß B-E-C Beschriftung? Danke und Grüße, Chris
so - alles geht nun: USER_MPROC_NotifyReceivedEvent ;; BEGIN --- control DOUT pins via Note events at channel #1 movf MIOS_PARAMETER1, W ; Note Off -> Note On with velocity 0 andlw 0xf0 xorlw 0x80 bnz USER_MPROC_NRE_NoNoteOff USER_MPROC_NRE_NoteOff bsf MIOS_PARAMETER1, 4 clrf MIOS_PARAMETER3 USER_MPROC_NRE_NoNoteOff movlw 0x90 ; check for Note On at channel #1 IFNEQ MIOS_PARAMETER1, ACCESS, rgoto USER_MPROC_NRE_NoNoteChn1 USER_MPROC_NRE_NoteChn1 ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 movf MIOS_PARAMETER3, W ; velocity == 0: off, velocity != 0: on skpz movlw 0x01 movwf MIOS_PARAMETER1 movf MIOS_PARAMETER2, W ; pin number: note number - 0x24, we start with C-2 addlw -0x24 andlw 0x7f call MIOS_DOUT_PinSet USER_MPROC_NRE_NoNoteChn1 ;; END --- control DOUT pins via Note events at channel #1 ;; process MIDI event call CV_MIDI_NotifyReceivedEvent ;; for best latency: branch to USER_Tick so that the new CV values ;; will be mapped immediately rgoto USER_Tick und: USER_SR_Service_Finish ;; ---[ handle with control surface variables (flashing cursor, etc) ]--- ;; Reset the first two shiftregisters of dout clrf MIOS_PARAMETER1 movlw 0x00 call MIOS_DOUT_SRSet movlw 0x01 call MIOS_DOUT_SRSet goto CS_MENU_TIMER so sehe die beiden modifizierten funktionen jetzt aus..... Wiki kommt - ich hoffe so klappt es jetzt. Grüße, Chris edit: allerdings kommt da gerade noch eine frage auf: wenn ich nun paare aus aout und dout haben möchte - sprich note c-2 über den ersten dout und dessen velocity über den ersten aout - wie funktioniert das ab dem zweiten paar? die douts hören ja nur auf die erste keyzone wenn ich das richtig verstehe - und die erste keyzone ist ja von c2 bis c2 weil der erste aout ja auch nur die velocity von c2 ausgeben soll - c#2 bis c#2 wäre dann die zweite keyzone für den zweiten aout - wenn ich jetzt nen c#2 spiele kommt das auch aus dem dout raus dann?
ok... einige probleme später - gestern machte ich den fehler im laufenden betrieb den midi stecker reinzustecken - spannungswandler abgeraucht und pic im arsch - gut, keller - neuer pic - neuer spannungswandler - diesmal ne andere taktik beim netzteil: der core hat jetzt nen eigenes mit 9v dc - spart ne menge hitze und den kühlkörper. dann test des aout's: geht nicht - dann habe ich nochmal die versorgungsspannungen getestet - alles ok - dann in der midibox cv mal den ersten cv ausgang auf cc gelegt und nen bischen geschraubt - siehe da - die max teile arbeiten einwandfrei - wenn ich rumdrehe ändert sich die spannung an den eingängen der tl074 - bei nem cc wert von 90 messe ich irgendwas um die 1,4 volt - scheint also alles zu klappen jetzt bleiben 2 fehlerquellen: 1. die tl074 haben sich beide verabschieded beim crash gestern - der pic ist ja auch über den jordan, kann ich mir aber nicht vorstellen, denn sonst wären die max auch kaputt gegangen 2. die tl074 arbeiten nicht richtig bzw. sind kaputt weil ich die mit 15v betreibe - ist aber auch blödsinn denn in alten synthies werden die auch mit 15volt betrieben naja bin jetzt etwas ratlos - habe auch keine tl74 mehr hier zum testen - nur 72 und 71 - schätze conrad hat die wie immer nicht da :( was mir auch noch in den sinn kam: ich habe ja jetzt zwei getrennte netzteile - ob ich die masse des core-netzteiles und die masse des +15/-15 netzteiles verbinden muss? im moment ist von dem +15/-15 volt netzteil ja nur plus und minus verbunden... ??? vieleicht weiß jemand rat.... das doutx2 mach ich dir fertig und schick es dir per mail - dann vergisst du es auch nicht - sind im grunde 2 fehler - einmal nen kurzschluss und irgendwas war mit der seriellen verbindung der ic's falsch ... ja das wiki mach ich auch gerne - sobald der aout läuft teste ich noch die 1ms erweiterung und schreibe ne anleitung dafür - deutsch und englisch - so kann ich wenigstens was zur sache beitragen :-) allerdings sollte man sich dabei nicht so auf die 909 fixieren - ich denke das ist bei allen analogen drums so - denn hallocinogen brauchte das interface ja für seine 808 - und ich teste auch nur mit der 909 kick weil die in einem gehäuse ist und ich nicht noch mehr kabel/platinen-salat auf dem tisch brauche :) Grüße, Chris edit: ok problemlösung war: die beiden massen müssen verbunden sein - dann klappt es auch mit den tl074 :) - weiter gehts mit der 1ms erweiterung
ok ich habs :) funktioniert - allerdings wurde ich etwa 2 stunden durch die fehlerhafte vorlage für das doutx2 aufgehalten - solltest du aus dem netz nehmen.... kein plan ob der rest nach meiner codeänderung noch geht - werde ich aber gleich noch testen und dann posten.... lustig ist auch, das ich zwar 5v habe wenn ich eine note spiele - aber aus irgendeinem grund kann ich damit nicht triggern *lol* - bedarf also noch ein wenig forschungsarbeit - hoffentlich hat es nichts mit der der dauer des triggern's zu tun, hallocinogen schrieb mir, das er einen impuls von 1ms benutzt - naja muss mal sehen, hab auch kein oszi hier im moment, sonst würde ich mal messen was aus der 606 kommt - damit klappt es nämlich wenn ich mit meinem finger den gate-in der 909-kick berühre kann ich sie damit triggern - nicht aber mit 5v aus dem dout - egal erstmal den rest bauen dann weiter testen.... Grüße- Chris
ok klappt auch nicht - naja jetzt habe ich noch ein anderes prob - der 7805 wird wegen den 18volt vom rinkerntraffo etwas "warm" *g* man kennt das ja - irgendwann bricht die spannung ein, so kann man nicht ordentlich testen - werde mal eben nach conrad fahren und nen kühlkörper kaufen dann noch mal was: ich habe vorhin auch einfach mal die normale midibox-cv anwendung aufgespielt um mich mal ein wenig damit vertraut zu machen (so gut es ging, in 5 minuten intervallen weil der spannungsregler ja immer versagte) - eigentlich muss ich doch gar nix einstellen oder? der code den du gepostet hast bewirkt doch, das bei einem note event auf dem ersten channel, der entsprechende dout getriggert wird- richtig? wenn ich also bei keyboard-zone als erste note C-2 einstelle - sonst habe ich auch noch gar nix konfiguriert - und dann ein c-2 spiele müsste also der erste dout getriggert werden, ooooder? :-) Grüße, Chris
so, der gesamte abschnitt bis zum nächsten kommentar sieht jetzt so aus: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when a complete MIDI event has been received ;; Input: ;; o first MIDI event byte in MIOS_PARAMETER1 ;; o second MIDI event byte in MIOS_PARAMETER2 ;; o third MIDI event byte in MIOS_PARAMETER3 ;; -------------------------------------------------------------------------- USER_MPROC_NotifyReceivedEvent ;; process MIDI event call CV_MIDI_NotifyReceivedEvent ;; for best latency: branch to USER_Tick so that the new CV values ;; will be mapped immediately rgoto USER_Tick USER_MPROC_NotifyReceivedEvent ;; BEGIN --- control DOUT pins via Note events at channel #1 movf MIOS_PARAMETER1, W ; Note Off -> Note On with velocity 0 andlw 0xf0 xorlw 0x80 bnz USER_MPROC_NRE_NoNoteOff USER_MPROC_NRE_NoteOff bsf MIOS_PARAMETER1, 4 clrf MIOS_PARAMETER3 USER_MPROC_NRE_NoNoteOff movlw 0x90 ; check for Note On at channel #1 IFNEQ MIOS_PARAMETER1, ACCESS, rgoto USER_MPROC_NRE_NoNoteChn1 USER_MPROC_NRE_NoteChn1 ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 movf MIOS_PARAMETER3, W ; velocity == 0: off, velocity != 0: on skpz movlw 0x01 movwf MIOS_PARAMETER1 movf MIOS_PARAMETER2, W ; pin number: note number - 0x24, we start with C-2 addlw -0x24 andlw 0x7f call MIOS_DOUT_PinSet USER_MPROC_NRE_NoNoteChn1 ;; END --- control DOUT pins via Note events at channel #1 kompilieren ging mit f10 glaube ich - mal sehen ob's geht - bin auf der arbeit und kann erst heut abend testen.... Gruß, Chris
ok die hardwaretestumgebung steht - jetzt das problem :) hab mir die sources von midibox cv geladen dann ein bischen gestöbert und mplab installiert (noch nie was mit assembler gemacht!) dann habe ich ein neues project erstellt und einfach alle dateien aus dem midibox_cv verzeichniss hinzugefügt dann ging es schon los: die original funktion die ich suchen sollte, habe ich auch gefunden - aber an welcher stelle muss ich den code da einfügen? einfuch in diesem label nach dem goto ... ?? ich habe keine ahnung.... zweite frage ist dann: ich kann die main.asm ja dann speichern - wie kann ich dann compilieren? einfach den wizard benutzen und immer ok drücken? Grüße, Chris
Hi, ich eagle mir gerade ein netzteil für den 808 clonne. den gleichrichter und den 7805 vom core lasse ich natürlich wech und integriere das einfach in das hauptnetzteil, welches also +15/-15 und 5v für den core liefern soll. jetzt die frage: der tl074 vom aout arbeitet ja auch mit +15/-15 volt - MUSS ich den wie in der doku vom aout mit +12/-12 betreiben oder kann ich den auch mit +15/-15v betreiben ohne, dass der rest des aout's "leidet"? Grüße, Chris
Hi Thorsten, sollte ja kein Vorwurf sein :) - verglichen mit komrz. MIDI-CV Adaptern ist das aout extrem leistungsstark und günstig. Hab auch einige günsdtigere dac's gefunden aber du hast schon recht, wenn man die auf 8 hochrechnet wirds auch schon teurer - und was auch stimmt ist das viele dac's sehr ungenau arbeiten, was vielen leuten aber auch egal ist da es "früher" ja auch ungenau war. nutzt man das aout aber für 1v/oktave sind gute dac's natürlich von vorteil. für meinen sid habe ich mir das lc halb (1channel) gebaut und steuere damit cutoff von einem externen filter - funzt auch zu 100% und das war extrem billig - hab noch nicht mal selected und es ist ok :) Gruß, Chris
Hi Thorsten, danke erstmal :) - ich denke ende nächster woche kann ich es testen. werd mich dann noch mal melden. zu maxim: hab da auch erzählt das ich lehrer sei und wir in einer ag in der schule ein projekt machen würden für das die schüler die chips brauchen *lol* "wären wir super dankbar wenn sie uns netter weise..... " und schon waren die bei maxim natürlich feuer und flamme - gut funktioniert nur einmal, dafür hab ich sie portofrei und kostenlos :) wobei ich heute mittag mal nach dem 6007 geschaut habe - habe keinen distributor gefunden, wo man den kaufen könnte - nur bei maxim direkt - und dann muss man gleich 25 stück nehmen. wie bist du damals bei der entwicklung eigentlich dadrauf gekommen, die teueren maxim chips zu benutzen? gibts da nichts günstigeres? Gruß - Chris
Hi Thorsten, also ich habe gerade bei reichelt die benötigten teile bestellt - auch nen display, werde also dann die komplette cv bauen mit nem dout x2 und erstmal auf hallocinogens code verzichten (kann ich ja wenns gar nicht hinhaut immer noch benutzen). ich denke ende nächster woche habe ich alles zusammengebaut - leider fehlt mir der 6007b :( hatte bei maxim samples geordert, die kamen auch, aber nicht dran gedacht dass ich den auch brauche - irgendne ahnung wo ich den her bekomme? wenn das teil dann vor mir liegt kann man besser sprechen/testen als so theoretisch.... allerdings muss ich wirklich dazu sagen, dass wenn mir niemand die 10 zeilen vorgibt, ich das wohl nicht hinbekommen werde. naja mal abwarten, die platine mit aout/dout/core ist fertig und ich warte auf die teile... Grüße, Chris EDIT: Gerade noch mal mit der netten Dame von Maxim gesprochen - der 6007 kommt im laufe der Woche nach.... :)
Hi Thorsten, ja das wäre doch ne option, denn so viele gates bräuchte man ja eigentlich wirklich nur für nen vintage drummer - dann könnte man sagen kanal 10 und ab c2. wenn das möglich wäre, wäre doch super. ich habe wie gesagt so programmiertechnisch überhaupt nix aufm kasten *schäm* aber wie bei deinen anderen app's könnte man das ja einbauen so das der user das mit einer zeile anschalten könnte. ich denke da vor allem an die midifizierung der 808 (auch der gekauften), denn was da im netz so an midi-kits angeboten wird ist echt super teuer und teils auch wirklich nicht so der brüller (selbst teure midi-kits haben ein gate zu wenig, so dass man sich entscheiden muss auf welches instrument man verzichten muss). naja bin jetzt auch echt am überlegen was ich mir baue - ich glaube ich baue zur sicherheit ne platine mit lcd und multiplexer auf, so kann ich die anwendung von halucinogen benutzen und wenn das mit den gates und dem multiplexer mal klappt kann ich umswitchen auf midibox cv und habe dann auch genug velo leitungen - den rest kann ich dann auch rausführen für andere sachen. habe auch ein paar 909 clones gebaut, kick und snare, die ich im moment mit meiner 606 triggere - die hätten dann auch direkt ein ordentliches interface :) aber mal zurück zu den "paar zeilen code": wenn du die statisch vergibst, wäre immer noch das problem der zuordnung - was ich meine ist folgendes: bei nur 8 velo leitungen müsste es so sein, dass der erste dout getriggert wird und der erste aout die velo ausgibt - ab dem 8. dout müsste immer der 8 aout die velo ausgeben, also auch beim 9. 10. usw dout. wäre das machbar? Grüße, Chris
ne das ist doch nicht im sinne des erfinders - nen zweiten core der sich dann mit midio "an den füßen spielt" :) ich habe heute die anwendung von hallucinogen bekommen (fetten dank an dieser stelle!) funzt dann auch ohne display - einfach nen core + dout + aout und es macht exact was ich brauche - speilt man noten ab c2 so wird der erste dout 1ms getriggert - aout1 gibt velocity aus, note d2 = dout2 + aout2 usw.... ist schon sehr speziell die anwendung, dennoch sollte man an dieser stelle mal über die einbindung der dout's als trigger/gate's in midibox cv nachdenken, denn mir fallen da ja direkt noch mehr anwenungen dafür ein... wobei richtig sinnig wird die midibox-cv-dout-erweiterung erst mir dem aout multiplexer, denn die meisten leute brauchen wohl zu jedem trigger auch velocity (bräuchte ich ja auch, gehe aber vorerst den kompromiss ein, dass sich mehrere instrumente eine leitung teilen) wenn man mal so das netz durchstöbert ist die midibox cv die mit abstand beste und günstigste lösung, wäre von daher sehr cool wenn man das noch ausbauen könnte. Grüße, Chris
Nein die Sache ist so: Die 808 hat 12 Instrumente, die alle Trigger/Gate und Velocity BRÄUCHTEN. Da man mit einem aout aber nur 8 mal Velo steuern kann teilen sich 5 Instruemente eine Leitung, was auch nicht schlimm ist, solange BD, HH, SD etc dynamisch gespielt werden können. Trigger/Gate könnten sich zwar mehrere Instrumente teilen, dann kann man die aber nicht mehr zur gleichen Zeit benutzen. Naja ob jetzt 8 oder 10 - mir fehlen dummer Weise immer noch 2 dann :( Richtig cool würde mein Vorhaben dann, wenn der aout multiplexer von der midibox cv unterstüzt würde, wobei ich mit 8 mal Velo leben könnte, nur solange Gate/Trigger fehlen ist das ganze halt sinnlos leider. Das es hardwaremäßig geht, sieht man bei hallucinogen nur kann ich halt die Software nicht selber anpassen. Grüße, Chris
Hi, da mein 808 Clone nun schon fast fertig ist suche ich nach einem geeigneten Midiinterface. Ein Aout habe ich bereits, dann müssten zwar ein paar Instrumente ein und die selbe Velocity Leitung nehmen, die wichtigsten haben aber eine eigene - wäre also kein Problem. Das große Problem bei der Midibox CV ist aber, dass ich nur 8 Gates habe, aber 12 brauche. Kann man da kein DOUT dran anschließen und so ein paar mehr Gates bereitstellen? Hallucinogen hat das bei seiner 808 so gemacht - musste dann aber wahrscheinlich auch die Firmware anpassen, was ich auf keinen Fall hinbekommen würde :( Wenn es da wirklich keine Lösung für gibt, bleiben mir nur 2 Möglichkeiten. 1. Ich verzichte auf Velocity, dann kann man aber nicht so schöne organische Patterns machen :) 2. Ich baue ein Midio128 und eine MidiboxCV und baue beide ein - was nen ganzen Core verschwenden würde. Weiß jemand Rat? Grüße, Chris
Hi! Da habe ich aber noch mal eine Frage - man hat ja normalerweise eine LED bei den Ledrings für "Center", beim Level-Meter eine für Overload .... benutze ich jetzt das LEvel-Meter um die Reglereinstellung anzuzeigen - wird die Overload LED dann einfach nicht benutz (also alle LED's an ausser Overload=100%) oder wird sie mit integriert? Besser wäre dass sie nicht benutzt wird im Reglereinstellungsanzeigemodus :-) Gruß, Christoph
Hört sich super an :-) Besten Dank schon mal im vorraus .... bin gespannt... Gruß - Christoph
Nunja, wie schon gesagt: Mit dieser funktionalität kann man halt alles was man will für die Volume-Steuerung benutzen und das bei guter, praktischer Bedienbarkeit. Ich habe jetzt natürlich leicht reden :) aber find ich schon cool von der Planungsphase an supportet zu werden.... ist bei opensource nicht unbedingt die Regel. Wobei ich auch einiges von C verstehe ..... mehr als von asm zumindest - wenn du Bock hast (und vor allem mal Zeit) kannste ja mal was basteln.... ich werde mal schauen dass ich bei dem Teil zumindest mal einen Kanal mit nem Level-Meter baue (ist ja erstmal fliegende Verkabelung + Schrankrückwand) würde dann auch nen bischen was testen und evet. mal ne Anleitung schreiben ... Gruß, Christoph
:) das wäre natürlich die beste lösung, denn eigentlich ist man ja auch fader gewöhnt um zu mixen - nur muss ich ehrlich sagen, dass mir die sache mit (guten) motorfadern zu teuer würde - da wäre diese lösung wirklich eine gute alternative.... wenn ich die schaltpläne richtig gesehen habe, gibt es auch die möglichkeit level meter für die fader anzuschließen.... zeigen diese den pegel oder die einstellung des faders an? wenn diese nur die pegel ausschläge zeigen wäre es sinnvoll, wenn diese dann die einstellung des faders anzeigen würden .... sollte das so umzusetzen sein, denke ich das motorfader wirklich nur noch luxus wären - denn ordentlich betreiben liese sich die lc mit diesem konzept allemal... mal schauen wann meine teile kommen, bis aufs display und die frontplatte habe ich schon alles bestellt, würde mich dann auch als betatester anbieten... die encoder kann ich nacher mal für den ausbau des sids benutzen ... fehlen mir jetzt noch fader .... was nimmt man denn für welche? also mind. 80ger denke ich mal, und dann welche die nicht gleich verschleißen oder kratscheln (was sich bei einem digitalmischer bestimmt in wertesprüngen äußern würde) - gibts da schon erfahrungswerte? Gruß, Christoph
