toxictv101
68 -
Everything posted by toxictv101
Eagles___is it possible to mix 2 board in 1?????????
toxictv101 replied to toxictv101's topic in Design Concepts
of course without gnd and power ... ;D tks -
hi i ve looked everywhere in the prog (eagle) but can't find a way to mix together 2 or more different board for exemple if i want to put 1core & 1sid on the same card Tanks For Help. ENjoy DIY Electronic
hi sebo i used bc639/640 ((also for noise part)) and tl072 for opamp everything work well but i want to remake one my self and drawn everything and put all the pot on the board with voice because its so boring to solder all wire between pot and ci. >:( more than 200wire :o :'( (""i hate do that"")) i gona make one board with all voice on it And a second board with seq,ctrl,...
ive my 4 voice808 (bd,sn,ma,clp)now finished no one part was hard to find for me, i ve put the same transistor everywhere (npn,pnp ofcourse) and its sound good. ive just notice that all the hallucinogen mods are not working perfectly , because some pots dont work on 100% some one are only active during 15% of the rotation. would be maby great to redrawn all the schematics and make it tcheked by some one That know well The "TWIN-T filter :)
for now i was planning to just build 4 sounds modul bass drum, snare,maracas & clap with midio128 to trig it in midi, without velocity i ve never think to build it with 4 output with different velocity on each good idea :D i ll do it later. But i would like later build a complet tr808 with all sound, sequencer, 24ppqn sync etc ... lot of work :p i ll post sample of the 4sound808 when it s done , think will finish it tomorow ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) :P
yes you re right , the answer was there !!! just needed to replace a part of main code USER_SR_Service_Finish clrf MIOS_PARAMETER1 movlw 0x00 call MIOS_DOUT_SRSet movlw 0x01 call MIOS_DOUT_SRSet movlw 0x02 call MIOS_DOUT_SRSet return Perfect 1ms Pulse output , ;D YAhaaaaaaa!!!!!! :D
yes for trig drum modul
hi, i know that it's possible to get 1ms pulse from the output of dout with the midio128 , i just can find how to :(
i dont know but, one time i ve Destroy a pic and when i puted it into the core , Voltage falled Down,, dont know why
ok, sorry ! i m building a midi triger interface for a 808clone. i ve simpify the more i can the core modul , so i ve remove lcd connector and all route that was not needed, in fact i ve just keep the midi, and the dout. i ve upload midio128 without problem now, the problem was that the upload have to be done under 2 sec. now it s ok , but like all the time , i ve got a another probleme!!! the crystal dont seem to oscillate anymore!!! i supose that one of the 2 pin must be HIGH (5v) and the other Get the 10MHZ But no one is HIGH, is it normal ???? maby is it i dont know i tcheked all pin of the pic with oscillo, no one is moving, ((( Its not a hardware problem , because with a another pic already programed for sid , the crystal oscillate and all pin Are dancing))) so ..... ?????? i dont know ? if it s normal
i ve done the main board i can say that the snare is amazing !!!!! (now i m makin a midio128 to trig All That Sounds))
in fact i already try to convert the last mios puting the script hex2syx.pl in the folder etcetc... but it doesnt work , impossible to convert it say that the main. file need to be tcheked is someone can send me the already converted , it would be amazing Please help me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok i dont knowed these channel Tks!
i created a new chat room For Ucappser Join Me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
find the part number on it find the datasheet on google but for me it look like a switch
hey , Can u say what u use for trig the sound ? i mean witch module ? what is your mb configuration and what are the requiere change to the prog. Tks
so great!!! can't wait to see the plan :o it would be great to get more than 16 trig/Gate out to control also external fx, DrumSynth etc ... if u can send me info on Galactikexplorer@hotmail.com Tks ...
i would need a config. that alow a less 16 pulse output in 15volt controled by a sequencer with synch24, din modul for step prog. etc ... is anybody have a sugestions for this , it would be welcom ??? i m minding on this problem...
yheap you re probably right! i ll do like this finally But i wanted to understand how work the famous TwinT Filter and see it in work by my eyes ::) i just hope that there is no error in his pcb because without the schems it s not easy to understand :p but i think now , i would be able to do it with all the lecons of electronic that ive folow. i ll finish this , and find a other think, maby for my end of study work. ...i ll send this 808x clone's picture here later see you soon :) ...
Message for trusted technicians....:-)))))
toxictv101 replied to tripiale's topic in Testing/Troubleshooting
hey sorry for the time What is exactly the probleme with your MidiBox ? What Do not WorK ? -
hi i m also trying to make a clone of the 808 i want to build eatch sound separatly on a pcb like Hallu. and build a sequencer. i gona use a R8c/13 µC From Rensas actualy i ve done only the basscick pcb and the switch board and i m working on the serial shiftregister, first time that i do a such complex work. i also simulate all sound modul with ElectronicWorkbench That is work pretty well for That maby it would Be great to cooperate.
