mrmeana
    17
Everything posted by mrmeana
  1. I have a metcal SP-200, its the best it heats up in about 3 seconds and is always a constant heat. It is truely amazing to work with makes other irons seem a bit crappy, the ok industries irons are suppose to be great too. look on ebay for good second hand deals these things are damn near indestructable http://www.okinternational.com/product_soldering/sp200
  2. check this, I have been watching this evolve for a year or so. Brainchild from lumen lab has done most of the hard work for you :) http://www.lumenlab.com/store/robloks/microbotics/micro.html if only i had some workshop space :(
  3. I agree i have been looking for a cheap retrofit for years. That mungo is looking like a good option. my broken keys are an E an F and a G, my juno took a tumble and landed right on them; guttted :( i found these last night too http://manuals.fdiskc.com/mans/ a huge reasorce of service manuals and this wee treat http://erikhall.mine.nu/~ronny/juno60/juno-60serv_manual.pdf
  4. midification kit options http://mungo.com.au/midiretrofits.html http://www.kentonuk.com/kenton/retrofit_kits/ju60-rk.html http://www.engineersatwork.nl/catalog/product_info.php/products_id/548?osCsid=cffa9a77ac93e1cc2f32121a0fe07ac9 dont know if its any use to you but they all do retrofit kits, all comes down to how much control you want and wht you want to spend. any one know where i can get some replacement keys and those long screws that go through the end checks and hold the panel down?
  5. http://www.electronic.it/en/product/11776/Potentiometer-10K.asp 10k pots 5c each
  6. Got mine today. They were packaged imaculately. Thanks for all your effort Frank
  7. hi i am interested in at least 100 mabee more
  8. i would definately be in for 2 to mabee 6 depending on how many you end up with Cheers
  9. hi here is a list of compatible alternatives to the ks0108 ks0108 The controller pair KS0107/KS0108 drives a 64×64 pixel area. In a typical set-up, two KS0108 controllers are combined with a single KS0107 controller to form a 128×64 resolution display. Compatible alternatives to the KS0107/KS0108 are: HD61202/HD61203, AX6108/AX6107, KS0708, S6B0708, S6B0108A, S6B2108, S6B0108 and NT7108. found here http://www.compuphase.com/graphic/polyraster.htm now to find 240x64 displays :-\
  10. suck to be me then :'(
  11. http://mkv.itm.miun.se/personal/per/diy/DCB/DCB.html info on the dcb protocol :)
  12. 10k Alps Slide pots LOTS OF THEM ;D http://cgi.ebay.com/Alps-Single-Unit-Analog-10K-Ohm-Slide-Potentiometer-LOT_W0QQitemZ180096568699QQcategoryZ58164QQrdZ1QQcmdZViewItem?hash=item180096568699 check the photos to work out if they are linear????
  13. hi guys if there are any of the boards that arent spoken for i would love one. If there is one please pm me thanks heaps
  14. cheers I figured it would be blatently obvious ::)
  15. Hello This is probably a really stupid question but is it possible to implement a midi channel selector (either a rotary encoder or just a push button that incrementally increases) into a midibox 64 project. All I want to be able to do is shift all the front panel controls to a different midi channel via the selector. I know absolutely nothing about MIOS but have read this site and forum repeatedly and can’t seem to find an answer. Cheers Carl
  16. I am in wellington NZ i just searched and found a few nz reference in the forum. do you know any good sources for motorfaders overseas? cheers
  17. Hello I noticed alot of Nz/oz midiboxers and was wondering if anyone can help me find a good cheap source for parts for a midibox lc (mainly motorfaders) Cheers
