ansolas
77 -
Everything posted by ansolas
Thank you for your replys, essentially I don't care bout which encoders :) I just want an accurate controller Such kind of accelerating functions would be interesting, they would let do use some "rubberband" automation things :) Anything that is more accurate as a Novation SL mkII Control should be enough.
I just found this project : http://www.96khz.org/htm/midicontroller15spdif.htm
Thank you for your reply ! anything else ? This article is quite old and just theory ? Is there any high resolution controller out there which is more precise than anything from novation ?
Hi, is it possible to create a controller with encoders which has the following behavior: if you turn slow it is as precise (as a 1024 step Motor Fader) as using a mouse (perfect to tweak EQ's or 'tune' a Filter ) if you turn faster it increments faster It should be highly responsive to direction changes (play the filter as a analog synth) It would be awesome if you could enable easing functions such as: https://jqueryui.com/resources/demos/effect/easing.html Possible ?
Hab ich schon gehabt, aber die Haptik hat mir ganz und gar nicht gefallen, die Auflösung und die Reaktion war einfach weniger gut.
Hallo, kann man irgendwie VST Plugins (zB in Cubase oder Logic) mit einer hohen Auflösung von 14 Bit Automatisieren ? Im Grunde genommen brauche ich einfach nur ein Poti (kein Encoder) und eine Learn Funktion damit ich jedes Parameter steuern kann. Gibt es so etwas ? Grüße Marc
yeh unfortunately not any synth supports this standard, the guys from access even dont knew that there is such a standard... Some kind of magic box would be cool *lol*
Hm, editing sequences afterwards might be a lil bit hard due to all theses data.
Thank you very much for your replies, and links ! I wonder how these hi-pi guys solve the tuning, I bet via pitchbend? So you could theoreticly use 3 MIDI channels to play a microtonal chord?
Hello all, I wonder if there is a way to create a Mircotuner for MIDI Synths which do not base on Pitchbends, so that you can play it polyphonic. Any Idea how we could solve this ? Cheers Marc
Hallo Freunde, ich plane mir einen MIDI Merger und Splitter zu bauen. Wie gehe ich hierfür am besten vor ? Ich benötig min 1 auf 8 und 8 auf 1 Wo finde ich hier infos zum programmierung wie ich MIDI signale ?addiere? Generell, wenn ich daten "merge", werden die dann einfach hinteranender weiter gfeleitet ? Timing mäßig spielt das bei meiner Anwendung keine Rolle da ich eh alle Geräte nacheinander Sample. Grüße Marc
ich habe die Teile von eBay erstenden, duften tuen sie jedenfalls nicht. Die Teile aus der Liste sind nach Fertigstellung meines SID Synths über geblieben. Grüße Marc
http://www.ansolas.de/ebay/C64/Web-Site/Fotos.html Schickt mal einfach Angebote an mich. Am liebsten ist mit natürlich wenn alles auf einmal weggehen würde, dann kann ich mir endlich bassfallen zulegen. :D Liebe Grüße Marc
Hello Friends! as far as i know, you need a external tool to enable pure java programms to have access to external midi devices. The freeware Plumstone isn´t available for intelmacs, the shareware Mandolane overtook it´s job now. Anybody know if there is a FREE extension which enables access to external midi devices? Have a nice day! marc
Hochauflösend war evtl. ein wenig ungenau Ausgedrückt. Die Auflösung war auf die Votis bezogen, da es ja noch geringer Aufgelöste Enkoder gibt. Also 24 Impulse pro Umdrehung sollten schon drin sein. Idee ? Die Besten Grüße Marc
Hallo Freunde, ich erforsche gerade den SID Wavetabe Sequencer und arbeite die Tutorials durch. Leider funktioniert das bei mir gar nicht richtig ?! Trancegate gated nur einmal und dann wird der Chord angehalten. Die Jump Anweisung sollte doch ein ständiges "Gaten" ermöglichen oder ? Der Dropdown Teil eins geht nur einmal nachdem ich das Patch angewählt habe. Dannach muss ich das patchg abwählen und wieder neu anwählen ? Auf der Seite: http://www.ucapps.de/midibox_sid_cs.html unter WaveTable Absatz zweit steht folgendes: "Btw.: since it's difficult to remember all available CC numbers, the CC parameter string will be displayed when you modify the number" Ist diese Verhalte irgendwo einzusetllen? Be mir werden die Parameter Namen nicht angezeigt. Ich habe es bisher noch weniger geschafft die Wellenformen mit dem CC#32 zu wechseln. Aller Versuche resultieren mit der "Wellenform" Noise. Ich forsche weiter... Gruß Marc
Hab´s jetzt, hab mein mac einfach mit bootcamp in windows xp gestartet ::) So jetzt Laufen alle 3 Core / SID Module und nur noch ein SID Chip fehlt mir. Die Matrix funztzt jetzt endlich auch einwandfrei yeah :)
8565 R2 ?? ist das der gesuchte? Ich habe davon glaube ich noch mindestens 2! Gruß Marc
Hallo Freunde, ich habe vor kurzer Zeit so einige C64 II von eBay erworben. Ich hab ejetzt festgestellt das in einigen C64II Modellen ebenfalls die 65er chips Verwendung fanden. Ich habe jetzt 3 Cores / SID kombinationene am laufen, jetzt feht nur noch der 4te Chip. Hat hier evtl noch jemand einen zu verkaufen oder zu tauschen gegen einen 65er :) Die besten Grüße Marc
Halle Freunde! soweit funktioniert jetzt alles. Ich habe heute mal versucht Patches hochzuspielen. Geht nicht ! Mein MIDI -OUT port funktioniert nur in MIOS Studio Sende ich zB Noten mit MidiOX kommen die Noten nicht am Sid an. Nutze im SysexManager ist kein MidiOut Port anwählbar. Und die UNITOR8 Treiber funktionieren nicht mehr meht auf meinem neuem IntelMac Super wa ... Grus Marc
ok hab die anderen funktioenen gefunden und auch das sid-matrix test program von der mios seite.
Hallo Freunde! ich habe jetzt meine Step C Control Surface Fertig und mölchte diese gerne auf Fuktion Testen. Habt Ih hier für evtl. ein paar Erfahrungen mir mitzutreilen? Zb. wie teste ich am besten die LED Matrix ? Die besten Grüße Marc
