nhaudio
12 -
Everything posted by nhaudio
Hi t-xen if you still have this board available we can trade. I have an extra 8580 that I won't use. let me know if you're still interested. Cheers, nicolas
sorry I kind of forgot about this post, do you still have it for sale? if yes, is 120 euro + shipping a fair offer for you? cheers, Nicolas
hi can you give me your location, and what would be the shipping cost for italy? cheers, nicolas
as predicted no luck with jal, but at least I learned how to install from the terminal :) then I tried the script with the mios main.asm (not the sid), no luck either, that means the script does not work with osx as it is now. any suggestions?
hey, I saw your other forum post: But there's one thing I couldn't get done on my mac: burning the PIC. There's no serial Port and all USB-Adaptors have never worked relyable and / or there were no drivers available. So after all, if you want to burn MIOS into a chip, you'll need a PC. (Don't know if this changes with MBHP-Burner, I used JDM). I saw this article, maybe you didn't know about it and I think it's related: http://www.mactech.com/articles/mactech/Vol.20/20.02/PICMicrocontroller/index.html do you think the jal could work for our purpose? I'm going to try anyway. cheers, Nicolas
The top part I knew, though true that it's for mios and not sid app. ok I've checked one file, and at least in the main.asm there's no change before and after running the script. I need to check the oher files. So maybe the script doesn't work with os X? or with the sid application. I really don't know...but if it works with linux should it work with os x too? I guess you half answered the question already. If you have a clue of where to go from here, we can try and continue to work on it, but I understand that it might be time consuming for you. your call. It would be a great plus for os x users. in the short run I think the easiest way for me is to try to find a friend with a pc and do it at his house. while we can continue to try and find a script that works. again, thank you for your time, cheers, Nicolas
well in theory it should work, it's from the wiki so I gess (i hope) people did try before me. no it wasn't me who tried to do the seq. I'll redo everything to see if it changes something. For what should I look in theory? thanks again nico
>:( I still get this if I try to compile ~/Desktop/midibox_sid_v1_7303b/src] nicolash% gpasm main.asm sid_sin_table.inc:34:Error [103] syntax error main.asm:520:Error [103] syntax error cs_menu_io_tables.inc:35:Warning [202] Argument out of range. Least significant bits used. cs_menu_io_tables.inc:35:Warning [202] Argument out of range. Least significant bits used. cs_menu_io_tables.inc:35:Warning [202] Argument out of range. Least significant bits used. cs_menu_io_tables.inc:35:Warning [202] Argument out of range. Least significant bits used. cs_menu_io_tables.inc:35:Warning [202] Argument out of range. Least significant bits used. cs_menu_buttons.inc:100:Error [103] syntax error cs_menu_buttons.inc:102:Error [103] syntax error cs_menu_buttons.inc:104:Error [103] syntax error cs_menu_buttons.inc:106:Error [103] syntax error the syntax error goes on for a while
got this, I think it's good... ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh + tr -d '\r' + sed -f replace-macros.sed + mv src/main.asm_ src/main.asm + tr -d '\r' + sed -f replace-macros.sed + mv src/setup_6581.asm_ src/setup_6581.asm + tr -d '\r' + sed -f replace-macros.sed + mv src/setup_6581_without_cs.asm_ src/setup_6581_without_cs.asm + tr -d '\r' + sed -f replace-macros.sed + mv src/setup_8580.asm_ src/setup_8580.asm + tr -d '\r' + sed -f replace-macros.sed + mv src/setup_8580_without_cs.asm_ src/setup_8580_without_cs.asm + tr -d '\r' + sed -f replace-macros.sed + mv src/app_defines.h_ src/app_defines.h + tr -d '\r' + sed -f replace-macros.sed + mv src/macros.h_ src/macros.h + tr -d '\r' + sed -f replace-macros.sed + mv src/mios.h_ src/mios.h + tr -d '\r' + sed -f replace-macros.sed + mv src/app_lcd.inc_ src/app_lcd.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu.inc_ src/cs_menu.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_bank.inc_ src/cs_menu_bank.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_buttons.inc_ src/cs_menu_buttons.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_cc_table.inc_ src/cs_menu_cc_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_enc.inc_ src/cs_menu_enc.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_enc_table.inc_ src/cs_menu_enc_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_exec.inc_ src/cs_menu_exec.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_io_tables.inc_ src/cs_menu_io_tables.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_leds.inc_ src/cs_menu_leds.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_matrix.inc_ src/cs_menu_matrix.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_ms.inc_ src/cs_menu_ms.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_p2r_r2p.inc_ src/cs_menu_p2r_r2p.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_print.inc_ src/cs_menu_print.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_tables.inc_ src/cs_menu_tables.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_tables_struct.inc_ src/cs_menu_tables_struct.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/cs_menu_timer.inc_ src/cs_menu_timer.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/j5_dout.inc_ src/j5_dout.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/math_mul16_16.inc_ src/math_mul16_16.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/midi_rxtx.inc_ src/midi_rxtx.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/mios_tables.inc_ src/mios_tables.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/mios_vectors.inc_ src/mios_vectors.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/p18f452.inc_ src/p18f452.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/p18f4520.inc_ src/p18f4520.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/p18f4620.inc_ src/p18f4620.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_aout.inc_ src/sid_aout.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_aout_lc.inc_ src/sid_aout_lc.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_bank.inc_ src/sid_bank.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_cc_table.inc_ src/sid_cc_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_ccin.inc_ src/sid_ccin.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_ccout.inc_ src/sid_ccout.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_depth_table.inc_ src/sid_depth_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_env_table.inc_ src/sid_env_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_frq_table.inc_ src/sid_frq_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_lcd.inc_ src/sid_lcd.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_lfo_table.inc_ src/sid_lfo_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_midi.inc_ src/sid_midi.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_note_table.inc_ src/sid_note_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_patch.inc_ src/sid_patch.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_presets.inc_ src/sid_presets.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_sin_table.inc_ src/sid_sin_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_sr.inc_ src/sid_sr.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_sw.inc_ src/sid_sw.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_sysex.inc_ src/sid_sysex.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_sysex_table.inc_ src/sid_sysex_table.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_tune.inc_ src/sid_tune.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/sid_wt.inc_ src/sid_wt.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/special_characters.inc_ src/special_characters.inc + tr -d '\r' + sed -f replace-macros.sed + mv src/user_vectors.inc_ src/user_vectors.inc
well I think we're getting there... here is what I got: /Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh + tr -d '\r' ./fix-gpasm.sh: line 4: *.asm: No such file or directory + sed -f replace-macros.sed + mv '*.asm_' '\*.asm_' main.asm_ setup_6581.asm_ setup_6581_without_cs.asm_ setup_8580.asm_ setup_8580_without_cs.asm_ main.asm setup_6581.asm setup_6581_without_cs.asm setup_8580.asm setup_8580_without_cs.asm usage: mv [-f | -i | -n] [-v] source target mv [-f | -i | -n] [-v] source ... directory + tr -d '\r' ./fix-gpasm.sh: line 4: *.h: No such file or directory + sed -f replace-macros.sed + mv '*.h_' '\*.h_' app_defines.h_ macros.h_ mios.h_ app_defines.h macros.h mios.h usage: mv [-f | -i | -n] [-v] source target mv [-f | -i | -n] [-v] source ... directory + tr -d '\r' ./fix-gpasm.sh: line 4: *.inc: No such file or directory + sed -f replace-macros.sed + mv '*.inc_' '\*.inc_' app_lcd.inc_ cs_menu.inc_ cs_menu_bank.inc_ cs_menu_buttons.inc_ cs_menu_cc_table.inc_ cs_menu_enc.inc_ cs_menu_enc_table.inc_ cs_menu_exec.inc_ cs_menu_io_tables.inc_ cs_menu_leds.inc_ cs_menu_matrix.inc_ cs_menu_ms.inc_ cs_menu_p2r_r2p.inc_ cs_menu_print.inc_ cs_menu_tables.inc_ cs_menu_tables_struct.inc_ cs_menu_timer.inc_ j5_dout.inc_ math_mul16_16.inc_ midi_rxtx.inc_ mios_tables.inc_ mios_vectors.inc_ p18f452.inc_ p18f4520.inc_ p18f4620.inc_ sid_aout.inc_ sid_aout_lc.inc_ sid_bank.inc_ sid_cc_table.inc_ sid_ccin.inc_ sid_ccout.inc_ sid_depth_table.inc_ sid_env_table.inc_ sid_frq_table.inc_ sid_lcd.inc_ sid_lfo_table.inc_ sid_midi.inc_ sid_note_table.inc_ sid_patch.inc_ sid_presets.inc_ sid_sin_table.inc_ sid_sr.inc_ sid_sw.inc_ sid_sysex.inc_ sid_sysex_table.inc_ sid_tune.inc_ sid_wt.inc_ special_characters.inc_ user_vectors.inc_ app_lcd.inc cs_menu.inc cs_menu_bank.inc cs_menu_buttons.inc cs_menu_cc_table.inc cs_menu_enc.inc cs_menu_enc_table.inc cs_menu_exec.inc cs_menu_io_tables.inc cs_menu_leds.inc cs_menu_matrix.inc cs_menu_ms.inc cs_menu_p2r_r2p.inc cs_menu_print.inc cs_menu_tables.inc cs_menu_tables_struct.inc cs_menu_timer.inc j5_dout.inc math_mul16_16.inc midi_rxtx.inc mios_tables.inc mios_vectors.inc p18f452.inc p18f4520.inc p18f4620.inc sid_aout.inc sid_aout_lc.inc sid_bank.inc sid_cc_table.inc sid_ccin.inc sid_ccout.inc sid_depth_table.inc sid_env_table.inc sid_frq_table.inc sid_lcd.inc sid_lfo_table.inc sid_midi.inc sid_note_table.inc sid_patch.inc sid_presets.inc sid_sin_table.inc sid_sr.inc sid_sw.inc sid_sysex.inc sid_sysex_table.inc sid_tune.inc sid_wt.inc special_characters.inc user_vectors.inc usage: mv [-f | -i | -n] [-v] source target mv [-f | -i | -n] [-v] source ... directory
much respect 8) if you ever come to italy, I owe a couple of beer...at least
:'(not yet ;) i did try a few things first like this: #!/bin/sh for i in \'*.inc' \'*.asm' \'*.h';do tr -d '\r' < $i|sed -f replace-macros.sed >${i}_ && mv ${i}_ $i done got that: ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh ./fix-gpasm.sh: line 4: unexpected EOF while looking for matching `'' ./fix-gpasm.sh: line 6: syntax error: unexpected end of file then like this #!/bin/sh for i in '\*.inc' '\*.asm' '\*.h';do tr -d '\r' < $i|sed -f replace-macros.sed >${i}_ && mv ${i}_ $i done and got that ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh ./fix-gpasm.sh: line 3: unexpected EOF while looking for matching `'' ./fix-gpasm.sh: line 5: syntax error: unexpected end of file then like this #!/bin/sh for i in '\*.inc' '\*.asm' '\*.h';do tr -d '\r' < $i|sed -f replace-macros.sed >${i}_ && mv ${i}_ $i done and got that ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh ./fix-gpasm.sh: line 3: \*.inc: No such file or directory sed: 1: replace-macros.sed: command i expects \ followed by text ./fix-gpasm.sh: line 3: \*.asm: No such file or directory sed: 1: replace-macros.sed: command i expects \ followed by text ./fix-gpasm.sh: line 3: \*.h: No such file or directory sed: 1: replace-macros.sed: command i expects \ followed by text then last one like this #!/bin/sh for i in \'*.inc' \'*.asm' \'*.h';do tr -d '\r' < $i|sed -f replace-macros.sed >${i}_ && mv ${i}_ $i done and got that: ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh ./fix-gpasm.sh: line 3: unexpected EOF while looking for matching `'' ./fix-gpasm.sh: line 5: syntax error: unexpected end of file thanks agan for the help, cheers, Nicolas
hey michael I did a typo, I had only removed src/ so the fault is not coming from there...but...I feel a bit stupid but this time I don't get it. ;-( let me know when you have some spare time, cheers, nicolas
ok removed "src/*" in the script got this (I hope it's ok?): ~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text sed: 1: replace-macros.sed: command i expects \ followed by text [nicolas-hermansens-powerbook-g4-12:~/Desktop/midibox_sid_v1_7303b] nicolash%
hi michael thanks for the help, we made some progress, here's what I get [:~/Desktop/midibox_sid_v1_7303b] nicolash% ./fix-gpasm.sh ./fix-gpasm.sh: line 4: src/*.inc: No such file or directory ./fix-gpasm.sh: line 4: src/*.inc_: No such file or directory ./fix-gpasm.sh: line 4: src/*.asm: No such file or directory ./fix-gpasm.sh: line 4: src/*.asm_: No such file or directory ./fix-gpasm.sh: line 4: src/*.h: No such file or directory ./fix-gpasm.sh: line 4: src/*.h_: No such file or directory
sorry about it, but for my defense i stated it ;). I did it just because as a sid forum user I never checked the assembler forum, and since the topics could belong on both...tried to remove but wont let me do...so admin if you can remove the topic in the sid forum... On the real topic now, yes that's what I'm trying to do, to fix gpasm, but when I try to run the ./fix-gpasm.sh or it gives me a permission denied, so went with the $sodu ./fix-gpasm.sh then it gives me a command not found, I even tried logged in root but no luck either. when I try to run the ./fix-gpasm.sh I'm in the midibox_sid_v1_7303b folder where all the files are located. (I copied the script from the wiki, made 2 files with a txt editor, one called fix-gpasm.sh and the other replace-macros.sed then put everything in the midibox_sid_v1_7303b folder) can you help? ???
Hi, I'm looking for some help, I'm building a sid with external filter. I've build everything ok, but when rebuilding the software (main.asm) after modification (MIDIbox SID users: open the "main.asm" file of the application and set the "ENABLE_AOUT" switch to 2. Thereafter rebuild the project and upload the new .hex file to the core.) I get an error. I posted this message in the sid forum too, didn't know where it really belong. if anyone can help. thanks I on mac os x and using gputils. I've read in the forum that with gputils they're some limitation. I've tried to run the script from the wiki (http://www.midibox.org/dokuwiki/doku.php?id=compiling_the_midibox_source_on_linux) but no luck (I get a no command found). can't seem to make it running. it's been 2 days that I'm trying to do this little change and I'm getting really frustrated, so my question is more a favor, does someone did the modification and can send me the hex file (main.asm in hex)? my email is nh[at]nhaudio.com. thanks for the help and this great forum, cheers, Nicolas
still have it? If yes Can I see the pics? Doesn't show on the forum. Cheers, Nicolas
ecco in italia, molto economico http://www.hifi2000.it/
cerca ebay, rack enclosure 19, cerca anche in tedesco, non mi ricordo piu come si dice xo gli ho comprati li. Gli trovi sui 30 euro Nico
hey Xavier would you be willing to sell me one kit (1-ymf262 and 2-yac 512) ? I live in Italy, I can pay you with paypal or european bank wire/transfer? let me know, Nicoals
thanks for all the great comments ;D With the Dr quack it sounds really good, A bit more "wooshy" "mooshy" I guess due to the envelope follower. btw it's an effect that I really like. I've only changed the feedback res on the opamp to have more gain. went with 3M3 instead of the 470k in the schem. I still think it's a bit low, I could have gone a bit higher... but if it works why change it... ;) Lazertran http://www.lazertran.com/ is a decal paper that you soak in water then apply to any surface. They have online ordering for europe and usa. I think it's a really good product to do homemade stuff. And you get really decent results. cheers, Nicolas
