Hello,  I've build a seq some time ago, but got stuck on a side note when trying it out. Now I just started reusing the machine again and I'm a bit stuck... I'm also not sure if I'm using the last version. How do I check this?  Track Event 5: I think this is what "drum mode" is. But when I put a note on layer A it's also on on layer B&C. Alas, with "0" velocity the note is gone again... But even then, "0" velocity doesn't always result in a 'no sound' either. So how is this mode used? Is there a drum mode as in 3 fixed notes and length and variable velocity but independent triggerable?  Phrase mode: It took me a while before I found out about this position (layer B button) function. Especially when I noticed I was changing banks instead of patterns, but I think I got it now. Anyway, when changing position, it changes position immediately. Got to the Sync pattern change option to change this, but now as soon as I select a new position, the tracks are muted. At the next start the newly selected position is started and you can hear it again. Is this also some sort of option? On topic, how do you chain patterns, haven't found this one either yet.  Well, that's it for now. It will take me some more time to learn about this machine, but I'm sure we'll get along eventually ;-)  Cheers, ToAd
