Hello Forum, Hello Thorsten, my Monodeck II MIDI controler uses two core modules to drive LEDs, capture pots etc.... So, DOUT modules are connected to both modules for controling a lot of LEDs. Additional hardware allows to dim R,G, and B of all LEDs based on phase width modulation of simple oscillators.It works somehow but is far from being perfect since it creates all sorts of flickering and moiree effects as a side effect of five clocks sources running free. I think there is a much more elegant way: The three phase width oscillators shall be replaced by three astable oscillators that are triggered by one common clock source and this clock shall be derived from the clock oscillator of Core 1. Core 2 shall be slaved clockwise to Core 1. According to the microcontroler data sheet it is very simple to achive. But before reinventing the wheel, i'd like to ask if someone here allready did this and if it works like expected. ( idea: Microcontroler 1 provides clock on OSC2 output, Microcontroler 2 gets this clock signal on OSC1 input, MIOS needs to be altered to reflect oscillator slave mode on Microcontroler 2. Microcontroler 2 puts out Clock/4 on OSC2 and this is used, maybe after more clock divisions, to drive the LED dimmers. This should create a 100% flicker and moiree free solution...) comments, ideas, suggestions ? Thanx, Robert
