thestruggler
18 -
Everything posted by thestruggler
My programming is not very good. AM just trying to figure out what files to change and how. I have followed the steps in installing perl, ultraedit, mid-ox, and so on. At the moment the mb64 is running the complete application midibox64_v2_4.zip. Am I supposed to edit a file from this? I do not have a bankstick installed, if i did would i be able to it through MIDIbox .syx configuration, should I be looking at serge's midibox editor? I am a bit lost, any pointers in the correct direction would help. Thanks
Hi, I am trying to figure out how to make mb64 LED stay on when button is pressed. At the moment it just turns on and then off again when a button is pressed, and I want the LED to stay on after the button is pressed, and then turn off when the button is pressed again. I have been trying the various parameters in the MB64 and edit events. The different paranmeters for the buttons don't make a difference. Should i be looking to edit the midibox64 ini in the mk_syx? If so what should I be editing? Thanks in advance for any feedback!
DIN problems and configuration
thestruggler replied to thestruggler's topic in Testing/Troubleshooting
Legend!! Thanks for the reply! feels like meeting a celebrity, and to top it off....what i had done was connect din pins J2 to another din on pins j2... yes...just knocked my head against the table a few times....need to shuffle the few brain cells i have left round a bit. Still .... I have to live up to my name....maybe its working in the late hours of the day that add their special twist ;) -
Hi, Am building a MB64. Have assembled most components and am now testing. lcd connected, and mios and application has been uploaded. faders and potentiometers behave as they should. The buttons on the other hand are not sending anything, and MIOS studio is not showing anything. I have only connected a handful and wanted to check the menu working. none of them do anything except for the menu/exec button, which send some rather random message? Any suggestions of how I can troubleshoot this? Thanks
i see your point. i dont really have a precision drill, but a plain ordinary one and what made me nervous to try that out. i dont have a board that i can try my drill on to see if that will work...am really tempted though ::)
I have a drill...but seems to be a drastic measure with them all already being stuffed...
Lets go shopping :) ... your input wanted
thestruggler replied to thestruggler's topic in Parts Questions
well spotted you bright person! I first noticed that on checkout when i decided to double check everything...phew : ) -
Hi, Another silly one really. The PCB's i purchased have really small holes for the 4 corners, same size as the legs of the componenets. I cant seem to figure out to fix them to a case?? Also would be handy to be able to take them off if the magic doesnt happen and it doesnt work?? Thanks...from miserably rainy london.
Hi, Thanks for your replies! Found an article that others might also find useful. http://sound.westhost.com/pots.htm With regards to the faders with 4 pins and two of them being labelled pin 2... do i connect them to each other?
hi, This is probably one of the dumbest questions but I seem to be a bit lost. I am not sure which pin on the potentiometer or sliders go where on the AIN. The sliders have 4 pins labeled 1 -3 (two of them being labeled 2). The pots just have three pins with no numbers? How can i test which one is which? Any link to info would be appreciated. Thanks
Hi! Thanks for the input people! I completely see your point about the length ... found some shorter ones .. hopefully they will work So thanks for saving me a bit of headache on those. Have been planning, contemplating, and procrastinating for ages ... so now i dive head first in the deep end! : ) Its always the best way to learn ... sort of have to live up tho the nickname ... even if most of the time its my own doing :P -
Hi, I am building a midibox64 with sliders, knobs, buttons, and leds. It will be hopefully used for a few things ... control cubase, ableton, and so on. I am just trying to experiment and see how this first project comes out. So far have had a few problems but which have been solved and my core, ltc, dout, and so on seem to be working with the correct voltages. Now is the time to build the case and put it all together. Can anyone have a look at my shopping list and let me know if I have gone wrong anywhere, and general thoughts. The case will be made of wood and plastic front panel. Potshttp://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Resistors+%26+Potentiometer&tier3=Control+Potentiometers&tier4=24mm+Commercial+potentiometers&moduleno=65224&catref=65-0515 Knobshttp://www.rapidonline.com/productinfo.aspx?&tier1=Tools%2c+Fasteners+%26+Production+Equipment&tier2=Fasteners+%26+Fixings&tier3=Knobs&tier4=Matt+black+control+knobs&moduleno=64713&catref=32-0280 Buttonshttp://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Switches&tier3=Push-Button+Switches&tier4=Non-RoHS+SPST+panel+mounting+push+switch&moduleno=75593&catref=77-0404 Sliderhttp://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Resistors+%26+Potentiometer&tier3=Control+Potentiometers&tier4=Slide+potentiometers&moduleno=65234&catref=66-0105 SlideControlhttp://www.rapidonline.com/productinfo.aspx?&tier1=Tools%2c+Fasteners+%26+Production+Equipment&tier2=Fasteners+%26+Fixings&tier3=Knobs&tier4=Slider+control+knob&moduleno=64718&catref=32-1222 Ledhttp://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Optoelectronics&tier3=5mm+LEDs&tier4=5mm+Standard+LEDs&moduleno=77692&catref=55-0155 LedCliphttp://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Optoelectronics&tier3=LED+Optics+And+Mounts&tier4=5mm+Bezel+panel+clips&moduleno=29304&catref=55-0260 Let me know what you guys think....and trying to keep it simple and accomplishable .... :)
Core voltage test issue... nothing showing up!
yeah yeah yeah!! i turned the rectifier the right way.....and voila all is how it supposed to be....(fingers crossed, knock on wood) measured the voltages at all the spots IC1:MCLR(1) - IC1:Vss(12) = 5V IC1:Vdd(11) - IC1:Vss(12) = 5V IC1:Vdd(32) - IC1:Vss(31) = 5V IC2(8) - IC2:(5) = 5V and i have 4.94 at all of them.......jubiiii!!!!!! I cant thank you enough for your help....me being so dense and all....absolutely brilliant.... until my next headbanging on the desk moment.... rock on \m/ -
Hi Lall, yes I have set the multimeter to DC when measuring + - and get 9v, and AC when measuring ~ getting nothing. Is the rectifier supposed to be installed onto the board in a certain direction? Could I have installed it wrong.... Thanks -
hi, Thanks for all your comments. My conclusion thus far is that the rectifier has broken. I get nothing at ~, but 9v at the + -. I am trying to get the component from maplins in th uk (B40C800).... does this look like the correct one? W005M http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=46438&doy=25m4#spec Thanks -
Hi, The power supply I am using is a regulated 500mA AC adaptor at 9v. 1) I have measured the voltage at J1 and get 9.10v. 2) I am not entirely sure how to do step 2. Sorry for being dense, i seem to be losing hope. I am getting nothing for step 3) Any suggestions? Should I try and stuff a new core? Again thanks for your input, i really appreciate it. -
Thanks a lot for your input. It is still not showing up with anything. :( Could I possibly have shorted something as the silly me was testing out with the clamps on....doh! Thanks -
Hi, I am a newbie and not as smart as I thought so pease bare with me and my stupid issues. I have soldered the core and attached a universal regulated 9v ac/dc adaptor. But when I come to test with the multimeter i seem to be getting absolutely nada. This is the front of the core: Back of the core: Multimeter Settings: Soldering is not my trong point but at least something should be showing up no? So I must be doing something very wrong in the way I am testing or fried something. The thumbnail of the mutimeter shows the seeting I am using...is this correct? I am testing on the front side as well as the back....which side should I be testing on? In theory i should be able to connect the black cable to IC1:MCLR(1) ...and the red cable on the multimeter to IC1:Vss(12) ...and get 5V... and so on. At the moment I am getting nothing. Even if I sucked at soldering shouldnt I at least get some values at some points during the testing? Could I have toasted a component during soldering. If I use the multimer to check the power supply then that shows up as 9v. Aso I dont really understand where the black cable on the multimeter should be positioned on the board for the tests in http://www.ucapps.de/howtodebug/mbhp_core_extract_measuring_vdd.gif Thanks for all your input in advance....and dont worry I wont be quitting my day job : )
