Thanks for support, the whole point is the idea interchange. Yes, as you approach with LDR to light source, the control voltage swings 0-5V. Sensitivity is adjustable, with knob (note the LDR sensor picture), in order to avoid offset in existing ambient light. Active range is about 30 cm. In Reaktor instrument, ther is the field labeled SENSOR ROUTER, so the LDR action is to be attached to various parameters ( apart form Loop rack parameters (pithc, volume), there is synth working in the backcround). Heavy atmos are preseted on Brother ( upper right on Brother picture). As there are 2 LDR's and two lamps, synth is controlled as LEFT HAND - pitch, RIGHT HAND - volume. So this is something like THEREMIN. Speaking about hands in action, i thinh that some manufacturers introduced ultrasonic distance meters, for 0-5V voltage generation. There is also electrostatic implementation ( like Theremin ). If there is any intrest, i'll post the schematic for LDR's. It's simple OP AMP circuit, and some discrete electronics. Also i could offer help for pepole who want to experiment with Reaktor. Note that for reasonable performance, you'll need low latency soundcard (mine is MAYA44 USB, with 3ms input, and 4ms output latency), minimun 10ms. Regards Dmitttri
