ultrasound
15 -
About ultrasound
- Birthday 01/01/1
Gender
Not Telling
ultrasound's Achievements
Hi I'm looking for somebody who can help me with led groups for buttons [notes] example: While pressing button #1 - the led under the button will turn on While pressing button #6 - the led under the button #1 will turn off and the led under button #6 will turn on I have one group of 10 buttons with leds and another group of 10 buttons with leds, and i want that groups of leds work independently. So that, when I push the button from 1st group and the button from 2nd group, they both led will be turn on. But when I turn on, for example, the other button from 2nd group, the led from the 2nd group will switch(the new one will be now shinning) but in the 1st group nothing will change. My controller (check the enclosure): group 1: 90x00 90x01 90x02 90x03 90x04 90x05 90x06 90x07 90x08 90x09 90x0A 90x0B Group 2: 90x1C 90x2C 90x3C 90x4C 90x5C 90x6C 90x7C Group3: 90x1D 90x2D 90x3D 90x4D 90x5D 90x6D 90x7D Group4: 90x10 90x11 90x12 90x13 90x14 90x15 90x16 90x17 90x18 90x19 90x1A 90x1B 90x20 90x21 90x22 90x23 90x24 90x25 90x26 90x27 90x28 90x29 90x2A 90x2B 90x30 90x31 90x32 90x33 90x34 90x35 90x36 90x37 90x38 90x39 90x3A 90x3B 90x40 90x41 90x42 90x43 90x44 90x45 90x46 90x47 90x48 90x49 90x4A 90x4B 90x50 90x51 90x52 90x53 90x54 90x55 90x56 90x57 90x58 90x59 90x5A 90x5B 90x60 90x61 90x62 90x63 90x64 90x65 90x66 90x67 90x68 90x69 90x6A 90x6B 90x70 90x71 90x72 90x73 90x74 90x75 90x76 90x77 90x78 90x79 90x7A 90x7B NEXT NOTES Of WHAT I NEED: 90x0C 90x0D 90x0F 90x1F 90x2F 90x3F 90x4F 90x5F 90x6F But leds for that and rest notes must be like that, I push the button>led turn on, I push the button again (turn off the effect)>led turn off Can anyone help me to change ain64_din128_dout128_v1_3 code? I hope, that all i wrote, it's not too knotty.. Best Regards Waiting for proposition
Hello I have an idea but i dont know how to do this: When i will press button #1 - the led under the button will turn on when i will press button #6 - the led under the button #1 will turn off and the led under button #6 will turn on ... and so on... ... and, how can i make some groups ? By groups i mean something like this: I have one group of 10 buttons with leds and another group of 10 buttons with leds, and i want that leds in only one group will switch betwen them. Greets
Hi I have uploaded ain64_din128_dout128_v1_3 to my PIC and i have connected 1x core + 2x AIN (no pots soldered, all unused pins are soldered to the ground) + 1x DIN (with only 1 button soldered). The problem is that i have foot controller on DIN, and i want to switch them to note-on buttons, how can i change it? Greets
Hello. Can someone help me finding some company that cuts aluminium panels from my project? How about prices? Is this affordable? I need them for my midi controller ;) Greets
Witam Czy znacie jakie? tanie firmy które wicinaj? panele w alu? Chodzi mi o panel do midi. Najlepsze chyba b?dzie wycinanie laserowe albo frez cnc. Jakie s? orientacyjne ceny? Pozdrawiam.
Hello. I need 128 note on/off buttons and 64 controllers (pots), and all 128 butoons on 1st midi channel and pots od second midi channel, as i assume i need 2 cores or is there some other way to get 128/64 in this configuration. Can someone create some step-by step instruction for PIC18F452 programming. Which software should i use and what parameter should i enter everywhere. Greetz.
"Loading Setup from BankStick" on startup problem
ultrasound replied to ultrasound's topic in Testing/Troubleshooting
So this is my new PCB, is this looks ok? On both PCBs i have the same message on LCD. Can you give me some step by step instruction how should i program PIC, with every radio button and value for selected sotware for MIDIBOX64. Im not shure did i programmed PIC propertly. We want to have 2 cores for 128 buttons and 64 pots, or is there some other way to have 128/64. Greetz -
It's the same situation with and without bankstick, it doesn't matter. On LCD is only "Loading from..." message and nothing else. -
Yes, by "stop" i mean that nothing else is happening. I see only "Loading Setup from BankStkick" message. It's the same situation with and without bankstick, it doesn't matter. I have 24lc128 EEPROM. Please tell me what exactly should i upload into empty PIC if i want to have 128 buttons and 64 pots, please give me some links. IS this ok? bootloader + mios 1.9d + main.hex from midibox64 2.4 via mios studio Greetz -
Witam Zaprogramowa?em PICa (bootloader + mios 1,9 + main.hex z midibox64 2.4 przez MIOS STUDIO) programowanie posz?o bezproblemowo. Gdy podaj? napi?cie do CORE monitor pokazuje info (F0 00 00 7E 40 00 01 F7), a na LCD poazuje si? komunikat: Loading Setup from BankStick (mruga) Formatting Bank 1 (mruga) MIOS V1.9d... i tak ca?a ta sekwencja powtarza si? kilka razy, a potem zatrzymuje si? na: Loading Setup from BankStick Pod??czony jest tylko CORE z LCD i nic innego. Czy wiecie mo?e w czym problem bo nie mam poj?cia o co chodzi i ju? zaczyna mnie to wkurza? :P POMOCY prosz? ;)
Hello. I have problem with my midibox64, i have programmed PIC (bootloader + mios 1.9 + main.hex from midibox64 2.4 via mios studio), mios studio monitor shows echo when i power on (F0 00 00 7E 40 00 01 F7), then on LCDisplay i have this message: Formatting Bank 1 (blinking) Loading Setup from BankStkick (blinking) MIOS v1.9... Formatting Bank 1 (blinking) Loading Setup from BankStkick (blinking) and then it stops on "Loading Setup from BankStkick" Where is the problem, is there my fault or is this some popular problem? Greetz
Witam Czy ma kto? koncepcj? na co? takiego: Chcia?bym u?y? diod do midibox64 w takiej konfiguracji: Gdy wcisn? przycisk zapali si? dioda ko?o niego, natomiast jak w??cz? jaki? inny z 64 to dioda z poprzednio wci?ni?tego przycisku zga?nie a zapali si? przy aktualnie wciskanym. Prosz? o propozycje jak to zaprogramowa? i ewentualnie wsad do Pica. Z góry dzi?kuj?, Maciej
Cze?? Mam do ciebie pytanie QBAS. Czy jest mo?liwo?? zaprogramowania przez ciebie uk?adu do MIDIbox64 oraz MIDIbox SEQ V3? Je?li mo?na to podaj mi swoj nr. Gadu Gadu. Mam te? kilka innych pyta?. Pozdrawiam
Szukam kogo? z trojmiasta kto moze pomoc przy budowie sterownika midi oraz seq. Co najwa?niejsze wgrac soft do pic'a. GG:9337449
