Is it just my build or is the lcd set quite far back from the front panel, leaving a noticeable "hole"? And the cs switches are making direct contact with the pads on the lcd. Am I doing something wrong? Also, what sort of screws are you using to fix the lcd to cs pcb? I've found everything about the MB-6582 quite well documented, except fitting the lcd. Cheers, Martin
