keefaz
    5
Everything posted by keefaz
  1. Ok, the sdcc upgrade to 2.8.0 solved the problem! the skeleton app compilation worked on first try Thank you stryd_one ! *I admit I hesitated before the sdcc upgrade because I had a working setup, but I wanted the advantages of the fabulous MIOS programming platform, very good job!
  2. BTW, when I use sdcc_skeleton_v1_9a as an app template, everything works fine! I write the programm, then run make command and it compiles/creates the project.hex, which I upload successfully in the PIC with MIDI via mios studio and the app run well.. [edit] The \r characters appear also in the project.lst created in the sdcc_skeleton_v1_9a template dir, so I guess the error in MIOS programming platform template is not caused by those characters... must comes from elsewhere.... At least I have a working solution, but I am curious and wonder why the new templates don't work on my system
  3. Thanks for the quick reply! sdcc -v SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.5.0 #1020 (Apr 17 2007) (UNIX) And the output from make command in the apps/templates/sdcc_skeleton dir rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output sh /home/keefaz/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/keefaz/mios/include/asm -I /home/keefaz/mios/include/share -I /home/keefaz/mios/modules/app_lcd/dummy -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/keefaz/mios/modules/mios_wrapper /home/keefaz/mios/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o sh /home/keefaz/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/keefaz/mios/include/asm -I /home/keefaz/mios/include/share -I /home/keefaz/mios/modules/app_lcd/dummy -DDEBUG_MODE=0 /home/keefaz/mios/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o sh /home/keefaz/mios/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -I./src -I /home/keefaz/mios/include/c -I /home/keefaz/mios/include/share -DDEBUG_MODE=0 main.c -o _output/main.o Processor: 18f452 sdcc: glue.c:1318: pic16emitStaticSeg: Assertion `0' failed. Caught signal 6: SIGABRT make: *** [_output/main.o] Error 1
  4. Hi all, I have a problem with the new MIOS programming platform developement I can't compile programming examples/templates in the apps/ directory The error is: sdcc: glue.c:1318: pic16emitStaticSeg: Assertion `0' failed. Caught signal 6: SIGABRT make: *** [_output/main.o] Error 1 Now I looked into the _output/app_lcd.lst file and I see that there are a lot of Macintosh newline characters (marked as ^M in vim, it is the character 015 or \r, the newline character on linux should be 012 or \n) I don't know if it is relevant though... I looked all the files in $MIOS_PATH/modules/app_lcd/dummy/ but I do not see the \r character on those files... How the _output/app_lcd.lst is created ? I am newbie into Mios programming, but I success to write an application and compile it with an old Makefile (not with the new MIOS programming platform) so I guess my toolchain is correct
  5. Hello, I would like to buy: 40 x "Quiet" 3FTL6 Thanks (First post but long time lurker ;))
