Elpy
    6
Everything posted by Elpy
  1. Thanx wicked1, I will dive again in this asm file ;) I will try it another time, if I'm in trouble again, I will ask you. thanks again ! 8)
  2. If your synth have 2 midi input, why not... but not sure... But I think you can do it with a Midi Merger. If you merge 2 midi signal with same channel, it should result in a 1 channel signal with the 2 information (CC from MPC and note-gate-... from Midibox Seq) ++
  3. Here is my FDP file : http://files.filefront.com/mbseq+v32fpd/;9145708;/fileinfo.html There is a lot of "missing" hole for led, but in fact, I'm planning to use buttons WITH LED inside. The Edit / Song / Pattern and layers buttons are same with differents shape. I found them in a french store. A print-screen : wicked1 : in fact I'm not a electronician nor a programmer... So : 1 / should I buy an other DOUT ? Because, I think that I will run out of output with only 1 DOUT. Is that right ? 2 / Is there a ASM file already made for additional buttons and LED ? I tried to read this file, and I know it's only a "text adventure"... but I'm definitly not Idiana Jones ^^. So if you have ever modify it, could you post it ? Thanx for you help
  4. I have done it. I will post-it tomorrow cause I don't have it here. But I'm still confusing about wiring and compiling the right asm file... Is anyone done the complete wiring and modifiyng the asm file ? And if done, could this person post it ? See you tomorrow ;o) ++
  5. Salut et merci pour le début de réponse. En fait, j'ai continué ma quête en fouillant ucapps et le wiki (un peu mal foutu d'ailleurs... m'enfin) et j'ai enfin compris le principe global du projet. J'ai également trouvé le .asm que l'on peut modifier. Effectivement ce sont des question plus lié à la prog. Et c'est ce qui me fait peur, j'ai pas trop de mal en soudure, mais là j'ai rien compris au programme... notamment dans le cas où je veux mettre les led supplémentaire de la V3 et les boutons supplémentaire, j'ai rien trouvé qui l'expliqué clairement. M'enfin je vais commencer de toute façon (c'est déjà commandé) et je ferais la face avant en dernier... ++
  6. Hello les gens ! Je suis arrivé sur le site y'a qq jours, et j'épluche le forum, les différents modules afin de trouver le step séquenceurs idéal. Apèrs avoir cherché sur le net, ce que je cherche est le P3 Sequencer de chez www.sequentix.com (by Colin Fraser). A mon grand regret, celui-ci n'est plus fabriqué, et les PCB non dispo :'( Bref, j'en viens donc à éventuellement une MidiBox SEQ V3. Déjà que pensez-vous des possibilité de la MB par rapport au P3 (pour ceux qui connaissent) ? Et sinon quelques intérogations reste sans réponse avant de me lancer à corps perdu dans l'aventure ;D 1/ J'ai compris qu'il y avait 4 tracks par patern, ok, et la possibilité de jouer 4 patern en simumltané, ok, tout ca pour avoir 16 tracks. Il est aussi possible de chainer 4 paterns pour avoir 128 pas, ok. MAIS, est-il possible de chainer 4 patern de 4 patern de long pour avoir 16 track de 128 pas ? 2/ Ensuite le coup des layer. On a à dispo 3 layers pour les encoderts et 3 pour les boutons. Bien, mais si par exemple mes 3 layers d'encoders sont tous sur note, il va me jouer des accords de trois note tous les pas, ca on est d'accord, mais quelle sera la vélocité ? la longueur ? bref les paramètre de base des notes midi ? Je crois que je n'ai pas compris le coup des layers... il sont défini pour chaque track ? et une fois défini ils sont modifiables ? (par exmple pour jouer 3 note par pas, mais avedc des valeurs de vélocité et de longueurs différents) 3/ J'ai pas trouvé, et la question est sans doute oui, mais qu'en est-t-il d'une fonction Tie (c'est à dire une fonction qui maintien la note sur plusieurs pas.) ? 4/ Est-ce possible de mettre des boutons leds à la place des boutons et des led. C'est à dire d'avoir des équivalent de pad type MC 808-909 ou Electribe ? 5/ est-t-il possible d'avoir plus d'encodeurs (ex 2 lignes de 16 encodeurs, toujours avec un seul affichage, mais 3 layers par lignes encodeurs). Il me semble que ce n'est pas possible, mais dans ce cas, pourquoi une MB64E en est t-elle capable ? 6/ Apparemment on selectionne les layers via 3 boutons (A, B et C), mais peut on avoir 6 boutons ? (3 pour les layers des encoders et 3 pour les layers des boutons, et les selectionner indépendament ?) 7/ Pis la question à la con : si j'ai bien compris, tous les paramètres sont éditable sant stoper la bécanne. Est-ce que qqun peut me le comfirmer ? Merci d'avoir eu la patience de lire ces anneries ;D et marci pour les futures réponses. Et bon son ! ++
