troek
15 -
About troek
- Birthday May 1
Gender
Male
Location
Netherland
Interests
elektronica and music
troek's Achievements
Hi Thorsten thnx for helping, it's the resistor that wasn't working properly. :angry: now it's working fine. (you deserved a beer!!!) hope I can call again for problems ? :blush: thnx and mzzl Koert
Thorsten, The loopbacktest is good, but with te same delay :pinch::( Yello Led continu after short time red led also continu with delay after last signal that sending. But if i have the ribbon cable, J4 to J2 in the hand than is the delay much shorter. if i have to leave the ribbon cable the Delay is the same long time. Its not a broken conecting. Best Regards, Koert
Thorsten, De 4 Ri lines checked it's ok there 4 modules connected the IIC_MIDI_MAX_NUMBER checked the max st to four I have the J4 and the J2 connected with ribbon cable can that and problem? if i have J4 and J2 connected with experiment cable sometimes is the delays shorter but never go way. I have a niuew cable make but ist same delay en hang up. Regards, Koert
hi thnx for replying my testing setup contains roland rd 700sx -> iic module (input) korg tr 61 -> iic module (input) alesis s4 quadra -> core module (output) when i'm playing we notice a delay which gets higher the more notes we play, and finally it stuck. when we put te roland master keyboard on the input of the core module & the alesis on one of the ouputs of iic module whe don't notice any delay ps -> for the white list midi interfaces on mac -> motu 828 mk3 (firewire) regards koert
Hi, If i sent a midi signal to the core module then i have no delay from the IIC modules?? if i sent midi to the IIC module then i have a great delay from the core output????? Thanks Vd weerd
Good evening , Is it possible that this project (midi router) only works with a old version of mios? Thanks all. Koert
Hi, I have build to make a midi router * 1 core pic based 17f452 (burnd with bootloader_v1_2b_pic18f452 and mios_v1_9g_pic18f452) Router software midi_router_v1_1c * 4 IIC MIDI module pic burnd with mbhp_iic_midi_v1_0c * 1 DINX1 but not connected After very long time to build and program (wrong interface etc.) The note to sent via mios studio or instrument to the port in of the IIC midi module coming with very great delay back from core out poort (1 a 1,5 sec) I have look on this forum but not found Thanks
Ok, a other interface and yes, mios installed and midi router right thats it i think
Thorsten good evening, Thanks for very fast answord. Blacklist YES E-MU midi1x1 Tab i looking for a other interface, Thanks at this moment i let you now Vd Weerd
Core 18f452 All checks from site testting and correct. bij conect core to pc en mios studio 2.1 "boot loader is up and running" if i load the mios to the core ,it's during 1 houre, its after that "boot laoder is up and running"grrrrr :mad: the pic burning with loopback programa is perfect working The pic burning with old version 1.9 also its not upload mios to the core what do I wrong. Please help Troek
Thanks a lot It works great. Thanks
Hi, Very tricky from me :shocked: ,But do you have some old code ?????? with that function that whe can experince? C programs is not my thing. :blush: thanks
hi thanks for the fast respons :thumbsup: but its not what i was looking for :unsure: on the site i've found a block diagram which says on input iic3 -> only channel 16 -> split notes <c-4 or >=c-4 and then change the channel and send them to ouputs iic3 an iic2. I can't find this in the code. It might be possible that the code has changed without changing the diagram grtz
hi i'm sorry for the crossing The router works great except the note splitting on the last input. All midi signals on input 5 is going directly to output 4 and 5 without the note and following channel split.
I have build the router and... its working!!!!! all poorts are sending from and to with on an off. IIC2 its sending chn.<9 to INT0 and >9 to IIC0 and IIC1, thats all right. But the keybord on IIC3 DON'T split anyway its sending all notes to same . I have software versie from midi_router_v1.1c. (v1.1b working de rotary/encoder not good) please help :sad: Best Regards, Troek
