Logo
    10
Everything posted by Logo
  1. So I've been successfully using my MB64 for several months with out it falling apart (yay!), but I've recently noticed the LED backlight fluctuating every now and then. I can only notice it when viewed at an angle and it seems somewhat related to moving controls. It happens maybe every couple of minutes or so. I suspected it must be a power issue, maybe related to using a switching power supply, but it does it on my linear bench power supply as well (both far exceeding it's current requirements). Is this normal? It doesn't really bother me, I just want to make sure it's ok, and won't potentially damage anything. Thanks in advance...
  2. I guess they are pretty clicky, but clicky is awesome in my book. You get solid visual, audible, tactile confirmation that says "yup, I just pressed that button" :)
  3. Thanks again everyone :) No, just a nice white on black lcd. Spark Fun carries some cool ones. http://www.sparkfun.com/commerce/product_info.php?products_id=709
  4. Thanks. They are adhesive plastic pcb posts, they're pretty sturdy and save a lot of time. I highly recommend them. I found them at Mouser http://www.mouser.com/Search/ProductDetail.aspx?R=561-LAD250virtualkey56100000virtualkey561-LAD250
  5. more pics
  6. I'm not sure if this the correct forum area to post this, but I have finally finished my first MIDIBox64 based project I started in 8/07 (I'm slow/lazy :) ). I had many false starts and headaches making it, but it was entirely worth it. I plan on using it for Live and Traktor DJ sets, as well as simple Max/Msp sequencer patches. Overall it cost about $400 USD (but would of been much less if I didn't splurge on nice faders and make a bunch of incorrect orders). It consists of 1 Core, 2 DIN, 1 DOUT, 1 AIN. Info that might be of help to others: -Bourns makes a very nice DJ Style fader that you can order in the US from Mouser (though only in 60mm length) http://mouser.com/search/ProductDetail.aspx?qs=b8viKDOLiXaWB8SJ8GW14g%3d%3d -Wilba's JB Weld trick for panel mounting pcbs works very well. -When ordering parts always order enough! I say this after 4 orders to Mouser and about 3 to SmashTV. Thanks to TK and the entire community. This is a truly amazing slice of the internet... Larger pics here http://www.flickr.com/photos/williamsphotos/sets/72157605027766384/
  7. Thanks for the reply and incredible platform :) . Thankfully its only 16 pots to shuffle around. edit: Also please forget my question about led assignments. It's obvious to me now
  8. So I'm a little bit lost when it comes to changing pin assignments on the ain, din, dout. So far I have all the pots on my MB64 working, but they are out of order for the sake of clean/easy wiring (same will go for the rest of the 32 buttons/leds I have yet to wire). From what I have found the relevant files to modify are MB64.ini (which then must be converted to sysex) and Main.asm (which then must be compiled into a .hex). I think I've found the relevant sections in the commenting of both files, but the code looks foreign to me (I have very little coding experience). Could someone give me a quick rundown of the reassignment process? Also how are leds assigned to buttons? Thanks and sorry for my newbieness...
  9. Electronics Goldmine is selling the MEC 3F w/ red led at 5 for $1 http://www.goldmine-elec-products.com/prodinfo.asp?number=G15660. The bad news is you have to find your own keycaps. I ordered mine from Newark at $0.58 a piece plus a $15 import handling fee. Add on the price for replacement leds in the color of your choice, and it's a pretty good deal.
  10. I was searching for a decent DJ style fader for a while, and the best/cheapest I could come up with was the Bourns PTS series http://www.bourns.com/pdfs/PTS.pdf They feel really nice compared to everything else readily available (sturdy, looser than most standard faders... but not really scratch fader loose). Unfortunately, I could only get the 60mm length in the US from Mouser in single quantities http://www.mouser.com/search/ProductDetail.aspx?R=PTS60-02L-103B2virtualkey65210000virtualkey652-PTS60-02L-103B2 I think Numark is actually using this fader in some of their mixers (since it looks identical to this http://www.numark.com/content35551.html )
