Hi. I completed my sammichFM tonigh, or so I thoughtt. I uploaded the firmware, got the rhodes sound, everything appeared to be ok, but none of the controls work. Three LED's are lit (the top left 2, and on the bottom row second from the left). No response from any buttons or the encoder or any of the other LED's.
FWIW, to the best of my knowledge all the voltage and continuity tests came up fine.
Now, some background, or what I think the problem could be. When i was building the control board, some solder fell from the iron while tacking and got in the hole for pin 16 on IC2. Whilst removing said solder I accidently lifted the solder pad. Also before I noticed the solder in the hole, I pushed the socket in and broke of the end of the socket pin. So, here is where things get dicey.
First off, I did not get rid of the socket (so, so dumb). I just flipped it over, becuase it looked like pin 8 had no traces going to or from it and was unused (though I never checked any schematic). For the record, the chip is orientated correctly, I just followed the marker on the board and ignored the reverse socket.
Second, I follow the trace from pin 16 of IC2 and it appeared to just run to a resistor network RN4 I believe. So I soldered a jumper from pin 16 on the socket to the correct pin on the resistor network. I tested continuity, it checked out ok.
So, any idea's on what's up? Was it my butchery, or something else? Any help would be most graciously appreciated.
Thanks.
Matt
