Thanks for the hint... I will investigate this simple project which uses 12F629 to convert midi to din sync. I'd be more interested in RESET-trigger than start/stop pulse though. Now if the master midi clock is reset, the slave sequence stays in sync, but is out of beat. So the slave sequence would have to be manyally reset at tick 1 (or by pressing stop and start in some cases). So it's not actually sync-standard, but a trigger at every 1:st tick that is easily adapted to analog sequencer use. I'm in impression that it could be accomplished by midibox CV. Anyone knows if this is possible with mbsid also (using aout_lc or not) ?
