Hello Audio Commander,
I am having a good time with my speakjet project and am glad you have published your work. I have put the gesture frame together first, because I can use it straight away - wired into the analogue inputs of a kit-built monome, it works very nicely. The more I have thought about it, the more interesting the design layout of the sensors is, maybe it was obvious, but I would never have started out with that configuration. As one thinks through other possibilities it becomes apparent that it's a very smart layout.
I have kitted-up the speakjet board including the MAX chip (had to go to the USA for that) and bought spares in case of 'mistakes'. I will release the spares into the wild once all is built.
The next stage has been the MBHP PIC burner, which is all soldered up, running on an original Trace Elliot compressor wall wart, and has so far failed to kill my laptop :) The power supplies seem to work right and present the right voltages to the IC sockets. I have tried a preliminary test with P18 burner software, but the board is not recognised (there is no PIC in yet).
I have two questions:
Which is the best software to connect to MBHP PIC burner? I have loaded Sprut's P18 software on my PC and it certainly looks good, but seems to be for PIC 18xxx only, whereas we are trying to programme a PIC 16. Obviously, it needs the 40-18 pin adaptor and 13.1V, but should I use different software?
Do I need to have the PIC IC mounted in the socket in order for the software to recognise the board?
OK, I found the right page: it's PBrenner37 or 37U - also the board not found message box gives four steps to check, including having the PIC in place.
Regards, Chris.
