yoho
8 -
Everything posted by yoho
Hi all, I just stopped by to check if my experiences are right... 1 In my mios c program (user_tick function) i used a modulo division like counter%divider and divider was a unsigned, non zero value, which caused the program to crash and the pic to start over. Using a number did't. I could think of workarounds, but I am curious to hear yours 2 the same happened with 3 nested ifs, again I am working on a workaround, but I am equally happy to hear yours. Is there a list of Mios8 don't in C programming?
Hi all, I found at the attic my never finished V3 seq. Decided to finish the build, but the soldering guide at ucapps.de is gone. I know it's not difficult, I saved most of the documents earlier, but I missed ie. where the caps at the pcb side should go. Anyone has a document or the pictures? Thanks a bunch!
Thanks TK. I can compile again... and again. But there no installing on an iPad, because I don't have an developer account. Any chance somebody could include the installable app here, or is impossible install it that way?
Hi all, I checked the source out to have a look, but things aren't compiling/linking. Can somebody explain? I added ../mois32 to the searchpath, but I'm still left with a couple of link errors. Cheers!
After being offline for half a century: Getting one of the leds to show the shift status in this case the beat-led. In seq_leds.inc just after SEQ_LED_UpdateIRQ_NoBeat movlw DEFAULT_BEAT_INDICATOR_LED call MIOS_DOUT_PinSet insert this #if DEFAULT_SHIFT_ENABLED ;; Erik : update shift led SET_BSR SEQ_BASE clrf MIOS_PARAMETER1 BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, SEQ_LED_UpdateIRQ_NoShift SEQ_LED_UpdateIRQ_Shift setf MIOS_PARAMETER1 SEQ_LED_UpdateIRQ_NoShift movlw DEFAULT_SHIFT_INDICATOR_LED call MIOS_DOUT_PinSet #endif ;; ---[ increment the LED row counter (used when DEFAULT_TRACK_LEDS_ENABLED set ]--- In setup_mbseq_v2.asm add this #define DEFAULT_SHIFT_INDICATOR_LED 0x07; And the shift led should work... To have the gp leds working with the shift go to seq_leds.inc again and edit SEQ_LED_UpdateIRQ_GPLED ;; transfer current LED pattern to IRQ_TMP[12] movff SEQ_GP_LED0, IRQ_TMP1 movff SEQ_GP_LED1, IRQ_TMP2 to look like this SEQ_LED_UpdateIRQ_GPLED ;; transfer current LED pattern to IRQ_TMP[12] #if DEFAULT_SHIFT_ENABLED BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, SEQ_LED_UpdateIRQ_GPNoShift movff SEQ_GP_LED1, IRQ_TMP1 bra SEQ_LED_UpdateIRQ_GPEndShift SEQ_LED_UpdateIRQ_GPNoShift movff SEQ_GP_LED0, IRQ_TMP1 SEQ_LED_UpdateIRQ_GPEndShift #else movff SEQ_GP_LED0, IRQ_TMP1 movff SEQ_GP_LED1, IRQ_TMP2 #endif I skipped the one-button-track-change for now. I thought it is better to focus on the display changing steps with the shift status. Here's the challenge in seq_buttons.inc, first part we've seen before, how do I get this to work? ;; -------------------------------------------------------------------------- ;; Enable to shift ;; -------------------------------------------------------------------------- SEQ_BUTTON_Shift SET_BSR SEQ_BASE #if DEFAULT_BEHAVIOUR_BUTTON_SHIFT ;; Toggle Mode (default): ;; exit if button depressed btfsc MIOS_PARAMETER2, 0 return ;; else toggle status btg SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED #else ;; On/Off Mode: ;; button status controls mode directly bcf SEQ_BUTTON_SHIFT_STATE, SEQ_MODE_SHIFT, BANKED btfss MIOS_PARAMETER2, 0 bsf SEQ_BUTTON_SHIFT_STATE, SEQ_MODE_NOSHIFT, BANKED #endif ;;Does this work??? BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, seq_set_no_shift bsf SEQ_EVNTS, 2, BANKED rgoto seq_set_shift_update seq_set_no_shift bcf SEQ_EVNTS, 2, BANKED seq_set_shift_update ;; request display update bsf CS_STAT, CS_STAT_DISPLAY_UPDATE_REQ return
I managed to find the solution myself: this code should be placed in seq_enc.inc SEQ_ENC_Handler ;; save encoder number in SEQ_CURRENT_STEP and SEQ_EVNTS SET_BSR SEQ_BASE ;; Altered for shift function BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, SEQ_Enc_NoShift ;bsf MIOS_PARAMETER1, 3 ;Erik Add 8 to the encoder number... well 7 but it works ?!? movlw 7 addwf MIOS_PARAMETER1, 0 SEQ_Enc_NoShift I'm off to the next challenges: doing a one-button track change. Up till now it looks like (in seq_buttons.inc) this but isn't working :-) ;; -------------------------------------------------------------------------- ;; Select Track 1/2/3/4 ;; -------------------------------------------------------------------------- ;; Erik: Different for single button here! ;;SEQ_BUTTON_Track SET_BSR SEQ_BASE movwf SEQ_SELECTED_TRKS,BANKED rlncf W, 1, 0 andwf 0xf rgoto SEQ_BUTTON_Trackx_Cont SEQ_BUTTON_Track1
Hi there, I have been inspired by the idea of MBSeq in a small box with not too much controls, 1 LCD and 8 encoders and some buttons and started working on a prototype. Due to parts I had, I started on a V2 seq, I had a "452" lying around :-) To implement a shift function this what I have done: in app_defines.h change ;; free: 0x16b to this: SEQ_BUTTON_SHIFT_STATE EQU 0x16b ;; free: 0x16b In seq_core.inc add this after the line with SEQ_MODE1_RECORD.. SEQ_BUTTON_NOSHIFT EQU 0 ; Shift buttons SEQ_BUTTON_SHIFT EQU 1 ; Ofcourse I added something like this to the setup*.asm (according to your own box) DIN_ENTRY SEQ_BUTTON_Shift, 3, 7 in seq_buttons.inc I added this after the SEQ_BUTTON_All function ;; -------------------------------------------------------------------------- ;; Enable to shift ;; -------------------------------------------------------------------------- SEQ_BUTTON_Shift SET_BSR SEQ_BASE #if DEFAULT_BEHAVIOUR_BUTTON_SHIFT ;; Toggle Mode (default): ;; exit if button depressed btfsc MIOS_PARAMETER2, 0 return ;; else toggle status btg SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED #else ;; On/Off Mode: ;; button status controls mode directly bcf SEQ_BUTTON_SHIFT_STATE, SEQ_MODE_SHIFT, BANKED btfss MIOS_PARAMETER2, 0 bsf SEQ_BUTTON_SHIFT_STATE, SEQ_MODE_NOSHIFT, BANKED #endif return In seq_gp.inc in function SEQ_GP_function I added this (some lines repeated for the right line) SEQ_GP_Button ;; request display update bsf CS_STAT, CS_STAT_DISPLAY_UPDATE_REQ ;; the menu select function overlays everything SET_BSR SEQ_BASE BRA_IFSET SEQ_MODE0, SEQ_MODE0_MENU, BANKED, SEQ_GP_Mode4_Button ;; This is new: setting the gp no according to shift state: add 8 = setting bit 3 BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, SEQ_GP_NoShift bsf MIOS_PARAMETER1, 3 SEQ_GP_NoShift up till now this is working ;-) well almost. The shift key does the job on GP buttons but, you can only see it working after pushing one... Pointers anyone? From here things get worse. I tried to "copy" this to the encoder function, but it is going wrong. I know that you have to add 8 to WREG but I didn't succeed in getting that working. The bit setting trick didn't work. So any help is appreciated SEQ_ENC_Handler ;; save encoder number in SEQ_CURRENT_STEP and SEQ_EVNTS SET_BSR SEQ_BASE ;;new: Altered for shift function BRA_IFCLR SEQ_BUTTON_SHIFT_STATE, SEQ_BUTTON_SHIFT, BANKED, SEQ_Enc_NoShift ;could be this ;bsf MIOS_PARAMETER1, 3 ;or this? addwf 8, 0, BANKED movf MIOS_PARAMETER1, W SEQ_Enc_NoShift This last piece of programming drama (being a pro: this brings me back to my programming kindergarten years) triggers all of them, but: all encoders are shifted one position: first enc does second value....last encoder does first value. And subtracting one from W just crashed the app. Can anyone shine a beautiful light? Cheers....
Hi there, I moved my post to the Asm forum;
With a :blush: i have to admit that it was a stupid thing forgetting the capacitor. I installed a cap under the pic (which is close to the lcd connector) and that worked! Thanks for the help! (note to self: don't save money on caps...)
Hi all, I have a core and some on a veroboard. It is working ok. With a 16x2 LCD with backlight. If I replace this with a 40x2 (without connecting the backlight) the core gets confused. It keeps restarting and sometimes shows the application but mostly can't get past the MIOS intro. After a couple of restart it stops al together. Changing back to the 16x2 solves the problem. Power is at a steady 5V and the core keeps shouting through MIDI out for a download... Can somebody give a pointer how to solve this? Could the length of the wire (15 cm= 6 inch) be the problem? I've checked the diagram and only thing so far missing are the two 100n condensors on the powerlines near the PIC. I know those are there for a reason, but I didn't install them because all my stock was consumed by another project. Cheers, Erik
CodeBlocks MIDIBOX GUI Simulator for Windows (based on ACSim)
yoho replied to Tokolos's topic in MIOS programming (C)
Has anyone succeeded in porting this for XCode?
