Xem
    42
Everything posted by Xem
  1. ill do it.. now is the seaside time!
  2. i valued this thing.. but the light should be uniform, like a little neon.. maybe in the future il could try, but for now i like the yellow text =D
  3. the first was taken using the flash .. the second without and the third is the bottom .. the yellow strips are for color the text on the top.. the bottom was black and whit the laser was made the hole and the text is grooved from the bottom.. so the black is gone.. =D the yellow fills the groove.. DSCF0005.JPG DSCF0006.JPG DSCF0007.JPG DSCF0005.JPG DSCF0006.JPG DSCF0007.JPG
  4. I've done it.. the glue works so well =D
  5. Hello, i built the 6582.. i finished everything and i'm so happy, but what break my happiness is the fact that 2 leds of the matrix can't turn on.. the strange thing is that they are inside the matrix (6 col, 3 row and 4 col 6 row), and the fact that another led had the same problem.. i added some iron and now it works.. i cant fix the other 2 whit the same method, they have enought iron now on each side. I've tested the joining and they are ok.. what could be the problem? thx ps. the leds works, putting 5 volt (whit the resistor) it light up pps.. is normal that all over the board some led are lightly lighted?
  6. has i wrote on an email i need sid.. but i want to be sure that they works perfectly.. have you found è good method to test them?
  7. why? is it so different 47k or 48k?
  8. i'll replace R4 whit that resistor.. thank you.. the led was on for less then 1 minute.. i hope it has not get damaged
  9. http://docs-europe.electrocomponents.com/webdocs/06dd/0900766b806dda1c.pdf
  10. hello.. i wired my lcd and i works very well.. but the backlight get so hot.. i verified the problem.. i noticed that the P1 should regulate the current on it.. turning it do not change the lum of the led.. the volts at the a-k is always the same (5,2v) Is this normal? what should i do? -- ps.. wops.. i forgot to say what i'm speaking about.. the project o built is the mb-6582
  11. ok, thank you.. i'l keep this in mind..
  12. Hello.. i made a panel on plexiglass cutted whit laser.. on the bottom-side it is black painted. i'm about to attach the bolts and the threaded spacers to the pane.. does the jb-weld corrode the platic or the paint on it? thx .. NoOne can help?
  13. hello! i built a mb-6582.. but i have to the do last step.. SIDs! is normal that sids sounds differently? expecially the volume of 6581s is more loud.. there is a way to regulate it?
  14. yep, noticed this..
  15. link fixed.. so.. are they problematic? i'll buy them from voti
  16. but those whit "nice shiny knobs" costs 13 AU$ -> 6.20€, it's soo much! umh.. voti.nl sell the knobs too.. i did not notice this.. i need the 13 tall switches too, where could i find these? i found this knobs in an italian shop: http://www.elettronica-hobby.com/catalog/index.php?cPath=86_39
  17. Hello! i'm going to build the MB-6582, i have to buy just the encoders. i found this encoder on ebay: http://cgi.ebay.it/12mm-Rotary-Encoder-Switch-With-Keyswitch-10pcs_W0QQitemZ370190020165QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item370190020165&_trksid=p3286.c0.m14&_trkparms=72%3A1385|66%3A2|65%3A12|39%3A1|240%3A1318 is this good? i compared the datasheet i think they are very similar, am i right?
