Hi,
After an unsuccesful build attempt in 2006, I'm now an LCD upgrade and a couple of hours of grinding and screwing away from completing my Midibox sid. So, before I begin with my possibly pathetic questions about how to alter the code, I guess a quick thanks are in order for Thorsten and Tim.
So here are my questions
1: Besides the general compiling tutorial, is there a tutorial kicking around somewhere detailing how to change the key assignment for a DIN module? I'm going to be using a 2x40 LCD because it fits the case better and is easier to parse, but I was a humanities major and not an engineering major. While the mechanical and electronic side doesn't give me too much trouble, code kind of makes my head spin and it's been years since I've had to put together a tool chain or use an IDE or, you know, pretty much anything related. Any help to make this simple for me would be greatly appreciated. Specifically, I need to add in the 5 extra menu buttons and map them to the appropriate pins on the DIN.
2: This is the much more difficult and, ultimately, more important question: Is it possible to alter the OS to support micro and macro tonal scales? Neat as it is, if I'm stuck with 12 tone equal tempered, my SID friend is probably not going to get a lot of use. Ideally I'd like to be able to dump either .tun or midi tuning standard format tunings to the thing, be able to store them on a bank stick and assign them in patch. "Hard coding" a single tuning as part of the mbsid program would be, I'm sure, a lot simpler and also, I guess, pretty acceptable. Sadly, man, I don't have the slightest idea of how to even begin doing this. Again, any help would be appreciated.
