AC
    19
About AC
  • Birthday 01/01/1
  • Gender
    Not Telling
AC's Achievements
MIDIbox Newbie
  1. Hi! It´s looks to be XTAL 10MHZ, C1, C2, if out of frequency or internal bad contact can reboot the CORE. I hope this help you.
  2. Aqui +1 para a vaquinha Na farnell tem +de 500 peças R$31,37 + impostos/sedex http://www.farnellnewark.com.br/cimicrocontrolpic18fxxx40mhz40pdip,product,89H0709,1271.aspx
  3. Hi, May be this is not new for advanced users. This XR-2206 Monolithic Function Generator is very usefull to use with analog out module, for example to control 3x XR-2206. Low-Sine Wave Distortion, 0.5%, Typical Excellent Temperature Stability, 20ppm/°C, Typ. Wide Sweep Range, 2000:1, Typical Low-Supply Sensitivity, 0.01%V, Typ. Linear Amplitude Modulation TTL Compatible FSK Controls Wide Supply Range, 10V to 26V Adjustable Duty Cycle, 1% TO 99% Waveform Generation: Sweep Generation AM/FM Generation V/F Conversion FSK Generation Phase-Locked Loops (VCO) FM OPL3 and SID are hard to find parts, so this XR are too cheap and easy to find. Any inputs are wellcome, let´s do it. XR2206v103.pdf XR2206v103.pdf
  4. Yes, I discovered this today that we dont need core connected to listen the sounds from keyboard, this is too simple, I did many search here but there is nothing about this.
  5. That´s OK I´m stopping by now and reading/learning: Introduction to uCApps.de http://www.midibox.org/dokuwiki/doku.php?id=introduction_to_ucapps.de - recommended reading! 98% of all newbie-questions in the forum are answered in here Thanks for all inputs
  6. OK this first lesson I got it and is OK. Now the second lesson. Was loaded the MIDIbox 64e I'm using the MIOS Studio midi keyboard controler, MIDI has DATA out but no audio on the PC. There´s only 5 pots in unmuxed mode(J5)
  7. Yes Pin 25 is TX sorry for my confusion. mios_v1_9f_pic18f4620.hex was programmed s_v1_9f_pic18f4620.hex was uploaded You said "Next is to upload your application" What this mean?
  8. Hi!! There is a PIC ID Value Calculator here http://www.avishowtech.com/mbhp/idgen.html For PIC18F4620 PIC ID Header: 0000 0000 0000 0000 This is the same I´m using but no way, no DATA on pin 25. This is the LCD message start: MIOS V1.9f © 2007 T.Klose and them READY I´m feeling too bad, why me???
  9. Thank you for your help. Elnec SmartProg2 is a profissional programmer, this is best them ICD2BR, I have beem programed DSPIC/PIC/ATMEGA88/AT90S2313 and many others. Flash Microcontroller Programming Specification "39622F.pdf" page 9; "Users may store identification information (ID) in eight ID registers. These ID registers are mapped in addresses 200000h through 200007h. The ID locations read out normally, even after code protection is applied." SmartProg2 GUI let user store ID location. Could someone provide correct ID location for 16F4620? ID Location 1=? ID Location 2=? ID Location 3=? ID Location 4=? ID Location 5=? ID Location 6=? ID Location 7=? ID Location 8=?
  10. Now LCD is READY not DEAD. I´ll try to explaim step by step all procedures for newbie like me. Please look PDF for more clear undestanding, english is not my native language and some time I have some difficulties to explaim what I´m thinking. 1-I made my mbhp_core_v3b using an universal PCB this is very easy to build and better them protoboard, anyone can do this without buyng an industrial PCB. 2-For people like me that have a programmer like SmartProg2, you must check "Ignore Microchip Recommendation to let most Significant Niblle of each ID to be Fh" this is the secret for not have anymore "Received Unxpected MIOS SysEx message" 3-Take care with MIDI IN/OUT, "Rear View" means exatily "Rear View" see this in PDF atached, that show MIDI Front View. But here I have no "FLOWERS" there´s no DATA outgoing pin 25 TX, PIC is not dead, I did MIDI OX tests and before upload mios was receiving DATA on MIDI MONITOR IN Well, any suggestion??? Upload.pdf Upload.pdf
  11. I did software implemented loopback test with MIDI OX, everything OK. I´ll try this tomorow MIDI-OX.pdf MIDI-OX.pdf
  12. Fixed? this is not true... Started again Erased all PIC18F4620 LCD is new one. Uploaded mios(look pdf) Everything looks ok but, display is dead and no sound. MIDI IN receiving DATA but MIDI out there is no DATA, PIC clock is 10mHz. What is the magic way to work? Upload.pdf Upload.pdf
  13. I fixed the problem "Received unexpected MIOS SysEx message = 00007E407001F7 expected = 00007E4002" Was very easy the solution, "Upload Option" "Device Option" change to 70 for 18F4620 Midi input/output comunication is ok, but no sound, any ideia? LCD is dead, this is an old one, will buy new LCD. Thank for all inputs.
  14. Manual mode, Delay 500, but LCD is dead. Sending block #1 00000400-000004FF Sending block #2 00000500-000005FF Sending block #3 00000600-000006FF Sending block #4 00000700-000007FF Sending block #5 00000800-000008FF Sending block #6 00000900-000009FF Sending block #7 00000A00-00000AFF Sending block #8 00000B00-00000BFF Sending block #9 00000C00-00000CFF Sending block #10 00000D00-00000DFF Sending block #11 00000E00-00000EFF Sending block #12 00000F00-00000FFF Sending block #13 00001000-000010FF Sending block #14 00001100-000011FF Sending block #15 00001200-000012FF Sending block #16 00001300-000013FF Sending block #17 00001400-000014FF Sending block #18 00001500-000015FF Sending block #19 00001600-000016FF Sending block #20 00001700-000017FF Sending block #21 00001800-000018FF Sending block #22 00001900-000019FF Sending block #23 00001A00-00001AFF Sending block #24 00001B00-00001BFF Sending block #25 00001C00-00001CFF Sending block #26 00001D00-00001DFF Sending block #27 00001E00-00001EFF Sending block #28 00001F00-00001FFF Sending block #29 00002000-000020FF Sending block #30 00002100-000021FF Sending block #31 00002200-000022FF Sending block #32 00002300-000023FF Sending block #33 00002400-000024FF Sending block #34 00002500-000025FF Sending block #35 00002600-000026FF Sending block #36 00002700-000027FF Sending block #37 00002800-000028FF Sending block #38 00002900-000029FF Sending block #39 00002A00-00002AFF Sending block #40 00002B00-00002BFF Sending block #41 00002C00-00002CFF Sending block #42 00002D00-00002DFF Sending block #43 00002E00-00002EFF Sending block #44 00002F00-00002FFF Sending block #45 00003000-000030FF Sending block #46 00003100-000031FF Sending block #47 00003200-000032FF Sending block #48 00003300-000033FF Sending block #49 00007C00-00007CFF Sending block #50 00007D00-00007DFF Sending block #51 00007E00-00007EFF Sending block #52 00007F00-00007FFF Upload of 13312 bytes completed after 26.0s (0.5 kb/s)
  15. Thanks for too fast answer but same problem here. I have DSO 100mHz, pin 25 TX and pin 26 RX are OK
