Hello all,
I'm designing a PCB to hold approx. 16 tactile buttons and LEDs. My question concerns grounding. I'm wondering if I can simply create a ground plane on the PCB and tie all of the LED and switch grounds to the same plane, and return this to a common ground with the DIN and DOUT grounds. By this I mean: combine the LED and switch grounds on the PCB and run a heavy-gauge ground wire to a common ground on another board, likely the PSU board somewhere (near where the DIN and DOUT board grounds connect).
Or, do I need to group the grounds for each bank of 8 switches and LEDs and return this ground back to the DIN and DOUT modules, keeping the LED grounds and switch grounds separate, and keeping each set separate as well.
Obviously if I can combine the grounds this makes routing the PCB MUCH easier. However, I'm wondering if there's a reason not to do this.
Thanks - Andrew
