baptistou
Programmer
    54
Everything posted by baptistou
  1. Yep, it's OK. Thanks!
  2. hi there! The SVN server has been refusing to connect me the whole day, is it a problem from my side or is it temporary down for everybody? I get this: "Can't connect to host 'svnmios.midibox.org': Connection refused". Baptistou
  3. Hi Kyo I got that SVN stuff working easily with the free svnX software. Thanks for the trick! And about the compilation process on Xcode 3, any help? Baptistou
  4. Hi all! I'm not sure if I should have put this post under the topic for XCode, but as I haven't found anything for MIOS32 yet maybe it's a good idea to start a new topic. Well, here's my question: I just got my STM32 core, soldered it, made it run and checked with MIOS Studio 9 on my Mac OS X Leopard MacBook. So the first step is done. Now I'm having trouble building apps through XCode. I did it for MIOS8 projects and it worked fine, but I don't really know if it's all the same for MIOS32 or if I need to get some other libs for the STM32, how to tell the compiler about that and everything. I'm a bit dumb with scripts, makefile and compilers. In the Wiki the application development page seems only be for the MIOS8, where could I find a step by step tutorial for the MIOS32? Another small question: is there a simple way to download the code for examples? I can only see the files one by one, copy them and save them in a text file with that WebSVN. Can't we just clic and save them? or even better get an archive with all of them? Thanks for everything Baptistou
  5. Thanks Thorsten for your advice. I just recieved a CORE32 kit from smash TV, I'll try as soon as it's all soldered! Baptistou
  6. Hi! I would like to connect some serial interaced devices to my midibox project, but then they will need different baudrates: mainly 4800 for the NMEA devices (a GPS for example) and mainly 9600 for the others (more classical baudrate). Does anyone here knows how to handle that? I would like to do some trials with a PIC based core that I already have made, and my final project will be with and STM32 and I will probably want to have two serial interfaces, one for a GPS and the other for an AIS (it's a navigation system). I think that I will be able to set both to 4800 bps, and as the STM32 core has two midi ins an outs I will probably be able to convert them to serials connexions (MIDIbox-to-COM concept). Does anyone has advice about this? My main problem now is to set the baudrate at 4800 or 9600bps. Thanks all. Baptistou
  7. It looks like I only have to put something like TRISCbits.TRISC5 = 0 or 1 I'll try that as soon as I have the time, thanks for the help!
  8. And how do you set the pin direction? Thank you for your help, these are easy syntax but hard to find when you are a newby like me!
  9. And can you read these ports so easily as well?
  10. Hi there! Does anyone can give a C code example on how to use the "free to use" pins like J10 SO and RC? I'm using X-code and I would like to use these pins to do a PWM signal to control a servo. For a servo it's not real PWM signal but rather a high state during between 1 millisecond (0%) and 2 milliseconds (100%). As the DIN registers are refreshed only once per millisecond it's not precise enough for me. I hope that by using a timer and these pins I should be precise enough without having a code too heavy. Thanks in advance! Baptistou
