spufuz
    2
spufuz's Achievements
MIDIbox Newbie
  1. Ok! Great! Yes im aware of the relay-switching in the PbD but the thing is that im planning to use the "midi-switch" in my 19" rack and have all my pedals there along with the G-Major. But i don´t se that it would be any problem to hook it up that way then! Ok, i´ll just use a pot then? Im lucky enough to work in an workshop so i´ve got the sheet-metal and the tools to build my own enclosure for the PbD. But im also thinking of this one, 1456RL1BKBU. It has about the same measurements as the Voodoo Lab Ground Control! //david
  2. Great project Durisian! I have a few questions if you don´t mind? :rolleyes: In your manual for the PbD you write: Hooking it all up * MIDI merger should be OFF * MIDI out of Pedal Board to MIDI in of your device * MIDI out of your device to MIDI in of Pedal Board Im planning to control this unit with the PbD, but it has no MIDI OUT-jack that are supposed to go to the MIDI IN of the PbD. My question is, do i really need to use the MIDI IN jack on the PbD and what is it used for??? Next question: Do i have to use an expression-pedal to scroll in the setup-menus in PbD-mode? Are there any buttons assigned for that? I know bank up and down is used for selecting and save and exit but is it possible to use two extra buttons instead of a pedal? Last question: You write that the PIC18F4620 should be used in the MIDIBox Core. Is it possible to use an PIC18F452?? //David
