danne71
8 -
About danne71
- Birthday 09/10/1971
Gender
Male
danne71's Achievements
Hello Peter Yes You Right ...Thanks Thorsten !!!! But you wrong at the "more Demands" READ My second question in my first entry... Best regards Dan Lind Sweden
my patience is at a end... Why cant things be simple and logic? Maybe i try again in a year or two ...
Of course the AOUT_NG doesent work.... :frantics:
Yes. No parallel happenings now :thumbsup: ' But now to the Simpler Question? How do I get the MBSEQ to send 64 Triggers ? Please Explain all steps! (menu, event,type, port, channels and so on...) and how to choose the trigger number. /Dan
I have checked the hardware for shorts and the Serialdata is going in at pin 14 and out at pin 9 (J1 SO-U7 14,U7 9-U8 14,U8 9-J2 SO.....) all is ok. But there is only 2 ShiftRegisters at the MBSeq Pcb ??? Why Define 4? It must be software related ?! I have a small USB adapter for the MicroSD card, insert the SDcard in the PC Open the file with Wordpad, change the parameters and save, then back to the MBSeq and start it up. This is the only way it "works" to access the MicroSD, Have tried the MSD USB The PC only ask me to insert the disk...nothing happens what i do. Best Regards, Dan Lind
This is a copy from Setup File for Wilba's Frontpanel # $Id: MBSEQ_HW.V4 1219 2011-06-02 21:34:29Z tk $ In the Root of my SD-card DOUT_GATE_SR1 5 DOUT_GATE_SR2 6 DOUT_GATE_SR3 7 DOUT_GATE_SR4 8 DOUT_GATE_SR5 9 DOUT_GATE_SR6 10 DOUT_GATE_SR7 11 DOUT_GATE_SR8 12 # if set to 1, the DOUT "gates" will send 1mS pulses # useful for analog drums DOUT_1MS_TRIGGER 1 Still get parallel signals on LED 1-16 and SR1-5, SR2-6 outputs
Hello I want 64 triggers out on the Wilba V4 sequencer, But do not understand how the Shift registers are defined. Have tried to define them But its not clear to me what values 1-16 mean? (Allowed values: 1-16, 0 disables the function, all other values invalid and not allowed) 0 =off,1=on 2-16= ? have tried different values, But the first and second gate shift register works in parallel with some leds on the sequencer. Can anyone Help me? Second: How to activate the Aout_ng in the Seq? Menu/Event/Port_AOUT/and then What? MIDI Channel encoding: Event Chn. Behaviour CC 1..8 (channel itself has no effect) CC Number #16: CV Ouput #1, Gate #1 always set CC Number #17: CV Ouput #2, Gate #2 always set CC Number #18: CV Ouput #3, Gate #3 always set CC Number #19: CV Ouput #4, Gate #4 always set CC Number #20: CV Ouput #5, Gate #5 always set CC Number #21: CV Ouput #6, Gate #6 always set CC Number #22: CV Ouput #7, Gate #7 always set CC Number #23: CV Ouput #8, Gate #8 always set CC 9 CV Ouput #1, Gate #1 always set, CC Number ignored CC 10 CV Ouput #2, Gate #2 always set, CC Number ignored CC 11 CV Ouput #3, Gate #3 always set, CC Number ignored CC 12 CV Ouput #4, Gate #4 always set, CC Number ignored CC 13 CV Ouput #5, Gate #5 always set, CC Number ignored CC 14 CV Ouput #6, Gate #6 always set, CC Number ignored CC 15 CV Ouput #7, Gate #7 always set, CC Number ignored CC 16 CV Ouput #8, Gate #8 always set, CC Number ignored Note 1 Key Value -> CV Out #1, Gate #1 triggered Note 2 Key Value -> CV Out #2, Gate #2 triggered Note 3 Key Value -> CV Out #3, Gate #3 triggered Note 4 Key Value -> CV Out #4, Gate #4 triggered Note 5 Key Value -> CV Out #5, Gate #5 triggered Note 6 Key Value -> CV Out #6, Gate #6 triggered Note 7 Key Value -> CV Out #7, Gate #7 triggered Note 8 Key Value -> CV Out #8, Gate #8 triggered Note 9 Key Value -> CV Out #1, Velocity -> CV Out #2, Gate #1 and #2 triggered Note 10 Key Value -> CV Out #3, Velocity -> CV Out #4, Gate #3 and #4 triggered Note 11 Key Value -> CV Out #5, Velocity -> CV Out #6, Gate #5 and #6 triggered Note 12 Key Value -> CV Out #7, Velocity -> CV Out #8, Gate #7 and #8 triggered Note 13 Velocity -> CV Out #1, Key Value -> CV Out #2, Gate #1 and #2 triggered Note 14 Velocity -> CV Out #3, Key Value -> CV Out #4, Gate #3 and #4 triggered Note 15 Velocity -> CV Out #5, Key Value -> CV Out #6, Gate #5 and #6 triggered Note 16 DOUT drum gates/triggers Notes to AOUT Channel #16 will be redirected to up to 64 digital outputs of the DOUT chain. Each key number triggers an individual gate for 1 mS, accordingly this mode is predestinated for drum triggers. The used shift registers have to be defined in the MBSEQ_HW.V4 file (DOUT_GATE_SR1..8) Sorry if my questions is stupid.... /Dan Lind
http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_seq_pcb_bulk_order Added my name to the bulkorder-list.Are there plans for a new order in the near future? /Dan Lind Sweden
