Successfully finished building a sammichSID last week. Everything went fine.
It wasnt even that difficult to build. :cool: You did really great work with the kit an the superb build guide! :thumbsup:
The only issue is, that i cannot trigger the right notes via midi.
Between C3 and C4 all is played well except G3 (plays C3) and A3 (plays D3).
Below C3 only B2 is correct. Going deeper results in large steps heading C-2.
Above C3 there are also incorrect notes in each octave.
Sysex communication has no problems. I could upload the preset sets and i can use the MidiBox V2 Editor.
(Can watch the parameter changing on the display when editing on the screen)
So i assume sysex and the midi communication in common is working.
I tried a clean patch, with one OSC, no detune, no finetune and no transposition.
For every factory preset the problem is the same depending on the transpose setting.
BL and LD mode makes no difference. I am using Rc37.
I crosschecked with another HW-Synth. Seq, cable and midi-out is okay.
Did i overlooked some "special" scale option or what can go wrong in this context?
