catscase
11 -
Everything posted by catscase
Hi Sorry again Searching on svn mios, I have found dmx.c dmx.h and dmx.mk reading one file, i have view : "dmx in" A midibox using your code accept dmx in ? how does it word ? highest takes priority ? latest takes priority ? dmx full merge ? thanks
Hi all I have searched where adding your code but ... I have found only bin and hex ... not source code ! where could I find it ??? thanks
ok thanks, I understand more ! Do not worry, as you are here on the forum, as you help everyone who want to made a midiboxdmx using your code ! And complete on the forum that said on wiki. So, it is very simple to do ? I need a CORE32 complete board, 4 AIN, some faders, and your code to the core32 code, some faders, many times, and run! on the second midi port, the core 32 sand midi dta a 7 bits resoltions, isn't it ?
Hi Philetaylor I am a bit lost ... on your wikipage midibox dmx you speak only using core8 and IIC ... Do you have another wiki where you speak about it with Core32 ? In fact, with core32 and your code, the midibox do not produce midi but dmx, is it ? thanks
Hi Philetaylor : the code the posted : where do I have to include it ? in the core ? or IIC modified module ? thanks.
Hi Ok thanks philetaylor In fact I was thinking that your project support only 7 bits resolution. I ll try to do it in 8 bits but my knowns in C are very limited. on another post you speak about ARTNET, where are you about this ? thanks
Hi Piletaylor I just read another post you have made and ... You say it is possible to make DMX with core 32. A full dmx ? with 256 levels by channels ? Is that I am searching !!! Nothing more ! Is it that ? Sprry my english is not very good and I need to read and read many times to understand ... thanks
En fait, et pour autant que j ai compris, le midi est une norme ou la velocité des notes est codée sur 7bits ? En dmx le niveau d un canal est codé sur 8 bits. Sinon les normes sont proches. Cependant un projet comme celui vu sur le forum midibox dmx via IIC simule le 8 bits du dmx en rajoutant un bit toujours a 0 comme bit de poids faible ... ce qui fait que pour une velocité a 0 en dmx j ai 0 mais pour une velocité a 1 j'ai 2 sur mon dmx ... et non pas 1 ! Le soucis que j ai c'est que je voudrais me servir de la midiox dmx pour piloter un logiciel de montage video temps reel via le dmx. Dans ce soft sur les canaux d effets a 0 j ai 0 effet appliqué, a 1 j ai un effet, a 2 j en ai un autre et ainsi j'ai 255 effets accessibles + le niveau 0. Idem pour l acces aux banques de samples! donc si ma trame dmx ne me permet pas d acceder aux impairs 1 3 5 7 ... pour chaque canal, bein je pers la moitie de mes effets, librairies ... ... Donc ok il faudra un firmware customisé mais j ai pas encore les outils ni les connaissances pour mieux comprendre comme marchent vos firmwares ni refaire le mien perso ... Tu sais ou contacter smashtv ? merci
Hi Phil ! Really ? you think it is possible ??? Yeeeeesssssss ! I could not help you very more because I do not know anything on C+. I know some things but ... this is limited to program a door for garage ... Do you think I can bought all parts now and waiting your soft ? If needed, I can bought some parts, tests your soft, and only after it, bought missing parts. For my project I need at least 96 faders, so 2 core, 4 AIN, and ? thanks thanks thanks !
Hi all Before starting excuse me for my bad english, I do that I can. I am searching a way to do dmx lighting desk thru a midibox. I see your project, it is very interessant and good, but I need to have access on all level on a dmx channel. Is it in order to pilot a VJing software, and each level of each channel is assign to a different effect. So I need all 256 levels for each channel ... Searching on we I have found this : http://www.response-box.com/mididmx.shtml On "Mode 3" it correspond exactly to that I need. Do you think it is possible to program a core to respect this requierement ? Thanks a lot.
Bonjour a tous je serais interessé pour faire une régie dmx a partir d une midibox. Celle ci aurait 2 activités principales : tantôt extension d une console dmx, tantôt pour piloter un logiciel de VJing. J'ai deja regarde un peu le principe midibox, le hardware proprement dit ne me fait pas peur, par contre je ne sais pas programmer et je ne sais pas si l idee que j ai en tete est realisable ... J'ai vu qu'il y avait deja un projet midibox dmx, http://www.midibox.org/dokuwiki/doku.php?id=midiboxdmx , mais dans celle ci le dmx n'est pas complet. Le dmx a 256 niveaux par canal, or avec ce projet il recompose le niveau dmx en faisant "niveau midi" x2. Ce qui fait qu'on n'a pas une graduation complète du dmx (on ne passe pas par toutes les valeurs). Mais moi j aurais besoin de passer par toutes les valeurs ! surtout pour le VJing ou pour chaque valeur d une canal dmx j ai des effets differents ... si je saute des valeurs, je saute des effets ... En continuant de chercher j'ai trouvé ca : http://www.response-box.com/mididmx.shtml qui sur le mode de fonctionnement 3 m'interesserai. C'est la que j en appelle aux connaisseurs : Pensez vous qu'il est possible de programmer un core pour qu'il produise le signal midi aux normes demandees pour le mode 3 ? Si oui, combien de faders pourrais je mettre par core ? toujours 64 ? ou cela diviserai le nombre de faders par 2 ? Serait il possible "d'empiler" les core pour avoir plus de faders ? si oui combien de core max ? pour combien de faders ? Je ne sais pas si j'ai ete tres clair ... mais je n hesiterai pas a apporter plus d informations si necessaires ! Merci a tous.
