pat_00
32 -
Everything posted by pat_00
Done! (well except for a small issue with 1 row of the matrix leds not lighting up, will fix that later) Now to learn how to use it....
Bingo, switched out the LED and everything works like it should. Thanks for the tip. Almost there!
So the switches test fine under NG debugging, LEDs are still constantly on. Noticed the LED on SW17 doesn't light up when pressed. Replaced the HW config file and still the same issue.
Thanks for the suggestions. I'll upload some photos later tonight. I took some yesterday, but the quality is too bad to be useful. So far I checked: r1 and r2 are not shorted, All LEDs are the correct orientation with the anodes going to the holes marked with the circles. In testing then I found that the LEDs on SW14 to SW18 the LEDs passed voltage (approx 1.6v) in both directions, I'm guessing this isn't as it should be? I also found my Multimeter does not light any of the LEDs in diode test mode except the red 'recording' one. Maybe it doesn't put out enough power for the clear ones? The Cathodes are shorted in pairs to the switch below eg. SW9 is connected to SW14. I guess this is by design and not an issue? I'll do the tests with NG firmware tonight as well, but when I originally tested all button functions were OK (no latching, registering on and off as separate events) but the problem LEDs were still stuck on.
Thought I'd report back, the above issues are solved. They were soldering issues, some really stupid some harder to find. I still have an issue I'd like to fix, the stop, rewind, fast forward and pause buttons are constantly lit up. They function correctly when pushed, but I'm assuming this is not normal?
Ugh, I seem to have problems at every stage :( So I have gotten to the Fluxtest and have issues on both boards. On the LH board, no red led on SW14. Have tested the LED with multimeter and it's fine. On the RH board, no green or blue on SW7 and SW15, same as above, LEDs are OK. I've tried the usual, looking for obvious faults, diodes are all correct., soldering all looks OK. Any hints on where to look?
Hi, I am loading seq_l and have both boards connected as in the video, setting debug to on. It is the left Lemec board that I am having trouble with. All other encoders/switches register except SW17-20.
After a couple of weeks break from the build, I'm back. I tried soldering in the MEC switches that are where the bridge is on both boards. Still no response from SW17-20.....Any other hints where I should look? I've also noticed some of the LEDs on the JA PCB light up now when running the seq_l code.(SW14-18 light up).
I use two kinds, both Kester brand. Both are leaded, one with a water clean flux and the other a no clean flux. I find the water clean solder flows much more reliably, but I was worried about the Super LEDs getting wet seeing as there is a warning about humidity exposure on the video. Also the no-clean solder leaves most of the joints looking dull like a cold joint, so this is annoying when it comes to diagnosing. Which is why I am reflowing things here and there without any real plan.
Not sure, I reflowed a couple of points here and there so that might have fixed it.
I have SW9-12 working now. But still no SW17-20 (on both LEMEC boards). All diodes are correct. Transistors too. Do I need to solder in the MEC switches? In the build video they are not soldered in and the testing works.
Ah, that sounds like it could be one of my problems. Thanks.
Ok, I re-uploaded them at under 800kb each. Hope that works.
Thanks for the tips, had a look and reflowed a couple of points, but no luck. Here are some pics of the areas you mention and the whole board.
Yeah I prefer the chisel tip for most things, except for the really small stuff. On to the next problem, I have moved forward to testing the DINs. Everything works OK....but SW9-12 (Matias) and SW17-20 (MEC).. no response there. I'm guessing it's one of the 165s? all the soldering on them seems OK. Any clues where to look?
The expanders look great. So max triggers/gates is 64. What about CV?
So after giving the board a thorough clean with ISO alcohol in preparation for it's photo shoot, Ifound a pin on J89 that didn't look soldered too well, so I reflowed it. It all works now. I am relieved that I don't have to show you all my crappy soldering.
Are the full schematics available anywhere? I've searched online and can't find them. I have a problem with testing the JA PCB. I've flashed the NG firmware and the seq_l script loads OK, I set debug on but there is no response from any of the controls or LEDs on the JA board. Any pointers as to where to look? I have checked all the ICs on the wCore and JA PCBs and reflowed anything that looked less than optimal.
Thanks for the advice! I replaced them without too much hassle using hot air. Might have slightly damaged pad 1 on IC1A, but it looks OK for now.
So after building dozens of other DIY projects, I finally goofed and installed some ICs backwards. On the wCore board, i had the 74HC125s flipped around the wrong way. I only found out when I plugged the USB into my laptop. The laptop figured the USB was drawing too much power and shut down the port fairly quickly. Would the chips have survived this? Should I just remove and re-install them, or replace them? Anything else I might have fried?
these caps look good. I'm thinking about it... I was going to try painting the inside walls of the caps if the colour bleeding annoys me too much. Any news on the CV/gate expander?
It seems Mouser only has 33 of the MEC switches left (you need 34) and they have a 30 week lead time on getting more! I found RS Components still has them. What about the DMOS chip? TBD62381AFWG,EL. This is also out of stock at Mouser. Can I substitute another IC in the same series?
Looks amazing! getting really excited about this.
Congrats, shop looks great. What are your plans for customers outside the EU?
